Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Dyson DC17 Animal Brushes turn but won't ****
All hoses are clear, filter is washed. I turn on the power button and nothing. The only way it will do anything is if I put the handle down and then just the brush works, doesn't **** at all. Top or bottom, NO NOISE. Any suggestions? Besides this, LOVE IT. But I need help.
Thanks
  • cisherwood13 Jan 03, 2009
    I have the same problem. Checked and double-checked that elbow.. all is clear. No blockages in wand or tube. I have noticed that 3 of the holes are blocked with hair, etc. in the upper purple chamber, but am having great difficulty reaching that. Could this be whats stopping my vacuum from sucking up the dirt? Beater bar works, just no suction.. at all. Need help.. my floors are a disaster!! Thank you!
  • Anonymous May 25, 2009
    how do you take out the elbow tube?
My wife had precisely the same problem. I did what dskurth said above and instantly fixed it. Awesome! Found a 6" long eyeliner thingy wedged in there. Just WAIT till the daughter comes home!! 8-)
Thanks dskurth!
Posted on Jan 19, 2009
  • 3 Answers
Had the same exact problem (literally the EXACT problem) Take out the elbow tube and make sure it is clear. I found a small little plastic part (very small), but it did not make the turn. When I took the elbow tube off, it feel out. Upon reassembly, everything worked fine again. Seems that if the not the right amount of air flow is on, it stops.
Posted on Jun 10, 2008
  • sirtony Jan 27, 2011
    If the vacuum won't power on it means the motor is overheated, it has an automatic cut off which will power it down for 45 minutes. The motor can overheat if the filter is too clogged. The filter can be clogged frequently if the seal at the bottom of the canister is compromised alllowing extra dirt and pet hair to cover the filter (pet hair should never make it to the filter otherwise). If the seal is not adequate Dyson will likely send you another cannister.
2 Suggested Answers
  • 53 Answers
SOURCE: dyson dc17 animal stopped sucking. brush still
Make sure the flexible hose that connects the beater brush housing up to the connection up by the dust bin is still connected. It could also have a hole in it so check for that as well.
Posted on May 31, 2010
Does Dyson dc17 have a reset button to restart brushes
Please review the material here: http://www.dyson.com/Support/dc17/DC17-ANIMAL/DIAGNOSIS-ROOT-MENU/Flo-DC07-Gen-I-can-see-something-wrong-visual/Redirect-to-Flo-DC17-Check-brushbar/Flo-DC17-Check-brushbar/Flo-DC17-Reset-brushbar/Flo-DC17-Reset-brushbar
Feb 22, 2015 | Dyson DC17 Animal Bagless Upright Cyclonic...
My hose for tools has know power
Hi there, it's Jack at Dyson.
If your machine doesn't seem to have as much suction through the hose as normal, there may be a blockage in the hose, wand or U-bend, and the filter may need a wash. To check for blockages please follow the steps shown in our Support guide:
http://content.dyson.com/support/help.asp?article=969&product=DC17-ANIMAL
In normal use, the filter should be washed at least once every 3-6 months as shown in the video below. Use cold water without detergent, and allow at least 12 hours for the filter to dry completely before replacing it.
This should resolve the issue, but if you feel your machine isn't picking up correctly after following these checks please get in touch with us directly so we can help further. If you email us at askdysonUS@dyson.com, we'll be in touch as soon as possible.
Best wishes,
JackDyson Online Customer Supporthttp://www.dyson.com
Feb 27, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
When you use hose and it accidently sucks say a curtain or cushion it will make a sound as if a valve opens so it doesn't **** as much, well now it does it all the time as soon as its turned on in the...
I'm sorry to hear you're having difficulties with your DC17. From your description, it sounds as if you have a blockage in the hose or wand. The easiest way to check for and clear any blockages is to follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
It's also a good idea to wash the filter - under normal use, this needs to be done at least once every 3-6 months. Use cold water without detergent, and allow up to 24 hours for the filter to dry completely before replacing it. For guidance on doing this, please see the video linked below:
http://www.dyson.com/support/help.asp?article=1463&product=DC17-ANIMAL
Following these steps should enable you to resolve your issue without further assistance. However if you've tried this and are still concerned, please get in touch with us directly - one of our experts will be happy to run through some troubleshooting over the phone with you. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible.
Kind regards,
Jack
Sep 15, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
We checked everything on the vacuum, except the motor. Is there a way to check? Vacuum just stopped running. Its a Dyson DC17. Thanks!
I'm sorry to hear you're having difficulties with your DC17. Like most Dyson cleaners, your DC17 is equipped with a safety device which shuts off the cleaner if it starts to overheat. This is often due to a blockage - I'd also recommend washing the filter. The easiest way to check for and remove any blockages is to follow the steps shown in our online guide:
The correct way to wash the filter is shown in the video linked below. The filter should be washed in cold water without any detergent, at least once every 3-6 months. Always ensure it's totally dry before replacing it - this may take up to 24 hours.
By clearing any obstructions and washing the filter, you should be able to resolve your issue without further assistance. However, if you've followed these steps and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you and recommend the best course of action.
Kind regards,
Jack
It's making a terrible high pitched whining noise. It's an Animal DC17.
Sorry to hear you're having difficulties with your DC17. It sounds as if you may need to check the cleaner for any blockages, and to give the filter a wash. The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide:
This video demo shows the correct way to wash the filter. Under normal use, this should be done at least once every 3 months:
By clearing any obstructions and washing the filter, you should be able to resolve your issue. However, if you're still concerned, it's probably best if you get in touch with us directly so one of our experts can run through some troubleshooting over the phone with you and recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact with you as soon as possible.
Kind regards,
Jack
Dyson Customer Service
Aug 10, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson dc17 has no suction from hose and shuts off when hose is pulled out
By clearing any obstructions and washing the filter, you should be able to resolve your issue without further assistance. However, if you've followed these steps and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 1866MYDYSON - one of our experts will be happy to run through some troubleshooting over the phone with you and recommend the best course of action.
Kind regards,
Jack
Jul 03, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal does not have enough suction from the wand handle to power the mini turbine head. The wand handle has very little suction.
Hi its Darran at Dyson.
It sounds as though your wand/hose assembly is blocked. Try following the blockage procedure in your user guide or visit our website's support section where you can use our self help guide to diagnose problems.
www.dyson.com
Kind regards
Darran
Mar 10, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a Dyson DC17 animal vacuuum. Recently got
you need to check the clean out ports 1 directly under the hose on the bottom and the other where the removable filter is
Jan 02, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC 17 Animal...Lound Clanking sound
There is something most likely jammed in the brush roller. Check it and clear the brushes out.
Mar 08, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a Dyson DC17 Animal Bagless Upright Cyclonic Vacuum and it lost suction. How do I get it fixed? Also, is it possible to get a second filter for this machine?
OK. Lost suction almost always means blockage. You need to check all the pipework, the hose and any bits you can remove at the base of the machine - if I remember right, the DC17 has a sort of U shaped bend at the bottom of the handle that you can remove - also turn it over and inspect the clear flexible plastic tube (if it's not blocked, it can get damaged and leak). As for filters, you do of course need regularly to wash the filter that's above the cannister (wash both the blue sponge and the yellow carrier) and be sure they are dried gently for at least 12 hours before putting them back.  If you need new filters, any vacuum service shop should be able to supply them. I hope this helps. I value your feedback so please remember to rate my response.  Good luck!
Feb 25, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
1,296 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
