Question about Electrical Supplies
On a 120v primary / 24vac secondary transformer, how do you know which of the secondary wires are the common or the 24vac?
Take your multi-meter and test each lead to ground.
The hot wire will show voltage.
The neutral will not show voltage.
Set multi-meter to 24V
Put one prong on wire, put other prong inside ground port on wall plug
On a 120v primary / - 0145983.jpg
Posted on Oct 08, 2010
  • ladle76266 Oct 08, 2010
    Conducted test with two different inexpensive auto-ranging multimeters and get 10vac on known common (orange lead out of transformer) and 8vac off 24vac lead (brown lead). Then conducted test with "good old" analogue Simpson meter and get the same 1/2 vac from either lead. Any other suggestions?
  • Anonymous Oct 09, 2010
    I was mistaken with my answer.
    My test was for DC transformer.
    When setting up electronic circuit, you use DC transformer.
    I think your test is accurate for AC transformers. There is no neutral back to ground because of how transformers work. The 120V AC runs through a coil, and the electric field from the first coil causes alternating current in a second coil. That would indicate both leads would show voltage to ground.
    What exactly are you using transformer for? Perhaps if you re-post with objective-defined, we might have some insight.
    I post similar questions on electronics forum:http://www.electro-tech-online.com
    A lot of the helpers at electro-tech are looking for contract work building circuits
Have an old rheem heat pump split unit. Replaced condenser fan motor and contactor. Compressor and fan both come on when you manually trip contactor, but will not come on from thermostat. Was pretty...
Remove the thermostat face and place a jumper between R and Y. The outside unit should come on. If it doesn't, check for 24vac between R and C or R and Y. If you don't have it then you need to check the transformer. Check for 24vac on the transformer secondary and 120vac on the transformer primary. If you don't have power on the primary, check for a blown fuse or tripped breaker. If you do have power on the primary but nothing on the secondary, you need a new transformer. If the unit does come then the thermostat is the problem.
If the transformer is good and the unit doesn't start when you install the jumper then you have a problem in the outside unit. It could be the contactor coil which you can check with an ohmmeter. It could also be a low or high pressure switch or and overload all of which you can also check with an ohmmeter. Let me know what you find.
Nov 07, 2010 | Heating & Cooling
No 24 vac on yellow or compressor thermostat terminal in heat or cooling .
Turn the thermostat to off and check for 24vac between R and C or R and Y. If you don't have it then locate the transformer and check for power on the transformer primary side (120vac). If you don't have power on the primary side, check for a tripped breaker or blown fuse. If you do have it then the transformer is bad. You can confirm that by measuring the resistance of the secondary side of the transformer.
MY A/C WAS WORKING FINE THEN JUST CUT OFF AND THE ELECTRONIC THERMOSTAT WENT BLANK I CHECKED THERE IS NO BATTERIES CHECKED THE DRAIN PAN AND THE BREAKERS ANY IDEAS WHAT IT MIGHT BE
Check the transformer. Remove the thermostat face and use a voltmeter to check for 24vac between the R terminal and the C terminal. If it's not there check for power on the transformers primary and secondary sides. Replace the transformer if you have power on the primary and none on the secondary. If you don't have any on the primary you should look for a fuse or another circuit breaker.
Sep 12, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Have a problem with my Intertherm air conditioner not coming on so I put a new thermostat on it. Nothing comes on fan nor heat nor air. I reset the breaker but still nothing and the unit model is a...
Turn the thermostat off and check for 24vac between R and C on the thermostat. If there is no C then to G or W. If you don't have 24vac go the transformer and check for 24vac on the secondary. If it isn't there then check for 120vac on the transformer primary. If it isn't there check the circuit breaker/fuse. If it is there then ohm the transformer windings and replace if bad. Let me know what you find so I can offer more advice.
Aug 10, 2010 | Intertherm P3RA-048K Air Conditioner
Service tech and working on a h-250 nat gas. transformer burnt got new one.Q out the bottom of the trans is there to be 24vac that goes to the yellow wires? and does the trans need 240v for this trans I...
The transformer should have primary and secondary ratings on it. Is the primary rated for 240 or dual rated 120/240? If it is connect it to a 240V primary as shown in the connection diagram that should have come with it. If the seconary is 24VAC and that is what the heater should get then hook it up to the heater. Wire orientation won't matter since their is no polarity to the 24 VAC signal.
Dec 16, 2009 | Plumbing
WAVE radio transformer bad ???
If you can check ohms,you can also read volts. Open the radio again and look for DC volts on the rectifiers capacitors.They look like :cans", normally the color is blue. Check for positive dc v. against chassis ground. If no + tension,your rectifier or your secondary are open.
Aug 24, 2009 | Bose Wave Radio
Transformer secondary out ???
please my name is dele i have this BOSE radio/cd system model number is AWRC2G which transformer burnt out rightly, that the input is 240volts which output is the problem and in nigria. please i just want to know the output on each coloured wire of the secondary that has 8 wires output from the secondary (2 purple - brn = volt, 2 blue = volts, and 2 black - gray = volts. so that similar that i can use to work it.
thank you
Weatherking gas furnace and need help with transformer wiring
on 120v units most likely will be white should be common,black should be hot,brown to capacitor, and green to ground transformer sounds to be wired correctly.
Jun 26, 2009 | Heating & Cooling
My sx-315 pioneer receiver overheated and shut down.
Probably the thermal fuse in the main power transformer. Check for ac on both the primary and secondary of the transformer. If you have 120v ac on the primary when the standby light is off and nothing on the secondary you need a new transformer.
Feb 08, 2009 | Pioneer SX-315
It wont turn on
If nothing will come on check the breaker to the indoor section, check that the service switch by the in door section is on and the blower door cover is tightly closed. If all these junctions are transmitting power then it may be a burned out transformer. If you can check for 120v on the primary coil of the transformer and 24v on the secondary that would tell you where the problem is. If theres no voltage on either side then backtrack from the transformer on the 120v side till you find 120v. If theres 120v but no 24v your transformer secondary is burned out. If theres both then the problem is downstream from the transformer: circuit board 3amp fuse, loose wiring.
Jul 17, 2008 | Ruud Matching Split Air Conditioner
Electrical Supplies Logo
330 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
