Question about Vacuums
Ambassador 111 Electrolux canister vacuum, model C101H, stopped running for no apparent reason.
  • arnoldrobbin Jul 01, 2008
    Sears repair service has advised the motor is bad and no longer available but I'm not ready to accept that as the final answer. A look at the power harness is certainly worthwhile and also a look at the brushes inside the motor. I suspect Sears is more a parts replacement operation than a repair service.
  • Anonymous Jan 20, 2009
    I have the same problem. My Electrolux Ambassador will not turn on -- no power whatsoever. It has been working fine with no indication of something going wrong. Is there anything like a reset button?
Y want how to take off the motor on electrolux ambassador
Posted on Jun 24, 2010
Had same problem about a year ago. Had it serviced and was advised the power harness of which the retractable cable had to be replaced.
Posted on Jul 01, 2008
  • 4 Answers
Take to a independent vacuum dealer parts are available and its not that hard to fix. If you cannot find part go to www.banksvac.com you can get parts from them they have or can get and fix anything
Posted on Aug 08, 2008
My electrolux ambassador power head goes on and off as I try to sweep. What can I do?
Most probably the hose has gone bad. You would new a new one. this will fit your vacuum
http://www.ezvacuum.com/electrolux-hose-with-switch-control-for-electrolux-canister-vacuum-vnotch-generic-p-1525.html
Jan 11, 2013 | Electrolux Vacuums
How do i open the housing of an electrolux ambassador model #c101j to fix cord recoil
This can be a complex undertaking, so I highly recommend taking it to the nearest Aerus Electrolux store for repair. I've seen many disassembled machines come in to the shop because the owner couldn't figure out how to put it back together. Any misplaced wires during reassembly can result in nonworking vacuum, shock and even fire hazard.
Taking it to the shop may cost more, but I believe is less expensive in the long run. They'll do it right.
http://www.aerushome.com/storelocator/
Dec 14, 2010 | Electrolux Lux 5500 Canister Vacuum
Bag full switch is bad
I assume this is an Electrolux Canister with long narrow body and a dial control on top for adjusting the bag fill level.. Please confirm model and name on canister, as in LE, Ambassador, Renaissance, etc.
If this is a plastic bodied unit with 2 side bumpers the body opens like a **** shell after sliding the bumpers out the front. The normal cause is a failed control valve under the dial at the top center of the vac. The failed part can only be replaced, not serviced and can purchased through an AERUS Electrolux repair center. Please confirm and I can wa;lk you through the process if required
Dec 12, 2009 | Vacuums
I need a price for a wand for my electrolux ambassador 2100 vacuum cleaner
This same wand is used on all older canister models since 1974 until about 1995.
Metal wand, about $24.
Upper wand assembly, about $34.
Parts should be available at any Aerus shop.
Of course, you can try to find used ones, often with complete vacuum, at second hand stores, pawn shops, yard sales, estate sales, etc.
Sep 29, 2009 | Electrolux Vacuums
ELECTROLUX C101H JUST SHUT OFFWHILE WIFE WAS VACUUMING, DOES THIS HAVE AN INTERNAL THERMAL OVERLOAD SWITCH ? HOW TO OPEN UP CANISTER TO SERVICE ??
it does have an internal thermal overload device you need to put the vacuum into the shop they should be able to fix it in a few days
Aug 01, 2009 | Electrolux Guardian Bagged Canister Vacuum
Hi, I have an electrolux Ambassador and the other day I was vacuuming a fringe carpet and the fringe made the electrolux stop (has happened before) and when I pressed the reset button, the motor is on but...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=678083
Generic problem for all Vacuums
Hi, I have an Electrolux Ambassador
Posted by greenforest on Jun 17, 2008
Hi, I have an Electrolux Ambassador and the other day I was vacuuming a fringe carpet and the fringe made the Electrolux stop (has happened before) and when I pressed the reset button, the motor is on but the wheel does not spin. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are 2 possibilities that could be happening. Either the belt is broken of which you can replace the belt @ least one a year for proper maintenance or there may be a reset for the vacuum in case you get something caught in the brushroll section of the vacuum. Check both of those items and it should work unless you have a motor burn out – if you did there would be a burning smell. Feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 17, 2008 | Vacuums
Electrolux Ambassador stainless lower wand
http://geeksquad.fixya.com/ThreadView.aspx?prdid=113654&thid=638738
Posted by Cuyler on Jun 01, 2008
I am trying to locate a stainless lower wand for an Electrolux Ambassador model 1623. The search has proven fruitless so far. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. A couple of thought came to mind that you can try. Look in the yellow pages for your local vacuum dealer to see if they carry it to contact your Electrolux factory @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Go Ahead. Use Us.
Jun 01, 2008 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
1,079 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
