Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Is there a power fuse in this tv. sony 32" 1998 trinitron. Had great color, picture & sound. Will not turn on/no power.
    Scholar:
  • 143 Answers
There are fuses in most TV's... and in some cases, it's nothing but the fuse. BUT, the fuses are there to protect the circuits... so unless you know that there is nothing wrong with the TV, you shouldn't simply replace the fuse and plug it back in. However, if the TV is an older TV and it's either fix it by replacing the fuse or get rid of the TV... then I'd certainly take out the screws and check the fuses in the TV. But many times the fuse blows to protect it when something else fails... so if you find a blown fuse, look around for other signs.
WORKING ON ELECTRONICS should be done by professionals!! Proceed at your own risk!
Posted on Oct 08, 2010
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    https://esupport.sony.com/.../select-system.pl?...RCOD...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony
    https://docs.sony.com/release/KV20FV12.PDF Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
Dec 08, 2015 | Sony Televison & Video
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Tv keeps turning itself off and the white in the picture looks alittle off.
To get the right colors, especially a plain white, requires the right mix of red, green and blue from the picture tube. Sony TV sets have a circuit called AKB that automatically keeps the picture tube balanced by adjusting the signals to it. If that balance can't be achieved it shuts off the picture. This may due to tube aging so one of the color guns is too weak to adjust, or failure of parts in the AKB circuit itself. If the sound stays on and the power light starts blinking when the picture goes off, this is likely why.
On the other hand, if the set is turning off completely with no picture, sound or power light, the set may have power supply problems or defective parts in the picture tube high voltage circuits.
Since there are several possible causes, this set needs to be checked by a technician who can diagnose the problem and decide what needs to be done. It's not a simple thing I can point to and say "change this part". If the picture tube is the cause, it's better to replace the set. Otherwise get an estimate, then decide whether to fix or replace.
Apr 04, 2010 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Tv will not turn on but the stand by light is on and the tv make a click when you press the power button and the tv goes back to stand by mode. Any help would be great.
It sounds like it might bbe a fuse. Take the back off and check the fuse for open,(blowed). Replace it with the same amps. ...Hope this helps...
Mar 07, 2010 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
My tv just blanked off and want come back on its a sony trintron 36inch color tv
do you have any audio? if you do the it's usually a fuse for the video circuit. if no sound no picture, then main fuse power supply out
Sep 21, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Picture color is distorted.
Try turning off power and let set cool completely. Then turn back on. Letting it cool complety re-arms the autmatic degaussing circuit. It may take several cycles to completly clear it up.
Jul 25, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Tv doesn't turn on.
Does this have a replacable lamp? If so it will do exactly this. If it does it's probably fried.
Mar 27, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
SONY FD TRINITRON WEGA KV-32FS12
That generally means that the CRT is weak and is putting out low emmisions. This is confirmed by the fact that the color quality is not that great when you can see a picture IE: not enough red, green or blue. This is very common when these CRT's age.
Sep 08, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power on no picture no sound
the 2 bilnks is a fault code for a (b+ overcurrent), you could have a bad horizontal output check q506 or q505, varies by modle. I have also run into a bad color amp ic1751. use a multimeter to test the h. o/p transistor, as for the ic, easier to replace than test.
Oct 29, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
174 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
