Acer Aspire 5335 battery is plugged in via Ac adapter but only says plugged in not charging
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Oct 08, 2010
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
I have an ACER M5-581 and when the battery gets low and I am working on it and I plug it in to an AC outlet and continue to work it will show a charge for a few seconds and then stop charging. I have to...
If the battery is actually taking a charge but it seems the battery only lasts a short time after charging... it's time to buy a new battery. They eventually won't hold a charge very long
Note this is a separate problem then the case where the AC cable is plugged in yet the battery takes NO charge (what happens when the power jack breaks its connection to the computer so NO power reaches computer at all via AC adapter.
http://www.aurabuy.com/cheap-4400mah-battery-for-acer-travelmate-8473t-8573-8573g-8573t-4370-5335-5340-7340-tm5742-4740z-8573tg-5742z-paypal.html
Mar 31, 2013 | Acer Aspire One PC Notebook
I have a acer 5741. I have tried many times to charge it but it wont charge no matter how long i leave it plugged in. It is stuck on 10%. When I plug it in it says its charging but nothing actually...
1. Unplug AC adapter. Shutdown
2. Remove battery, Connect AC Adapter
3. Start windows7. Remove Microsoft ACPI-Compliant Control Method Battery under device manager , battery
4. Shutdown, Remove AC Adapter, Install battery, Reattach AC Adapter.
5. Power up -
Now Plugged in and Charging.
Aug 04, 2011 | Acer Aspire 5520-5908 Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Shut Down with message that battery power out. Was connected to AC via power supply at the time
When the ac adapter is plugged in does the charge light come on to indicate the battery is charging? If not, the charger has probably failed. Faulty battteries can also cause a charger to fail. Both need to be checked.
Dec 11, 2009 | Acer Aspire One PC Notebook
Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Sep 08, 2009 | Acer Aspire 4520-5582 Notebook
I have forgotten my bios password and want to clear or reset it
Open it up. Remove CMOS battery for 30 seconds, the one about the size of a quarter or nickel. Before putting it back in, hold down power button, WITHOUT it haveing a battery or AC adapter to clear all power to the CMOS whatsoever.
Jul 02, 2009 | Acer Aspire 5335-2257 Notebook
Problem with charging adapter on my laptop acer aspire 5335
the charger gets real hot??????? O really? wonder why?....Charger defect... guaranteed
Jun 27, 2009 | Acer Aspire 5335-2257 Notebook
My acer is plugged it but will not charge
if the adapter charge the battery but cant keep the lappy power up thereis something rong with your motherboard. to test take the battery out plug adapter in turn lappy on. if it does not power on motherboard problem
Apr 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
