Question about GE PTS22LCS Top Freezer Refrigerator
The top overheats - GE PTS22LCS Top Freezer Refrigerator
My car overheats, new thermostat, Radiator flushed out Coolant recovery tank replaced, still overheats
If the water pump is moving the coolant,then you may have a bad head gasket allowing combustion gas into the cooling system.Fill the cooling system right to the top and without the cap on watch for a constant flow of bubbles coming to the top.Bubbles?=bad head gasket or a crack.
Sep 03, 2017 | Cars & Trucks
Tip
Laptops can easily overheat
A laptop can easily overheat but placing it on a granite counter top while working keeps it cool. Make a homework place in the kitchen instead of in the bedroom for teenagers who forget to turn it off .
on Jul 07, 2010 | Computers & Internet
My 406 overheats even after changing top cylinder
radiator could be clogged try clean it out ,maybe take out termistat.
Dec 11, 2012 | Cars & Trucks
Will not spin code f 51 flash on top
In my opinion you may be using excessive amounts of detergent. This makes the rotary position sensor overheat.
On board intel senses SUDS and built in features work to get rid of it causing the RPS to overheat. Read more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
The car overheats. How can i replace the
follow the top rad hose to the block, should be connected to a goose neck, remove gooseneck, thermostat should be there.
Oct 27, 2009 | 2002 Chrysler PT Cruiser
Why is the top of my dryer getting so hot?
Check the moisture vent for restrictions from the dryer to where it exits outside. If it is restricted dryer will overheat. Also thermostat could be faulty causing dryer to overheat. And finally the insulation might have moved out of place inside the dryer causing the top to get very hot.
Sep 24, 2009 | GE Dryers
XB31 projector overheat
Hi sun_md
This sounds like a typical temp. sensor that is faulty.
If you take off the top cover of the Projector and follow the cables from your fans to the Mainboard - you'll find a smallish board that regulates the heat of the Projector. You will also find another sensor on top of the lamp housing.
Try replacing the sensor that goes with the fans first , this is normally the one giving problems.
Good luck and thanks for using Fixya !
May 22, 2008 | HP Digital Projector xb31 Multimedia...
GE PTS22LCS Top Freezer Refrigerator Logo
19 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
