Question about Garmin nuvi 350 GPS Receiver
Screen frozen Have full satellite reception, fully charged battery. Have tried resetting several times, unit displays "Where to" and "View Map" as well as wrench and sun icons. Tapping any of these does not take me to next option.
  • 174 Answers
It appears that the touch screen isn't working any more. If it is still under warranty then request a RMA from Garmin and send it back.
Posted on Jun 05, 2008
Sony pocket ereader frozen on "are you sure you .....delete items. tried reset many times ...won't work. it is fully charged. plugged in to computer & no lights come on ... computer does not...
Hi shianto,
Because of e-ink screen technology the reader will display last page even if the unit is not charges it may display "full". Try this:
1. Connect the reader to the PC and check if a redlight comes up
2. If there is no light, hit the reset at the bottom for 3 seconds, the light should come on now.
3. Leave the unit charging for about 15-30 minutes
4. Unplug the unit and see if its operational now, if not you can try the reset again and the slide the power switch
eBookBoy
May 14, 2011 | Sony E-reader Portable E-book MP3 Player
710 frozen on tom-tom splash screen
1. Activate the TeleType GPS program
2. Select Tools>GPS Status>Status.
3. Look closely at the GPS output that is displayed in the View Status menu. Data should be flowing even when the GPS receiver has not locked in the position.
The data string that begins:
GPGSV... is "bad data" because the receiver has not locked into the satellites.
Whereas:
GPGSA... is "good data" indicating that the receiver has locked into the satellites. Remember - "A-Okay"
4. Once the data is flowing, go outside away from buildings, select the Satellites tab (Tools>GPS Status>Satellites), and watch the satellite signal strength
Nov 27, 2007 | Tomtom GO 700 GPS Receiver
Garmin 260...unit turned on with good signal and fully charged batery and plugged into car power. display asks to AGREE to terms and conditions, then goes to WHERE TO or VIEW MAP, if either optionis...
Have you tried a master reset or updated the software?
Note: A master resetwill erase all waypoints or favorites and will restore your unit to the defaultfactory settings. But who cares if you have problems, right?
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the onscreen prompts then place your device in an area with a clear view of the skyuntil it acquires satellites.
IF this does not work, try updating to current software and maps.
Feb 03, 2011 | Garmin nuvi 260W GPS Receiver
My screen is frozen even after trying reset it. What should I do? The battery is fully charged.
hello , since u have tried reseting it , u have to hard rest the devive , follow the instructions below,,
Hard Reset (PRS-600/900)
WARNING: A HARD RESET WILL ERASE ALL TRANSFERRED CONTENT ON THE READER. IT WILL NOT ERASE THE BUILT-IN DICTIONARY.
1. Power off the Reader.
2. On the bottom edge of the Reader, using the stylus, press the RESET button.
3. Turn on the Reader.
4. While the screen displays Opening book... , simultaneously press and hold down the Page Turn button and the VOL + button until the Reset All screen is displayed.
NOTE: If Opening book... does not display on the screen, charge the Reader's battery for several hours before attempting the reset process again. 5. Touch YES to reset the Reader.
,,,regards ..i hope this was helpfull
Dec 04, 2010 | Sony Reader Touch PRS-600
Dropped my Garmin 260 it functions but not able to get satelite reception. a screen keeps popping up that says GPS firmware updating 1% then 10 seconds later it jumps to GPS firmware complete and show the...
Try a master reset: After you know the batteries are fully charged!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To perform a Master Reset on the nuvi 200,series device: Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Nov 14, 2009 | Garmin nuvi 260W GPS Receiver
Cannot locate saltellite or Acquiring satellite
The error means it can't pick up valid GPS signals. In other words, bad reception.
Has the unit ever worked? Does the unit have an internal or external antenna? Are the batteries fully charged?
Try the unit outside with clear view of sky instead of in the car. This will give it the best chance of picking up a GPS signal.
If it still doesn't then suggest something broken inside.
May 20, 2009 | Garmin nuvi 200W GPS Receiver
To make un full reset
Hello Rahooty,
There is no way to set the date and time becayse the system clock in your Garmin Rhino 120 should be updating based on the information it receives from the GPS satellites. The radio should auto locate itself within about five minutes of being turned on providing it has a clear view of the sky. Once it sucessfully auto locates the radio's clock and position should reset. There does not appear to be any other reset built into the device.
Try taking the batteries out for at least 5 minutes. Then, reinstall the batteries, turn the unit on, and give the unit 5-10 minutes to auto locate. If it doesn't, you may need to contact Garmin support for additional sevice.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 05, 2008 | Garmin Rino 120 2-Way Radio
Battery Charging
You can tell the battery is fully charged on this model from the Where to go and View map page. It displays battery status in the upper right corner when disconnected from the cable or charger.
Don't know on the reet as I have not done that. You might try the garmin website and post a question to their support group.
Dec 26, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
64 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
