Question about Microsoft Windows XP Professional
I cannot fix the resolution of my computer xp what i will do to fix it.
    President:
  • 2,291 Answers
Uninstall ur video card driver and then use reginout cleaner to fix registry error and then reinstall driver it will work
Posted on Oct 08, 2010
My monitor says out of range
You have set the resolution or refresh rate of your display adapter to a value which is too high than what is supported by your monitor.
In order to fix this, you have to do the following:
1. Reboot your computer & press F8 to boot into Safe Mode.
2. Once in Safe Mode, open Device Manager.
3. Remove the display adapter device driver form Device Manager.
4. Reboot your computer again. Windows will boot up normally & will detect the display adapter. It will prompt you for the device driver for the display adapter.
5. Use the CD that came with your display adapter to install the device driver. Once done, your problem is fixed.
Sep 01, 2011 | Insignia D300a PC Desktop
How can I fix an "Out of Range" display?
Please reduce display resolution of computer/ laptop to solve "out of range" error because laptop is producing high resolution video signal and monitor hardware is unable to show that much higher display resolution so causing that error message.
Let me know what Windows version (XP, Vista, 7) is running in laptop to provide you more info or check Display Properties in control panel and change it to lower resolution to get picture in monitor.
Thanks.
Feb 09, 2011 | Westinghouse L1975NW Monitor
I bough the LCD model VA2231w- LED every time I turn it on then it pop up that change the resoluyion to 1920/ 1080P I don't know how to do it. So please help. Thanks Thai Nguyen
This would be the Native resolution. That your display functions and displays best in.
Windows XP, Vista and Windows 7.
(1) RIGHT mouse click over your desktop.
Windows XP will differ - but same basic idea to navigate and make this fix.
Pictures show from a Windows Vista Machine (extremely similar to Windows 7)
(2) Click Display settings
(3) Now you'll see a slider bar, Native Computer Display 1680x1050 resolution.
Some computers can not support this resolution and may cause non operational situations.
If the display setting is not on the slider bar. Chances would be that it's not a supported Resolution.
"Older computer" If the display doesn't show while trying different resolutions - do not click apply and wait. the screen will return to it's previous setting. ViewSonic VX2235 has a Setting that could be used to Disable this annoying message - Revert to ViewSonic lightdark_2.jpg
Nov 15, 2010 | ViewSonic VX2235WM Monitor
The display is not fit on the monitor help me how to fix it thanks!!! ayanblink@yahoo.com
You need to set your PC video resolution to the native resolution of this monitor, which is 1440x900 @60Hz. Mkae sure to to have correct video card driver installed and may also need the driver for this monitor if the native resolution is not listed.
Resolution adjustment:
From Microsoft: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx?mfr=true
and here:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
and here:
http://www.videojug.com/film/how-to-change-screen-resolution-in-windows-xp-and-windoiws-7
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 09, 2010 | Acer AL1916W 19" LCD Monitor
Input signal out of range
Did you mean "out of range". Try reloading video drivers. If that doesn't work, perhaps screen cannot use that resolution.
Jun 28, 2009 | HP Pavilion F1523 15" LCD Monitor
My monitor requires a resolution of 1360 x 768 but I can't change it in Windows Xp eu but I could before with others versions of windows
The allowed resolution does not depend on the Operative windows used (XP,Vista, etc.) , but on the video adapter installed on the computer and on the video card driver.
If resolution 1360 x 768 was supported before on the SAME computer with a different system, then you may need to re-install the video card driver.
If resolution 1360 x 768 was not present before on same computer, then the display adapter installed on this computer may not support 1360 x 768.
Check specifications on Google, download updated display drivers, and if nothing works, then buy and fit inside the computer display adapter supporting 1360 x 768, like the one here: e-GeForce 7200 GS TC 128 MB PCI-e Graphics Card
Apr 01, 2009 | LG W1941S-PF Monitor
No Driver
You can use the .icm file from the Vista driver by manually going into driver update and pointing to the location wher you extracted it to. This however probaly won't fix your issue however, as the problem is more than likely that your videocard doesn't support the 1440 x 900 resolution.
Oct 13, 2007 | Acer X191WSD Monitor
Microsoft Windows XP Professional Logo
22 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
