Hhow to set the pressuretrol?? - Heating & Cooling
  • 43,501 Answers
I assume you are talking about a steam heating system...
There are two screws on the top of the pressuretrol...
turn the pressure screw down to the lowest pressure at which you still get heat to the farthermost radiator...make sure the vents are working...or steam does not flow to displace the air...
Then just give the differential screw enough difference so the boiler cycles on and of a bout three times and hour...when making steam...
That's all there is too it...
heatman101
Posted on Oct 08, 2010
I have a 220v pressuretrol connected to my well pump. Also connected was a 220v chlorine injection pump. Recently the pump cratered, had a teck install a new pump, however it is 110V, he changed the wiring...
The 220VAC is most efficient and less costly in the long run. You should not have changed over. Got back to what was working for you in the past!
Jan 04, 2015 | Dryers
What do you do if it is firing but wont crank? hhow do you adjust the carburetor on a eager beaver 2.0 chainsaw
turn both high and low screws in. now back the low screw out one full turn now the high side 3/4 turn unit should start at these settings
now run engine and fine tune carb
Aug 14, 2014 | Garden
HHow do I record an answering message when I don't answer an incoming call?
Hello!!!! In order to set up the voicemail on your tracfone you can follow the instructions from this website: http://www.tracfone.com/includes/content/questions/General.jsp?enId=FA10031&esId=FA10032&a=1349428365003
Best Regards.
Karen
Customer Support
Aug 13, 2014 | Motorola Mobility TracFone w175 PayAsYouGo...
I can't Find my transmission dipe stick on a 1999 vw jetta
Best Answer - Chosen by Asker Volkswagen does not have a dipstick. The fluid level is set by attaching a computer or scanner to the car. When the fluid is at 35 degree's there should be fluid pouring out the Level adjustment hole.
Source(s):
Volkswagen Mechanic 20 years
Mar 06, 2013 | Volkswagen Cars & Trucks
Hhow to change the location of games and app to memory card in b3410
go to your settings. select app manager. a list of apps should appear. click on which app you would like to change over to your sd memory card. a new screen will appear with a "force close" option at the top along with some of the applications data and storage size information. scroll down a little ways, and BAM! you should see and option to transfer app to sd card. hope this helped!
Dec 29, 2012 | Cell Phones
I have a honeywell PA404A pressure control switch on my home gas steam heating system. I'm having a problem with the switch turning off the system. It will only come back on if I turn the top screw all the...
This may be caused by accumulation of sludge in the steam trap (the looped tube that connects the pressuretrol unit to the boiler). the sludge restricts the pressure from reaching the diaphragm in the pressuretrol unit. So it gets a false reading. Clean or replace the tube and see if normal function resumes.
Jan 06, 2009 | Heating & Cooling
My boiler most of the time don't star until I push the switch in the pressuretrol (honeywell) PA404A1033. After I activate the turn on and off regular for some hours but later again don't star until I...
Looks as if your boiler is over firing (extended run) you probably have a faulty sensing thermostatic probe causing this the switch you are resetting is a safty pressure switch it is designed to keep the pressure from building which could cause the boiler to explode.
Nov 12, 2008 | Honeywell Heating & Cooling
Television Locked.
My Durabrand DBTV1020 is locked. I dont have a manual or remote. HHow do I unlock it?
May 19, 2008 | Televison & Video
Heating & Cooling Logo
214 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
