This is my question, How many pounds of force must a man exert on one end of a 9foot lever to lift a 250 pound rock on the other end, if the fulcrum is 2feet from the rock?
  • 560 Answers
To answer your question properly , I would need to know how far the fulcrum is from the load . From there , it is a simple ratio with respect to the length of your 9ft. lever . For example : if your fulcrum is placed in the exact center (4.5 feet) of the 9ft. lever , it would require 250 pounds of effort plus the energy required to overcome gravity to lift 250lbs. of weight . Now , put the fulcrum 50% closer to the load (2.25feet) and your effort required will be 50% less , or 125lbs.
Posted on Oct 08, 2010
I need to 225 cubic feet of helium. How many pounds is that? Thanks!
The difference in the up and down force is 0.069 pounds. Therefore each cubic foot of helium could lift 0.069 pounds. In order to lift 100 pounds (which would include the weight of your load, the balloon, and the helium) you would need 1449 cubic feet of helium
Aug 23, 2017 | Office Equipment & Supplies
Need torque specs head bolts inline 6 250 77 camaro no air
start with 15 foot pounds, then 30 foot pounds, then 45 foot pounds, then finally 65 foot pounds, all the while bolting them down in a clockwise pattern working from the center out with each setting of foot pounds.
May 24, 2017 | Cars & Trucks
What does the head torque to in foot pounds
Hi 100 inch-pounds force (in lbf). to foot-pounds force (ft lbf) 8.33. Hope this helps
Oct 22, 2016 | Cars & Trucks
Torques of ring gear & pinion
Varies with manufacturers. Rings gears are around 130 foot pounds, I use locktite on these bolts. Pinion is way different. Some are 250 foot pounds. Ones with crush sleeves are measure in inch pounds. With these you are measuring the drag on the pinion gear with out the differential installed yet. Usually between 15 and 30 inch pounds. I try to set them at the lower end, that way if it ever comes apart again, the sleeve can be reused.
Apr 09, 2016 | Cars & Trucks
How much in pounds is 250 grams of chicken livers?
250 Grams X .00220462262 = .55 pounds. That is a little over half of a pound.
Mar 10, 2015 | Office Equipment & Supplies
What is the average weight for 5 foot 7 inches?
Female Ideal Weight - Above Average Height The average height of a woman in the US is 5-foot-4. When considering the weight and height ratio, a 5-foot-5 woman should weigh between 113 and 138, 5-foot-6 between 117 and 143 and 5-foot-7 between 122 and 149. The weight and height ratios continue to increase at approximately 4.5 pounds at the low end and 5.5 pounds at the high end of the range, per inch of height. A 6-foot-tall woman's ideal weight range is 144 to 176 pounds and a 7-foot-tall woman's range is 198 to 242 pounds. Male Ideal Weight -- Under 6 Feet Tall Men have an ideal weight range similar to that of women, but their weights are higher per inch. A man who is 5 feet 11 inches tall has an ideal weight range of 155 to 189 pounds, which is significantly higher than the 140- to 171-pound range for women. Men under 6 feet tall can determine their ideal weight without consulting a height-to-weight ratio table by starting at 5-foot-11 and a weight of 155 to 189 pounds. Simply subtract 5 to 6 pounds per inch from the low of 155 pounds, and 6 to 7 pounds per inch from the high of 189 pounds. Thus, a 5-foot-5 man has a range of 122 to 150 pounds and a 5-foot-tall man has an ideal weight range between 95 and 117 pounds. Are There Ideal Weight and Height Ratios LIVESTRONG COM
Jul 09, 2014 | Health & Beauty
Is air weightless?
Just because something's invisible doesn't mean it's weightless. So, no, air is not weightless.
As a matter of fact, all gases have mass, and therefore they have weight. Air, a combination of gases, is fairly heavy.
Good thing, too, ?the weight of the air around us and the force it exerts on our bodies pushes on us, and that is what keeps us from exploding. The pressure inside our bodies, in turn, keeps the air pressure from squishing us flat.
Air weighs about .07 pounds per cubic foot.
And believe it or not, each square inch of our bodies is under about 14.7 pounds of air pressure.
Feb 22, 2014 | Scientific Explorer My First Chemistry Kit
WHAT IS THE COEFFIIENT OF FRICTION?
250 kg is sitting on a horizontal surface. Hence, the ground or the horizontal surface is exerting 250 * 9.8 = 2450 N to support the crate. Now, coeff is 750/2450 = 0.306 . The force you have to exert to move crate depends on how heavy the crate is. If crate is heavy you will end up exerting more force. The ratio of the forces provide the coeff of friction.
Dec 09, 2013 | Lands Phones
I was cleaning the dust out of the feed dog area and somehow disconnected the feed dog from the lever in the back that raises it and lowers it. How can I reattache them?
A feed system for a sewing machine having a frame, a horizontal arm shaft journalled in said frame, a vertical arm shaft extending downwardly from adjacent said horizontal arm shaft, means rotatably connecting said horizontal arm shaft to said vertical arm shaft, said feed system comprising a cam fixed to said horizontal arm shaft, a sheet metal feed fork having parallel bent over portions at one end thereof embracing said cam and in driving engagement therewith, a feed rock shaft supported in said frame and having an arm connected to the other end of said feed fork, feed regulating means carried by said frame and connected to said feed fork for converting motion induced by said feed cam to oscillations of said rock shaft, said rock shaft being formed with a pair of upright rock arms on the other end thereof, a horizontally disposed U-shaped sheet metal feed dog carrier having each end thereof connected to one of said upright rock arms, said feed dog carrier having a horizontal shelf extending from the base of the U between the ends thereof, said shelf supporting thereon a feed dog, means for attaching said feed dog to said shelf, a stud affixed to said base of said feed dog carrier beneath said shelf, a sheet metal lift lever pivotally supported on a horizontal axis in said frame substantially parallel to said rock shaft, said lift lever having a slotted end for engagement with said stud extending from said feed dog carrier, said lift lever having the other end thereof supporting a cam follower adjacent said vertical cam shaft, and a lift cam removably affixed to said vertical cam shaft and in engagement with said cam follower on said lift lever.
Take care.
Oct 20, 2010 | Kenmore 19110 Computerized Sewing Machine
Looking for advice on Schwinn Midmoor bike?
I could not find a weight limit specified anywhere, but it is designated as a man's bike and that should cover up to at least 250 pounds. However, the reviews state things like flimsy, and recommended for light (500 miles a year) riding. 240 pounds will probably stress it quite a bit. You might want to look for something more sturdy. If price is a consideration try craigslist for a used electric or hybred.
Jun 30, 2010 | Schwinn Midmoor Men's Hybrid Bike
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
