Question about Frigidaire Kitchen Ranges
Ancient (1971) Frigidaire Cookmaster electric Compact 30 Range/Oven, model number RBG-533N, has two surface mounted red indicator lamps; one for the oven & one for the burners. The surface burner indicator light is now permanently on even with all burner switches in the off position. Oven indicator light works perfectly. This is the original built-in range/oven installed in our Sun City Arizona Condo. I can get all of the stainless steel trim removed to expose the indicator lamps, infinite switches and wiring. I need the wiring diagram for the surface burners and indicator lamp or someone really smart/experienced to point me in the right direction. Thank you.
    Problem Solver:
  • 6 Answers
The stove has 4 burner switches with a # 2 terminal on each switch. This contact is similiar on all four switches. One of the switches # 2 contact is stuck. The burner switch should disconnect both legs of the 240 volt circuit, one leg through the # 2 terminal and one leg through the thermostat built into the burner switch. Disconnect the pilot lamp wire on each switch unti the light goes off and then replace that burner switch. This should correct the problem
phucks001@horrycountyschools.net
Posted on Jan 25, 2011
  • akittykat Feb 15, 2011
    We just purchased a house built in 1971 from the origenal owners. It has the RBG-533N. It is weird cooking on coil burners and having coils in the oven. I'm use to having a flat top with a conventinal oven. I hate to admit to it but the oven works better then a coventinal oven. It might be a awful looking split pea green and old looking it compared to todays ranges. I'm hoping it might be worth some money. All the cooking alements work even the clock/timer work. In good shape for being 40 years old.
Frigidaire Oven surface light stays ''on'' even when cooktop off
I unplugged the stove, un plugged all the burners cleaned them, put them back on plugged the stove back in and the light went out, something to do with unplugging it I think. reset it or something.
May 10, 2010 | Frigidaire FEF326 Electric Kitchen Range
Range indicator light doesn't shut off
the poles for the light are reversed or miswired
at the selector switch
make sure the light goes back to p1 or p depending on your switch
Oct 09, 2009 | Kitchen Ranges
Need to know if the burners come out of my stove
Hi, The burners should pull up and out. They plug into a receptical and should release fairly easy.
While you have the burners out, check the ends and see if there is any sign that they have been burning/arking. Thet should be clean before putting them back in. I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Replacement knob
imsert your model number here, you can download a complete parts manual
http://www.frigidaire.com/support/manuals.asp
Jan 15, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Compact 30 Frigidaire Model rbe539n range/oven. I am looking for the switch to turn on oven light.
Be sure the timer (right most knob) is set back to MAN (manual) after cleaning in order for the oven to work.
Jan 14, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Inquiry on parts for ancient Frigidaire Cookmaster
Try www.monitortop,com and send email
Jan 01, 2008 | Ovens
Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Dec 13, 2007 | Frigidaire FES367 Electric Kitchen Range
Kitchen Ranges Logo
1,214 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
