Question about CorelDraw 9 Office Edition (   90oeengo)
Thank you for your response
Unfortantly I do not have the disk no more. So is it possible to reinstall from the hard drive after uninstalling
with out lossing the program ofcourse ,,..
    Guru:
  • 859 Answers
Hello, I am out of town today and will respond to you upon my return.
Regards,
Worldvet
Posted on May 29, 2008
  • Glenn Rogers
    Glenn Rogers May 30, 2008
    Yes, there 'may' be a chance. Go to Control Panel, Add/Remove and then click on the program. If you're lucky it will offer to repair the installation. If the temporary install files are still on your PC then you'll be fine. If not, Corel does offer a disc replacement program. You'll asked to support your request with some explanation. Just don't tell them your dog got a hold of your disc. Say you lost it in a move/divorce, etc. anything plausible and if at all possible the truth as they actually use, believe it or not, truth meters on their phone lines that measure stress in your voice. Kind of sounds like SciFi, but sadly true based on all the fake calls they get.
    Good Luck,
    Worldvet
  • Glenn Rogers
    In the US you can only contact Corel via online at
    if you are in another location check that number from here
    this link
Hard disk USB does not connect
Have you tried reinstalling the drivers? Go into hardware and uninstall ththe device there then reinstal it again, drivers and all. Thats the first thing I would do...
Jul 05, 2012 | Freecom FHD 1 120 GB USB 20 Hard Drive
Im not completely dense i just need step by step instruction on how to remove the harddrive and reinstall another for my acer aspire3004wlci and the only difference is the original 60 the new one is an 80
I don't have a diagram for you but flip it over, remove the screws on the hard drive cover, carefully remove the disk, remove the adapter from the disk and install it on the new one, reverse.
That should do it. It is not hard. Recognize you will have a "blank" disk and will need to reload everything.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 27, 2011 | Computers & Internet
My external hard drive (buffalo HD-PE320U2) is not working. when I plug it on the computer it says "windows does not recognize it" or it has malfunction. what will I do with it?please help I...
First uninstall the software,make sure the external hard drive is not connected to the PC and use your install disk to reinstall the software.You might all so try system restore.Thank you for choosing FixYa.com.
May 18, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
May hard disk doesn't response it says error message then when I tried to run system recovery it doesn't work too. But I'll go to windows but no display then I'll try to run hard disk self test drive the...
> hard-disk self-test drive the result is 0-7 FAILED
It's time to purchase a replacement disk-drive, and then to install Windows Vista onto it, and then connect the "old" drive as a 'SLAVE' disk-drive, to see if you can copy any files onto the "new" disk-drive.
Dec 24, 2010 | Microsoft Windows Vista Ultimate Edition
I am trying to install a WD3200BEVE hard drive into a Dell Inspiron 6000 and it reads "Internal HDD Error" I received this hard drive from Dell after my previous hard drive WD600 went bad. Do I...
It's possible that the only problem is that the replacement disk-drive needs to be "initialized" for first-time usage. Or, it's possible that your Dell won't support your new _larger_ disk-drive.
Did they send you a disk-drive with _greater_ capacity than your old 60GB drive?
It's possible that they "upgraded" you, because they had no (small) 60GB disk-drives in inventory.
Take your Dell "System Restore" set of CD/DVD disks, and reinstall Windows.
The Windows Installer will "initialize" your disk-drive.
Dec 18, 2010 | Western Digital Scorpio WD600VE 60 GB Hard...
Dropped my external hard drive
danielhighto
Unfortantly if you dropped the drive then most likely you killed the drive because it messed up the read system in the drive. Now the case its self should be fine so you might keep it in case you ever need an extra drive encloser.
Sorry for the bad news
Issken
Jan 14, 2010 | Computers & Internet
My hitachi hard drive is not working when i do plug it wid my pc but its working wid other pcs so what cud be the prob. my pen drives are working wid pc that mean usb ports are not the problem. plz help
it is quite possible that there is a mistake somewhere in your drivers. the best wold be to reinstall all MB drivers, but if you can't do that, at least uninstall DISK DRIVERS from computer management and reinstall it
this might fix your problem
Nov 14, 2009 | Computers & Internet
Can someone help with a error code 13 for my iphone...I have uninstalled itunes restarted computer installed itunes..went to restore phone now i have code 13 again
hi..The reason to this problem could be a hardware failure
causing the hard drive not to boot properly or the software
needs to be reinstalled again.
check it out..
thank u..
kindly rate my response..
May 14, 2009 | Apple Cell Phones
Crashed hard drive on emachines T5026
Pardon me, but NO! The statement, "two things are responsible for booting up computer RAM and Hard Drive" is simply not true.
A hard drive crash COULD cause the symptoms you describe, but that is more indicative of a virus infection. When you say the XP reinstallation disk would not start it exactly how did you use that disk? Attempt to use the repair console? Boot directly from the disk? Attempt reinstallation of the whole operating system? If you attempted reinstallation, do you also have the specific drivers for all of the components E-Machines used when they built your computer (you will need at least some of them.)
Post again with some more details about how you used the reinstallation disk.
Feb 24, 2009 | E-Machines eMachines Desktop PC
Lenovo T61error 2100: HDD0(hard disk drive)
To all users with: lenovo T61error 2100: HDD0(hard disk drive),
Possible cause:
  1. Corrupted hard disk logical sectror/hard disk logical error (bad format).
  2. Hard disk connector not well in place.
  3. Hard disk broken, physical fault.
Solutions:
  1. Format hard disk and reinstall system using a Windows setup CD.
  2. If that does not work the Hard disk must be removed to check thge connector, and to test the hard disk on a different computer.
  3. If the hard disk is bad , it must be replaced, and windows reinstalled repeating step one.
Nov 25, 2008 | Lenovo ThinkPad T61 Notebook
CorelDraw 9 Office Edition (   90oeengo) Logo
Top Corel Computers & Internet Experts
photoshop serial
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
