Question about Microsoft Windows XP Home Edition
Why should i get "fata error during uninstall the java 1.6"in windows xp platform
    President:
  • 2,291 Answers
Hey i think u need a deep clean of ur system registry use reginout it will help u
Posted on Oct 08, 2010
My hp deskjet 2050 output tray open error
fata error during installation in hp deskjet 2050 printer
hp printer not uninstalled .
how to uninstall driver hp deskjet 2050
Jun 07, 2013 | HP Deskjet 2050 All-in-One Printer
Hi I am Farah, and as I wanted to download java , it came thet" " is not valid win 32 application'. What shoudl I do? Thx
It is possible that you are attempting to install a 64-bit version of Java when you have a 32-bit operating system. Check your operating and confirm this. In Vista you can find this using Start > Control Panel > System. This is similar if you have Windows 7. Here is what it looks like:
If after that you, you follow these instructions from Sun (Java) to locate and install the 32-bit version.
Error: x64.exe not a valid Win32 application This article applies to:
  • Platform(s): Windows 7, Vista, Windows XP, Windows 2000, Windows 2003
  • Browser(s): Internet Explorer, Firefox, Mozilla 1.4+
  • Java version(s): 6.0
SYMPTOMS
While trying to install Java a user gets an error message similar to:
' ... x64.exe not a valid Win32 application'
CAUSE
The error message is a result of trying to install a 64-bit version of Java on a 32-bit operating system.
SOLUTION
User needs to install a 32-bit version of Java software, since a 64-bit version is not compatible with their 32-bit operating system.
Follow these steps to download 32-bit Java
  1. Go to Manual download
  2. Click Windows XP/Vista/2000/2003/2008 Online.
  3. The File Download dialog box appears.
  4. Choose the folder location.
  5. (Save the file to a known location on your computer, for example, to your desktop).
  6. Click Save.
  7. Close all applications including the browser.
  8. Double-click on the saved file icon to start the installation process.
Nov 07, 2010 | Computers & Internet
When I try to open my MP3Rocket I get the following error: ''Unable to access jarfile libMP3Rocket.jar''. Can you please advise me? Thanks
1. Open Default Programs by clicking the Start button, and then clicking Default Programs.
2. On choose the programs that windows uses by default, Select “Associate a file type or protocol with a program > Click on the extension (.jar) to view the program that opens it by default.
3. Click change the program and select the default program JAVA virtual machine launcher
4. Click close.
Change-which-programs-Windows-uses-by-default
http://windows.microsoft.com/en-US/windows-vista/Change-which-programs-Windows-uses-by-default
Now check if the issue is resolved
If the issue persists, you may want to uninstall and reinstall JAVA.
How do I uninstall Java on my Windows computer? http://www.java.com/en/download/help/uninstall_java.xml
How do I manually download and install Java for my Windows computer? http://java.com/en/download/help/windows_manual_download.xml
If the issue still persists, you may want to check with MP3 rocket for any known issues
http://www.mp3rocket.com/support/
May 03, 2010 | Microsoft Windows XP Professional for PC
Why showing fatal errors during uninstalling java
go into Control Panel\Add/Remove Programs and scroll down to remove Java from my system. I click remove and it comes up with the window "Add or Remove Programs: Are you sure you want to remove Java(TM) 6 Update 13 from your computer".
I click yes and it says "Preparing to remove"
then configuring java.. and then come up with the window:"Fatal Error During Installation"
I've tried enabling logging.. it didn't work.. so that's all the info I can give, I have two HD's mounted.. if that helps.. I don't know. I tried using the install again.. it didn't work believe it or not s9.gif. Anyway please help
Mar 13, 2010 | ArcMedia JavaScript Source Code 3000 Pro...
Java installation problem
How can you reinstall and install the java software if it does'nt exist in your system,right? Read the information below which I researched for you. This addresses you in your problem. Don't forget to rate me..:-) Thanks..
Error: 25099 during Java installation This article applies to:
  • Platform(s): Windows 2000 , Windows XP , Vista , Windows 2003
  • Browser(s): All Browsers
  • Java version(s): 6.0 , 6u10+
SYMPTOMS
While Java installation is in progress, a message box with the following error is displayed:
Error 25099. Unzipping core files failed.
CAUSE
The actual root cause of this issue is still under investigation. Error 25099 indicates that the Java installation process has failed.
WORKAROUND
Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
Step 4 : Download and install Java.
  1. Go to Java.com
  2. Click on the Free Java Download button, and start the installation process.
Nov 08, 2009 | Computers & Internet
Hi tryed to download javameantime, error code 25099 connot unzipp core files, how do i corect the problem,
WORKAROUND
  1. Go to Java.com
Sep 17, 2009 | Microsoft Windows XP Professional With...
Java(TM) Platform SE Binary has stopped working.
I had the same problems and found that the new driver i had upgraded to for my NVidia card was the culprit. I rolled it back and my problem was fixed. Hope this helps.
Sep 03, 2009 | Acer Aspire 5735 Notebook
Fatal error during java installation uninstall
go into Control PanelAdd/Remove Programs and scroll down to remove Java from my system. I click remove and it comes up with the window "Add or Remove Programs: Are you sure you want to remove Java(TM) 6 Update 13 from your computer".
Jul 01, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Using WINDOWS VISTA. how to fix it
When are you getting this error?
are you getting the error when you log on or when opening any particular software..
Moreever the error seems to be thrown by Java.. Better reinstall java on your computer
To uninstall Java ->Start -> Type" Programs and features" on the start search and open it -> remove Java from there
Then open Internet Explorer -> Tools -> Internet Options -> click settings on Browsing history -> view objects
remove java from there. Reboot the computer once.
NOw logon to http://www.java.com to install java on your computer..
Jun 19, 2008 | Microsoft Windows XP Professional for PC
Java (TM) Plug-in fatal error
To view this page curectly intall java virtual machine pc destop of window xp operative system.
Mar 16, 2008 | Dell Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
