Question about Microwave Ovens
Whirlpool Over the Range Microwave Hood Combination, model MH7140XFQ, Serial XC H 51 40739. Has a loud hum, then shuts down in about one second. Started doing this following an electrical storm that also took out the clothes dryer (was only a fuse). Suspect that the HV diode is bad, as it reads 28-ohms in both directions. Replaced that with a new one today, part #W10163432, still does the same thing. The new diode had infinity resistance in both directions (???). Did I get a bad one??? HV capacitor seems OK, does what a capacitor is supposed to do. Magnetron reads infinity resistance across the two leads. HV transformer has what seems to be normal readings: 0.6 ohms across the primary windings, 90 ohms across the yellow/ground terminals, about 0.1 ohms across the orange leads; no shorts between any transformer leads. The HV diode is still my suspicious part. 2nd question: Is this unit covered by the recall? Manufacture date is December, 1998.
  • 1 more comment
  • ricksteimel Oct 08, 2010
    Would it be worth the extra expense (about $10) to go get another diode, since the one I bought today doesn't act like a diode at all--I believe a properly working diode should show about zero ohms resistance in one direction, and infinity in the other. I can't return the one I bought today, as the purchase clearly shows that electronic components cannot be returned once they leave the store. The one I bought today says "made in China" (?). If I decide to buy another one, it will be from a different store. Also, any idea on how much a replacement magnetron might cost?
    Appreciate the fast response and "professional" assurance that I am on the right track to get the unit repaired and back in service.
  • ricksteimel Oct 10, 2010
    Hi again, Rylee, the microwave is fixed and working fine. I did some "fine tuning" on whether or not the diode that I bought was bad...found a website that described why some resistance readings might seem to be problemsome, re-tested both the shorted one and the replacement that I bought, found that the replacement was actually good, it was simply a problem with my trying to get accurate readings without using a surefire circuit to check its operation. Also, I did buy a new magnetron for about $70, it was on hand so I did not have to order it out. Installation took about an hour due to the intensity of getting into the heart of things and then having to come back out once the new one was installed, all is well now. Thanks again for your advice.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If it's a loud hum/buzz sound then 90% it's usually a bad magnetron and other times it's a bad high voltage diode. However, from what you have described it seems to be the magnetron. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 08, 2010
  • Rylee Smith
    Rylee Smith Oct 08, 2010
    If you think that the part# that you bought is no good then yes it'll be worth a try to replace it with new one. Magnetron will cost you around $53 and you can buy it from this link. Please accept the solution if the issue is resolved or post a comment for further assistance.
    Rylee
  • Rylee Smith
    Rylee Smith Oct 10, 2010
    Good to hear that its fixed. Please let me know if you need further assistance.
    Rylee
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
M/n 665 6868 1891 Blew fuse, has F6 code in display and just hums when closing door.
Its well past what I would consider normal age for repair--some parts will not be available and frankly a lot of them the price for has also gone way down since 1998---you may if it is even possible to fix it be better to buy a new unit instead.
Dec 10, 2012 | Kenmore Microwave Ovens
I have a Whirlpool MH7140XFQ-0 Microwave and last night it stopped working with the screen showing F6. I unplugged it for over an hour and plugged it back in and it went right to F6. It tries to run if the...
"F6" on a Whirlpool microwave means you have a shorted cook relay on the control circuit board.
For model MH7140XFQ0 the control circuit board would be part number 4393919, which you can order from the Pros here for $132.23.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) take out the old board, then move the new circuit board into your frame.
Some connectors on the relays may have a lock:
Otherwise, we regularly repair these boards with our $39.95 nationwide service. Details are here.
Jan 23, 2011 | Whirlpool MH1140XMS Microwave Oven
Whirlpool over the range microwave model #gh4155xpt-0 serial # trr4413897 Microwave make loud noise and will not heat.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Aug 18, 2010 | Whirlpool Microwave Ovens
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Broken vent grille for a Whirlpool microwave hood combination
At our Web site, we have a video available showing how to remove a typical grille in seconds.
Jun 06, 2009 | Whirlpool GH8155XJ Microwave Oven
Whirlpool MH7140XFQ-1 microwave no longer heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
