N15235 win fast motherboard
We have upgraded three HP units with the above M/B, this last unit is causing a problem, there is no post and will not boot up. The fan spins for a few seconds then stops. Any ideas please.
Merlin
  • naivasha Mar 26, 2009
    My system is an acerpower s290. As of this morning,the system won't boot and has no POST. The processor fan spins for a few seconds and stops. Please help.
    Jack
Found the problem, it was in fact a faulty mother board. Have returned it to the supplier and was exchanged without problem.
Thanks for your reply,
Merlin
Posted on Jun 12, 2008
  • 55 Answers
The main cause behind this problem is :-
1) RAM JAM
2) HDD is taking extra power from SMPS
3) Motherboard faulty Capacitors / ICs
Try following :0-
step 1) Remove CMOS Battery (3V battery) + RAM
and now try to check whether Fan shows same symptoms or not
Step 2) if results of above step is fail then try to remove HDD powersuppy + CD/DVD power supply + Floppy Power supply (in short provide power to only motherboard) and now start the system.
If the result are same
3) then look for any swollen capacitors on motherboard, if they are then you need to replace them.
4) If no capacitor is swollen then check for every bigger IC on motherboard for whether it got excessive heated or not. If yes then you need to do serious operations on your motherboard .
Please not here i have used the word EXCESSIVE HEATED. and noth the normal heated
Posted on May 30, 2008
Xw6400workstation hp changed motherboard still4bleeps pc wont start
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in. Open computer and reseat memory Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST, disconnect the riser board(if applicable) and each of theexpansion cards. If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue. Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA, SCSI, or other data cables from theCD-ROM, Hard Drive, and floppy drive from theMotherboard. If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue. Remove the RAM If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. ' Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue. Re-insert the memory into the same slot. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick. Try one stick of memory in each slot. If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify what stick of memory is bad and replace it. If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard. Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot. This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware. Disconnect and reconnect the CPU (central processing unit) For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer. Bad motherboard, CPU, RAM, or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard , PSU ( power supply unit ), CPU, or RAM. The next step would be either to replace these components or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers.
Feb 17, 2013 | HP dc Computers & Internet
I need a win fast n15235 sound driver for windows 7
There are many free sites on the web that you can download this driver from; most want you to download their driver update program so you need to make a choice whether you want to do this. Difficult to find a site where you can download drivers for free other than the manufacturer's site for your sound card.
Try this site:
http://members.driverguide.com/driver_search.php?q=Winfast+Leadtek+Research+n15235&si=54f008106055f69d81f42de682a289d8&st=1293091176&gqm0=Winfast+Leadtek+Research+n15235
Dec 23, 2010 | Computers & Internet
Drivers
for drivers on M/B FOXCONN N15235 all dirvers go to www.quebex.com, also will include the direct link, and click on model APOLO_48XX and have fun downloading all needed drivers...
http://www.qbex.com/website/downloads.php?osCsid=83c184775bfaf6771df03e7fc3bdb41a
Jun 17, 2009 | Computers & Internet
Foxconn n15235 mobo will not post nd gives long beep
i think your motherboard is your problem... check your motherboard to other systems.
Apr 15, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Cheats of age of empire1
Age of Empires Exceed Population Limit
If you need more units, but the population limit stops you, try this. Bring your population to 1 unit beneath the population limit. Now, make sure you have lots of resources, enough to build several units.Next, go to all the buildings that can produce units, and QUICKLY click on the icon that makes the unit. Do this on every building as fast as you can, but you can only continue until a unit is completed, thus bringing your population to it's limit. HOWEVER, the game will complete all the units you started! With this, going fast enough, you, will be able to exceed your limit by about 10 units.
Age of Empires Cheat Codes - Demo
To activate a cheat, push [Enter] and type in its corresponding code below.
Cheat Codes 1000 gold COINAGE 1000 food PEPPERONI PIZZA 1000 stone QUARRY 1000 wood WOODSTOCK Control animals, not men GAIA Full map REVEAL MAP Lose campaign RESIGN Slay all opponents DIEDIEDIE Slay select opponent* KILL <1 - 8> Soldier wields nuclear weapons GIVEMEFISSIONMAN Upgrade all units** STEROIDS Remove Fog of War NO FOG Win campaign VICTORY * Enter a value within indicated parameters. ** Effects opponent as well.
Age of Empires Cheat Codes - Shortcut Keys
To activate a cheat, enter its corresponding hotkey below.
Cheat Hotkey Build immutable structure [Ctrl] + P New resource menu [Ctrl] + T Speed construction [Ctrl] + Q View ending [Ctrl] + C
Age of Empires Catapults fire on Peasants
To fire on civilians, highlight a catapult and press [Enter]. Then type: JACK BE NIMBLE. Depending upon its orientation, catapults target different members of the populace.
Direction Target East peasants North cattle South peasants West Superman
Age of Empires Cheat List
Hit Enter before typing these cheats
  • Upgrade heavy catapults: BIG BERTHA
  • Upgrade all units: STEROIDS (Effects opponent as well).
  • Upgrade ballistas (range=100): ICBM
  • Win campaign: HOME RUN
  • Full map: REVEAL MAP
  • Invincible army: ZEUS
Mar 26, 2009 | Microsoft Age of Empires: The Rise of Rome...
I HAVE fOXCONN N15235 MOTHERBORD
Hi.I am Adrian.I need drivers for win.xp
Sep 19, 2008 | Foxconn 6627MA-RS2H Motherboard
Drivers placa base Foxconn N15235
Foxconn drivers can be found at this webpage: Driver Update Software for XP Vista 7 8. Use their software to update all of your drivers.
Wish you best of luck
Hans
Sep 09, 2008 | Foxconn 6627MA-RS2H Motherboard
Computers & Internet Logo
1,877 people viewed this question
David Payne
David Payne
