Question about E-Machines W3107 (RBW3107) PC Desktop
My dvd driver makes a loud noise when disc is inserted. would like to replce the driver ..what is a compatible brand to replce this drive ?Maybe samsung?
    Master:
  • 388 Answers
Any will do you just need to know if it is a sata or ide if its has a ribbon belt pluged into the back of it its normaly grey in colour and two or thee inch in width if it doesnt have this conector it a sata.
Posted on Oct 08, 2010
The disc drive on my acer Aspire 5742G will not read any music cd's or dvds. I makes plenty of noise as though it is trying to open it but nothing!
The CD/DVD drive may need reseating to make proper electrical connection. Remove this drive and insert it back into the laptop.
Next try cleanibg the drive.
The laser lens maybe dirty, use a CD/DVD lens cleaning kit to clean the lens int the drive.
If this does not fix your problem then the CD/DVD drive is faulty and needs to be replaced.
Apr 01, 2012 | Acer Aspire 5742G
My dell insptron 1545 wil not recognise my DVD drive how can I repair this ? I am unable to burn dvd's as even when i insert a brand new dvd I am told that I do not have a writable cd in the drive...
Hi There
DVD drive sometime it is not working simply because maybe the disc you insert is not compatible for the DVD drive you have or the disc you put is really cannot be rad by your DVD drive, best thing to is check and try few discs and observe your dvd drive, sometimes the lens is faulty or sometimes the module of the lens is not moving forward and backward. this is the most case i encountered. you can replace your dvd drive by replacing it by the new one. it is not very costly.
It is better to replace than to repair it, repair might be last only for a weeks while new is sure to work more than that.
thanks
Apr 11, 2011 | Dell Inspiron 1545 Notebook
Dvd/cd is not working
You can follow these methods to try to isolate and resolve the problem. Use these methods in the order in which they are presented.
Method 1: Clean the disc
When you have problems with a CD or DVD drive, always check the disc first to see whether it is damaged or dirty. To clean the disc, follow these steps:
1. Remove the disc from the drive.
2. Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth.
Note Do not use a paper cloth, and do not use a circular motion to clean the disc. These can scratch the disc.
3. Reinsert the disc in the CD or DVD drive.
If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to step 4.
4. Try again to clean the disc by using a cloth dampened with water, or dampened with a commercial CD or DVD cleaning solution.
5. Dry the disc thoroughly, and then reinsert it in the CD or DVD drive.
6. If the computer can read the disc, you are finished.
If the computer still cannot read the disc, go to method 2.
Method 2: Check the disc for damage
If the disc is clean, check whether it is damaged. To do this, follow these steps:
1. Remove the disc from the drive, and then examine the disc for scratches or cracks.
2. If the disc is damaged, try another disc to see whether the CD or DVD drive can read it.
3. If the computer still cannot read a disc, there may be a problem with the drive. Go to method 3 to troubleshoot the CD or DVD drive.
If the computer can read the other disc, there is a problem with original CD or DVD. Contact the manufacturer of the damaged disc to obtain a replacement.
Method 3: Try a different disc drive
If the disc is clean and undamaged, check whether there is a problem with the drive. To do this, follow these steps:
1. If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc.
If your computer does not have more than one disc drive, you can insert the disc in a different computer.
2. If the other CD or DVD drive can read the disc, there may be a problem with your CD or DVD drive. Go to method 5.
If the other CD or DVD drive cannot read the disc, the disc may not be compatible with the drive. Go to method 4.
Method 4: Make sure that the disc is compatible with the drive
Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
* A DVD disc is incompatible with a standard CD drive.
* A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
* A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
If the disc is compatible, go to method 5.
If the disc is incompatible, use a compatible disc or contact the vendor for a compatible replacement.
Method 5: Use Windows Update to check for updated drivers
If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing.
Good luck
Jan 21, 2011 | Computers & Internet
I have two sony laptops, vgn-n31 and vgn-fs515h. vgn-n31 dvd/cd drive developed a fault when i removed it. so i thought i would replace the drive with that from my other laptop ( which is completely...
Hi. Check the transport mechanism of the laser head. The transport can get stuck with dust, hair or vibration. If the transport is stuck, the drive still appear but can't read the CD because the lens is not moving properly.
Clean the area around the lens with cotton buds (be careful not to scratch the lens). Move the lens mechanism away from the center (use a plastic paper clip, slide gently). Place a DVD/CD disc and reboot your laptop. The DVD will auto align the drive during boot-up.
Good luck.
Sep 02, 2010 | Sony VAIO Laptop
I have a HPdv4t laptop with the optiarc dvd rw ad-7560s ata device (firmware: SH03). It doesn't read dvd like it used to. It reads a dvd disc with lots of noise coming out of it n takes even hours to open...
This issue occurs due to corrupt registry settings.
Run Microsoft Fix it to remove drive limits. You can find the fix in the HP website provided below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00678214&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3745839
Also reinstall the CD/DVD drive drivers from device manager. If the drive still makes loud noise when any disc is inserted, then it states that it has gone bad. If u r under warranty contact HP to get a free replacement.
Jan 22, 2010 | HP Pavilion dv4t PC Notebook
My laptop cd burner isn't burning music I downloaded anymore. Everytime I insert disc, made for music, it makes a weird noise says that a disc needs to be inserted (one is already in there) and the tray...
Go to "computer" and right click the drive,Then "properties"then "Hardware"then pick your drive,Then "properties"again,Then click"drivers"then "uninstall" and "OK".After uninstalling the drivers for that drive you need to Reboot,Windows will automatically reinstall and repair the drivers.If after all this work it still refuses to work it maybe a hardware issue,the drive could be bad.Sorry,.............
Jan 17, 2010 | Acer (SCB5265) Burner
Drive can not read CDs..read Dvds
I suppose that you have windows XP. Pls follow these steps Clean the disc - Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth. Check the disc for damage - Remove the disc from the drive, and then examine the disc for scratches or cracks. Try a different disc drive - If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc. If your computer does not have more than one disc drive, you can insert the disc in a different computer. Make sure that the disc is compatible with the drive -Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
  • A DVD disc is incompatible with a standard CD drive.
  • A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
  • A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
Use Windows Update to check for updated drivers - If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing. To check for driver updates that you can install, visit the following Microsoft Web site: http://windowsupdate.microsoft.comRegards
Jun 18, 2009 | Computers & Internet
NEC DVD-RW 16x DL
If you switched to a different brand of DVD's try using the brand you used before. DVD burners are tested with certain brands of DVD's and sometimes the brands that aren't on that list don't work.
Jun 11, 2006 | NEC 16X Multiple Format DVD+/-R/RW/DL...
E-Machines W3107 (RBW3107) PC Desktop Logo
55 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
