Question about Whirlpool Refrigerators
Whirlpool ED2FHAXSB It makes ice but doesn't dispense ice. Every other part of the fridge works fine. Lights light, water dispenser works OK, the temp is OK, I don't see any fuses or anything else that might be wrong. Also, cleaning the fins underneath is strange. They seem to run side to side rather than back to front. There is little access to clean this part of the fridge. How do I effectively clean these fins?
  • dgustafs Oct 08, 2010
    My fridge was purchased in 1997.
    It is model # ED2FHAXSB, a side-by-side with water and an ice crusher in the door.
    The ice crusher does not run. It happened suddenly right after a power outage. The rest of the fridge works just fine. The lights light and the temperature is OK.
    What may be causing this?
    Also, the cooling fins run side to side rather than front to back. How can I access these to clean the fins? (I know you have to take off the plastic louvers in the front.)
    Thanks for taking a shot at this.
    President:
  • 1,796 Answers
Hi!
Make sure Ice is not stuck in the delivery chute. Use a plastic utensil to clear the delivery chute. Check for and remove the temporary shield from underneath the ice storage bin. Make sure ice is not stuck together, if so, dump ice and wait for new ice to be made.
Good Luck!! Keep me posted!!
Posted on Oct 08, 2010
    President:
  • 2,777 Answers
Strange, so the coil that pushes the ice out works, you can hear it moving but it doesn't move any of the ice out?
Tim
Model #WSF26C2EXY02. Why is ice maker not making ice?
When the ice-tray is full it pushes 'UP' a lever that shuts the water supply off. When you move the lever down all goes back to normal.
Oct 14, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator WSF26C2EXF01 water dispenser not working
This sounds like the water inlet valve has gone bad.. First before u replace it check to see that you have water coming to back of fridge as it could be restricted causing no water to reach the fridge.
Apr 04, 2014 | Whirlpool Refrigerators
The water isnt getting thru to the icemaker, i have used a hairdryer on the water valve and still nothing , i even changed out the water valve but alas no water is being pumped thru to the icemaker, what...
Does water dispense through the dispenser ok in the door dispenser??
If yes wate r dispenses through the door ok the problem is going to be with the icemaker itself and its not sending power to the water valve when its supposed to fill so it could make the ice
If water doesnt dispense through the door check that water pressure into valve is sufficent..even if water does dispense what seems to be ok check first that thier is good water pressure into the valve before replacing icemaker
GENE
Sep 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
Ice and Water Dispenser Quit Working
I am having the same problem. Were you able to get it fixed?
Jun 16, 2008 | Refrigerators
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
