My vcr keeps burning out fuses on the power supply. I took it apart and nothing looks bad
SOURCE: tv won't tern on
dont know how to tern on a tv, I do know how to TURN on a TV though...
Posted on Jul 27, 2007
  • 62 Answers
SOURCE: power supply
Call 800-726-4405 - But the part may not be available - request an exchange through the manufacturer. By law the manufacturer must provide parts for 5 years.
Posted on Mar 29, 2008
SOURCE: TV will not power on
The MZ73L is a posistor, its basically 2 thermal resistors back to back. One is connected across the mains, the other one connects the deguassing loop to the mains. When the TV is 1st turned on the mains connected R is cold so its neighbour is cold, that allows a large surge of current into the degaussing coil. The mains connected one rapidly gets hot and heats up the other one, this increases the resistance of it and the current being dumped into the degauss coil fades away. As the 1st one is a heater it will get hot and you will see signs of heat on the PCB, BUT its still a very good place to start. The heat is normal, but if the 1st ceramic disk in it has died then you will short the mains and blow the fuse with it.
Posted on Apr 20, 2008
Mike Adams
  • 19 Answers
SOURCE: RCA DVD/VCR model DRC8320
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Posted on Nov 26, 2008
Mike Adams
  • 19 Answers
SOURCE: Dead power supply.
Interface error
(and or)
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Posted on Nov 27, 2008
TV will not turn on, 3.15amp fuse keeps blowing on power board
I have an ln40b630n1fxa and my fuses keep going out as well i took it all apart and seen nothing blown. What would be my next step
Nov 06, 2012 | Samsung LN40B630 40 in. LCD TV
Computer not powering up
bad power supply. just replace
Jun 07, 2012 | Computers & Internet
No power on my JVC Kaboom
I would rule out the power supply simply because the batteries won't run it either. The internal plug that takes the cord should be checked for cracked solder joints, because the plug goes to battery mode when cord is removed and AC fuction when cord is plugged in. It is possible it may be an audio output problem given the age of the item.
Feb 12, 2012 | JVC KABOOM RV-NB10 Boombox
I turned on my tv this morning and it started smoking and of course smelling like something inside was burning. We took off the back and can see nothing that looks burnt or melted but the tv still wont...
hi,
may be ur tvs lamp side have some problem. may be the lamp over heated and burned. just open its lamp cover ann check it.
also check its power supply input point(near fuse) there is an MOV (used for voltage surge protection) is burned or not. if there is any voltage surge it will get shorted and the fuse will blow off, protect the power supply for any further damage. check the fuse also. if found open then check the MOV. insert fuse only after replacing the MOV.
ok
Dec 22, 2010 | Samsung HL-S5087W DLP TV
I have no power to the unit. I took off the cover and nothing is moving. Fan twitches but does not spin. No lights or response from anything else.
Hello StretchGT hi, you have power supply problems, check first the fuse, that the only thing you can do. Locate the Power Supply section (usually with big capacitors and transformer., Smell for burned parts? Well if its a fuzz for you, buy a new DVD its cheap nowadays, cyberdyers_1.jpg
Dec 07, 2010 | Samsung DVD-VR330 VCR and DVD Recorder
Nothing works in the car. lights, windows, horn,
Hello Ricard.
You have blown a fuse that supplies power to most of your car.
I would suspect the one you are searching for will be in the trunk near your battery in the battery junction box.
Look for one that may be discolored and replace it.
If it isn't immediately apparent which one it is you may need to look at each one carefully to see a burned copper colored link at the top of the fuse. They can be tricky to find as they sometimes do not look bad.
I will in some situations switch the same rated fuse for another and see if it makes a system work.
If you need more advise or help please leave them in "add comments" and I will check for your message.
KL
Dec 29, 2009 | 2002 Lincoln LS
Gateway mfatxnin nmz 300s no power opened power supply box lloking for a blown fuse or something?
sometimes they just die the windings burn out in hidden spots and trust me i took 1 apart to find the burn it's not worth the time just to have a look
spend the cash and buy a universal adapter
just rember voltage and amp or mily amps required
Jul 23, 2009 | Computers & Internet
PS2 Power problem
Check the power supply.Use a multimeter if you have any voltage coming out from the power supply.
If the power supply is good Check the main fuse on the motherboard.There is a white ceramic fuse on the motherboard and sometimes get Bad.
Good Luck
Jun 05, 2008 | Sony PlayStation 2 Slimline Console
19 people viewed this question
 Grubhead
Grubhead
