Question about Tomtom GO 700 GPS Receiver
NOTHING HAPPENS It's off and resetting (bent paper clip) doesn't bring it back. It is charged, the green light upper left of screen is on when plugged into house current. Goes out when unplugged. Blank unlighted screen. Will not respond as in the past. It did possibly get hot but not "that" hot. What to do?
  • Anonymous May 31, 2008
    blank screen when put on charged does not turn on but some time the screen lights in flash's and it warmed up ,smells
    President:
  • 4,402 Answers
Posted on Jun 11, 2008
My sony nwz e444 simply stopped working. As I took it out of my bag i obviously pressed a button, and the screen switched on, I plugged the charging cable into the device, the screen went black, then when...
Try to connect it again to your computer and while it is connected. Press the reset button on the mp3 player using a paper-clip. It should do the trick.
Sep 29, 2010 | Audio Players & Recorders
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Low Battery, Connected car charger, now is dead
May be the battery won't have charge, keep 1 or 2 hrs continues charges, and if it is not working then you have to replace the battery set full.
Jul 04, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
My tomtom go 910 will not switch on it has the green light on at the top left when plugged into a charger but nothing turns on when pressing button for 2 seconds any ideas??
In general I find these sort of problems can be fixed by the below
If the Tomtom loses battery power it might cease to function with a blank screen but will show a green light when you charge it. The trick is charge it on the mains charger for at least two hours. Then reset the device with a paper clip. If you get no reponse hold down the on button for at least 20 secs and the device will show the Tomtom logo and play a drum roll and startup normally.
Sep 03, 2008 | Tomtom GO 910
Seeking the repair of my tomtom Go 910
One suggestion is to plug the Tom Tom using the temporary power cord to you home circuit (not the power source from the car). That worked for me. Sometime the Tom Tom shuts down when left in the hot car requiring a reset. Then the best way is to plug in at home and restart. Try it, otherwise I can't help.
Jim
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
My tomtom 510 was working fine until this morning when I set it in it's windshield dock. The green light to show that it's charging came on but nothing else. It's been on the charger all day but won't...
Remove the docking foot from the unit and expose the docking connectors. The reset button is at the bottom left of the body next to the connectors. It's hard to see but a paper clip will do the trick. Push just hard enough to here it click. Now it is reset.
Jun 25, 2008 | GPS
Unit will not come on green light is on and is docked to computer
tom tom kicked reset button[510]called customer assistance. use paper clip bent to a point turn unit upside down so ser# can be read you will see one gold ternimal on left side and about a dozen small terminals to the right just above last three terminals is a notch in plastic cover reset button is in middle of slot push with paper clip two or three times not overly hard.mine started working.when plugging to cig. lighter button kicked.easy fix hooray for TomTom.hope this helps.greetings from Music City.
May 29, 2008 | GPS
MY ARCHOS PLAYER WONT WORK
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
Jan 05, 2008 | Archos 605 WiFi Digital Media Player
Tom tom go 510
There is a reset button (hole) underneath by the plug-in bar. It is real small, you'll need a small paper clip straighten out
Nov 05, 2007 | Tomtom GO 510 GPS Receiver
Doesn' t turn on
reset the device by pushing the reset button near the plug on the bottom of the unit , then it will come on i presume you upgraded by the internet you need to use a paper clip to reset the unit
Sep 25, 2007 | Tomtom GO 700 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
