When i turned on dosent do nothing it make a humming noise on motor the timer keeps moving but dosent do nothing at all what could it be
  • 2 more comments
  • jo_al5 Oct 08, 2010
    the motor it seem that want to go could be the capacitor for the motor how do i check that
    my kenmore washer makes a humming noise on the motor could this be the capacitor how do i check on that
    the model # is 110.22942100
    thanks
    thanks men will try
    god luck
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The humming noise is caused due to the motor going bad and should be replaced. You can buy the parts from this link.
Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 08, 2010
  • Rylee Smith
    Rylee Smith Oct 08, 2010
    Dont think its capacitor issue however, please post back with the model no# for further assistance.
  • Rylee Smith
    Dont know why you did not like my solution, may be I gave you a honest answer. Anyways you can check the motor couplings before replacing the motor. Still capacitor will not cause hum noise, hum only occurs when the motor is bad.
    President:
  • Washing Mach... Master
  • 1,932 Answers
Initial thoughts are 1.worn/broken motor coupler if it is a direct drive 2.Belt got stuck somewhere if it is belt drive 3.Motor fault
Please go to below website this show how to access the belt drive and direct drive machine and repair it.It has photos for better understanding. http://www.american-appliance.com/catalog/newsdesk_index.php?newsPath=16&osCsid=de6d99b437988cbed9e657a31a75ecc9
Below website contains service manual select the service manual for your machine
http://www.eserviceinfo.com/index.php?pagetogo=1&what=search2
Thank You
I have a majic chef CYE3004AYW dryer. When I turn it on nothing happens but the dial still moves like the timer is working.
Do you hear any noise like humming? Maybe the drum belt broke, might be a lower panel held on with two screws near the bottom, remove to look with a flashlight to see if belt is attached to motor. If in tact unplug the dryer and check heating element for burnt leads.
Sep 26, 2017 | Dryers
Unit does not want to turn on. Power to switch, makes a noise when you turn the knob, but machine does nothing?
Sounds like either the unit's control board or timer is not communicating correctly. If you at all hear a humming or buzzing noise, the control board may be having issues with the motor of the unit. You would need a professional in this case to move forward.
Sep 23, 2012 | Frigidaire GLGR642A Gas Dryer
The 4004-20 timer began humming after a power outage. It will not stop, and I have pushed every button and turned the dial. How can I stop the humming?
Paragon 4004-20 is DPST mechanical timer with 240V clock motor
http://waterheatertimer.org/Paragon-timers-and-manuals.html#Paragon4000
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
I'm guessing that clock motor is source of noise.
If timer is keeping good time and dial is not slowing at tripper points then timer is basically sound.
Turn power OFF and spray WD40 or put a bit of white grease on the gears.
The noise might also be the timer mechanism vibrating in the box... see if snapping out the mechanism and putting it back makes a difference ... you might have to push sides of box inward to hold mechanism tighter.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 27, 2011 | Paragon Hardware & Accessories
Fills with water then does nothing
WHEN YOU MOVE TIMER DOES THE MOTOR AND WATER MAKE NOISE. MOVE TIMER WITH DOOR OPEN TO A MID CYCLE. IF NOTHING THEN THE MOTOR OR TIMER. OR CONNECTIONS AS THE WATER SHUTS OFF WHEN THE LEVEL SENSOR OPENS.
Mar 08, 2010 | Whirlpool Dishwashers
Dryer won't spin, but heats up - belt is okay
the motor may have seized up, or the drum bearings are shot.
Jun 19, 2009 | GE DBL333EA Electric Dryer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Dryer makes a buzzing noise when I push the start switch.
Sounds like a bad motor, The buzzing noise is probably the motor humming then nothing because the thermal over load switch inside the motor opened. Timer will still be energized. Good Luck
The Squirrel
Mar 26, 2009 | Dryers
Dryer will not start
when you turn the select knob, you set up the internal cams of the timer. when you press to start or pull to start, you energize the timer motor (buzz) the timer opens the water solenoids. the diaphragm switch senses the water level and moves the timer to the next step. agitate starts for the timed cycle. when its finished the motor kicks in in opposite direction to drain and pump water out.
Dec 10, 2007 | Kenmore 63942 Dryer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
