Question about Whirlpool Refrigerators
Makes ice but doesn't dispense - Whirlpool Refrigerators
  • Whirlpool Master
  • 3,740 Answers
Hi and welcome to FixYa I am Kelly.
Since you did not mention a model number all of here at FixYa will have to shoot from thr hip. Open the door and check the door switch plunger to make sure that the light is going out when you depress the switch. Even then that same switch can be bad as it has 2 contacts common to the power lead. One for the light and one for the ice auger motor. It is possible for the light to work and the auger motor not to work.
This manual will help you diagnose the problem:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Thanks for choosing FixYa,
Kelly
Posted on Oct 08, 2010
Testimonial: "Thanks! I guess I need a service call."
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
My Refrigerator makes ice but doesn't dispense water
The water reservoir is probably frozen. Remove the drawer second from the bottom and place a hair dryer on the shelf blowing on the coil of water line referred to as the water tank/reservoir. Let it blow hot air on it for 10 to 15 minutes. Try the water dispense. If the water flow is restored, set the fresh food section one setting COLDER to increase air circulation. Set the freezer to one setting to one setting warmer to circulate air that is a bit warmer. This corrects 90% of the issues related to water dispense.
The other 10% is normally the fault of the water valve.
Here is the water valve to order in case it is faulty.
Regards,
Richard Roth
http://appliancecafe.com
Oct 31, 2012 | GE Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Won't make ice
It probably still MAKES ice, it just doesn't dispense it. The ice drawer may be blocked. Remove the ice drawer, empty it, rinse it through with luke warm water - including all non electrical moving parts, dry thoroughly, replace, give the machine time to replenish the ice, should solve your problem. Assuming it is just that it is only that it is blocked.
Dec 27, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ice dispenser wont dispense ice
sounds like a problem with a belt or something or you cango here http://www.theelectricdiscounter.com.au/new/enquiry.asp and ring the nomber
Dec 24, 2011 | Kenmore Refrigerators
Problem with kitchen aid superb side by side refrigerator - ice will not dispense. It makes ice, and the water works just fine. Is there are part that I can by to replace the door insert all together?
This is the auger, the unit that dispenses the ice. Check to make sure that the power to the unit, usually plugs into a port in the freezer, isn't dislodged or loose, If that doesn't fix the problem, you can call local part sellers, you can find one on www.whitepages.com, and see how much for a new or reconditioned one.
Hope this helps
Joe
Aug 29, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kenmore Elite side by side 106.4442 603. Out of power for 24 hrs and after that the ice dispenser doesn't work properly. It makes ice and dispenses water but no ice is coming out. Could it be a frozen...
During the power outage im sure some of the ice melted and then refroze into a big block in the ice bucket did you remove the ice bucket and empty all the ice from it?
Aug 24, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Will not dispense ice
i have changed filter and it still is not making or dispensing ice what could be the problem
Mar 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
197 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
