Which one? Not sure what to open ???
  • 796 Answers
Let me know what has happened....
if that doesnt work press ALT+CTRL+DEL to open task manager.
in process tab end the mcshield.exe
Posted on May 29, 2008
Open stuck door
Use a torch to heat up the rusted-shut hinge/part. Make sure the doorlock mechanism is disengaged first (or open/disconnect it first from the inside (take out the doorpanel to make sure it's 'open').
Jul 13, 2014 | 1971 Chevrolet Corvette
I open my Yahoo messenger, but when i open my email, i cant open it. I tried to open first my mozilla firefox first, then open my yahoo email, still i cant open it.
Make sure your internet is strong, yahoo is hard to connect because a lot of people are using it. If your using pre-paid modem, make sure it has one-day unlimited internet.
Try also upgrading your Mozilla Firefox
Try also using Yahoo at night, between 7pm to 4am. People are asleep or busy at times like this, so you have the yahoo for yourself.
Mar 30, 2011 | Yahoo Mail
I cannot open my document that i just saved, please help!!!
Make sure the document isn't already open, then check the recently opened folder.
Mar 01, 2011 | MSI Wind U100-280US Netbook
Press the key fob button and the tone goes for about a min.
A door is open or the body ecu think is open, when you press the open button in your fob make sure the open door indicator in the cluster if off, also make sure that the buttons in your fob are not sticking
Dec 24, 2010 | 2000 Toyota Camry Solara
My yahoo mailbox canot open
are you sure of the password or user name.but if you sure then enter it again it will open.it will open.
Jul 09, 2010 | Yahoo Mail
Garage door will only open like 6 inches high but it will close
Does the light flash right after? I had the same issue and it was because the electronic 'eyes' couldn't see each other. Clean em up and make sure they are pointed at each other. The only other issue could be the upward force is set too low on the opener. You may have other issues with the door not opening as it should. I'd make sure that you can open it by hand just to make sure it's not binding.
Sep 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door is opening when the neighbor open theirs with remot
You say you "setup the remote and the main box but doesn't solve." I think you mean you programmed the unit but I'm not sure. Anyway try holding the smart/learn button in for 10 seconds and this will erase the memory. None of the remotes should work. Now when you are sure the neighbor will not be using their opener, program your remotes. This may be what you did but I'm not sure.
Aug 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
CRAFTSMAN 1/2 HP OPENER
Ok well the best advise I can give you is to open up your opener case should be a 1/4 nut driver or a Philips head screw driver. Make sure to unplug it first. Once the case is off, find a reqtangle black box with three white plastic screws they are what controls the limits. Chances are they got knocked off wheny ou were putting in the gear. check to make sure the wires are hooked up and find the placement of the limits make sure they can touch each other. Little tip I do for my customs is get a piece of sand paper and rub it agaist the metal contacts for the limits only. (after time lift master openers bind up a film and dont stop where they supposed to.) If your still not sure how the limits work plus in the opener and run it make sure not to put your hands inside the opener and nothing esle is in the way. Then adjest the limits as needed. That should take care of you if not go ahead and make another post ill check back with you.
Feb 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage wall mount
This might be a easy fix but not sure two thigns I would try is check to make sure you don't have a lock switch on your wall control and if you do make sure its off. That locks out the remotes but oddly they go bad and sometimes just do really odd things. The other thing is check the wire to the wall control make sure theres no cuts or staples in it
Feb 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Travel cot by chicco
the secret to open that chicco travel cot is to make sure while opening the upper clips make sure the base is still closed. its a safety thing. then open the base.
Jul 16, 2008 | Baby Gear
29 people viewed this question
jasbo
jasbo
