Question about HP DeskJet 960c InkJet Printer
La impresora hp deskjet 960 c no imprime y parpadea la luz de color naranja
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
  • 100 Answers
SOURCE: rodillo roto .. como desarmo la impresora hp C5280
Pls take ur printer to the service center.
Posted on Mar 14, 2010
puertobori
  • 7733 Answers
SOURCE: `LA IMPRESORA HP DESKJEST F380
Use este enlace y baje la aplicacion.Luego habra la aplicacion.Esta le dara un diagnostico de su problema.
Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English) .
Si necesutas mas ayuda vuelva.No ovide dar un "thumbs" o algun testimonio de mi solucion,gracias.
Posted on Nov 19, 2010
CreativeTECH
  • 1719 Answers
SOURCE: The 2605DN printer just do it on a thick black
Dirty print out is basically due to cartridge related issues. Take out the cartridge and clean its drum/ (green roller) with a dry, soft, lint-free cloth. The drum is usually located under a cover. Checkout for any spilled toner inside the printer and clean it also. Print a few pages so that the parts get further cleaned. I think, this would solve the issue.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Cartridge or get the PCR Roller changed by a professional.
Let me know if any further clarification is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Posted on Dec 22, 2010
  • 8 Answers
SOURCE: Hola necesito ayuda urgente!!!Mi impresora hp 5610 all in one no termina de alinear los cartuchos. Me imprime la hoja de alineacion y me pide que la ponga boca abajo en el cristal y nuunca termina de
Saludos
Mi nombre es Jose, es un placer inentar ayudarte, para este caso lo que te recomiendo es que leas el post de, mi impresora imprime una pagina de prueba todos los dias, es tu solucion.
Si necesitas ayuda estamos para ayudar.
Posted on Oct 18, 2012
Hola el problema que tengo es que la impresora copia muy oscuro y en un tomo chocolate quiera saber que puedo hacer en este caso gracias
Empezando, qu? impresora tienes? Si es un Deskjet y est?s escribiendo en modo de "color", deber?as ponerlo en modo de "black". Independientemente a eso, posiblemente tienes uno de los cabezales funconando incorrectamente de tal forma que el resultante de la impresi?n en vez de "black" sale marron.
Imprime los colores b?sicos para verificar cu?l es el color que causa el problema para reemplazar el cartucho o cabezal
Apr 18, 2015 | Office Equipment & Supplies
Parpadea la luz verde de encendido .la luz roja de lamp tambien
SOY NICO,Jose si es la D que parpadea es el sensor ,3 gear pressure switch tienes que cambiarlo, me pasaba lo mismo lo cambie y problema resuelto,cuesta 67 dollars con los taxes en el dealer,lo puedes cambiar tu mismo,busca este codigo en internet P0845 y mira las fotos donde esta ubicado,esta es la imagen ,quita la rueda del lado del chofer y lo veras,para cambiarlo desconecta el negativ bateria,,4_28_2012_1_09_18_am.gif
Apr 22, 2012 | Cars & Trucks
Jeep liberty 2004 se enciende una luz en el lado derecho del tablero de color naranja q es
Exactamente cual es la luz que ve en su tablero...
Comentenos para poder darle mayires detalles.
Nov 24, 2011 | 2004 Jeep Liberty
Tengo una impresora cannon mx 320 La impresora no imprime y me da el siguiente aviso en pantalla; ERROR DE IMPRESORA 5200
tengo canon mx320 y no imprime correctamente si es una linea recta sale torcida las letras tambien que puedo hacer
Feb 22, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
`LA IMPRESORA HP DESKJEST F380 ME MARCA ERROR Y NO ME IMPRIME
Nov 18, 2010 | HP DeskJet F380 All-In-One Printer
Pixma MP160 not faxing
ERROR E27
Hola gente no lo consigo ni por un lado ni por otro.
Alguien lo ha conseguido ???
Sigo las instrucciones al pie de la letra:
Describo las teclas que he usado:
parar -> tecla en roja que tiene un circulo y dentro un triangulo
on/off -> tecla que pone on/off arriba
1- Pulso y mantengo pulsá la tecla de parar
2- pulso y mantengo "on/off" y suelto parar
3- teniendo pulsada "on/off" pulso dos veces para y en la segunda suelto para y on/off
4- la impresora se enciende y pone un cero en el contador
5- pulso una vez la tecla parar se enciendo la luz de la izquierda que es naranja la que esta con el triangulo y un rayo dentro
6- pulso otra vez para y la luz se va a on/off
7- pulso para otra vez la luz pa la izquierda es decir triangulo y rayo
8- pulso otra vez para (ya van 4 veces) y la luz pasa a on/off
y ahora que....
por que yo pulso ahora on/off y la impresora hace ruido pero la apago la vuelvo a encender y las luces de falta de tinta, es decir la de la B y la C siguen encendida
no se que hacer he mirao por todos los foros del mundo estoy a punto de tirarla por la ventana y comprarme otra
saludos
Apr 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP DeskJet 960c InkJet Printer Logo
288 people viewed this question
Seeker5211
Seeker5211
