Question about Toto CST414M-11 Aquia Dual Flush Elongated Toilet - Colonial White
How do i replace a fill valve of a Toto Aquia II. I can't reach the underside of the tank where I suspect the coupling nut is located. Do i need to remove the entire tank?
  • David Pan Aug 07, 2013
    I'm facing the same problem. It appears you have to take the tank out to access the coupling nut below the tank.
  • 33 Answers
SOURCE: FAMILIAR WITH TOTO AQUIA TOILETS
Everything you need to know about Toto! Hope it helps!
http://www.totousa.com/Default.aspx?tabid=215#
Posted on Jan 27, 2009
kachbibi1
  • 979 Answers
SOURCE: I purchased a Toto Aquia
If this is one of those models that most people have, the valve that shuts the incoming water off when the tank is filled is probably bad. It only costs about 8-10 dollars to replace. This valve is actually a stem or tree shaped device.
Posted on Jan 28, 2009
manhandy
  • 146 Answers
SOURCE: Toto runs non-stop; won't shut off
float is sticking make sure it is moving up and down.or the float is set to low, the lower the float is higher the water level is.
Posted on Jun 24, 2009
  • 62 Answers
SOURCE: Looking to buy/install Toto Aquia II in my circa 1964 co-op apt.
When you say 10.5 inches from wall, do you mean that from the center of the drain in the floor to the back wall is 10.5 inches? If so, you need a toilet for a "10 inch rough-in" dimension. The Aquia doesn't come in that dimension. Sorry!
Caroma Sydney Smart model 270 comes in a 10 inch rough-in and is a dual flush model. Note that all dual flush toilets are fairly expensive as compared to normal toilets. HOWEVER, genrally speaking, ALL 10 inch rough-in toilets are fairly expensive just because the low volume that are sold.
Posted on Jul 11, 2009
SOURCE: Push Button - Have to Hold Down Button
I had the same problem with mine and I lifted the tank lid off and
extended the rods they are threaded and turned them out a few turns and returned the lid back on and no more holding down the buttons
Posted on Jan 17, 2010
Leaking from water tank
Is the water leaking from the tank onto the floor or at the water valve located where it comes in from the wall.
Feb 08, 2013 | Toto Toilet - Elongated Bowl, Dual Max -...
No water in tank
Check to make sure the valve that goes from the back of the toilet to the wall is open.
May 31, 2011 | Toto Toilet - Elongated Bowl, Dual Max -...
My tank bolt holes are leaking
If you cannot tighten them, then they will need to be replaced. Turn off the water supply valve, flush the toilet and bail out as much residual water as possible. Remove the old bolts and separate the tank from the bowl. Replace the old tank gasket and refasten the tank with new bolts, properly placing rubber washers symetrically. An added precaution that I use is (after drying the inside of the tank well) is applying a dab of clear elastomeric sealant to the top of each bolt head, working it past the edges of the bolt heads onto the tank. Allow the sealant to cure as per directions. Open the supply valve slowly and allow the tank to fill. Inspect the tank bolt holes for leaks.
Nov 23, 2010 | Toto Aquia II Dual Flush Toilet
Toilet flushes fine but when the tank has filled it seems like the float ball keeps bobbing up and down letting more water or air into the tank. it will do this 5/6 times then quits. its almost like it is...
The ball float follows the tank water level, and repeated cycles of the float dropping and opening the fill valve would likely reflect a leak in the flush valve. You could try adjusting the float arm downward so that it will respond to a lower water level. Try turning off the supply valve, flushing it and listen for water leaking past the flush valve after it closes. If it does, replace the flapper or adjust the chain.
Nov 13, 2010 | Toto Aquia II Dual Flush Toilet
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
REMOVAL OF TOTO AQUIA TOILET
first shut off water and then flush the john. this will remove most of the water. for water remaining in tank us a sponge or similar to remove remaining water. find where toilet bolts to floor and remove these bolts or nuts. then pick whole toilet from floor, there should be a wax ring under toilet, replace wax ring when putting back in. when putting back in just push down on toilet to squish wax ring and bolt to floor, turn on water and check for leaks. good luck
Apr 16, 2010 | Toto Aquia II Dual Flush Toilet
Constantantly dripping after tank is full
WHAT IS DRIPPING,?THE TANK ?OR IS STILL FILLING UP ?IT SOUNDS LIKE YOU NEED TO ADJUST THE WATER LEVEL TO THE PROPER 1.6 GALLONS PER FLUSH,WHICH IS MARKED ON THE INSIDE OF YOUR TANK SOMEWHERE,CAUSE WHAT YOUR HEARING IS THE WATER RUNNING DOWN THE OVERFLOW TUBE
Apr 09, 2010 | Toto Aquia II Dual Flush Toilet
Our Aquia Dual Flush Toilet starts running in the middle of the night. We would like to take care of the problem ourselves, without calling a plummer. Please advise.
it could be the flapper or a bad fill valve. you can easily replace these yourself. they sell kits at lowe's and home depot, or most hardware stores. they are pretty inexpensive and should only take about 15 minutes
Dec 18, 2009 | Toto Aquia II Dual Flush Toilet
Toilet will not flush
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Mar 07, 2009 | Toto Aquia II Dual Flush Toilet
I purchased a Toto Aquia II Dual Flush Toilet, around a year ago. No problems until now. The toilet won't flush. It doesn't appear to be running at all.
Jan 14, 2009 | Toto Aquia II Dual Flush Toilet
Toto CST414M-11 Aquia Dual Flush Elongated Toilet - Colonial White  Logo
1,060 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
