Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
Soap does not dispense but forms a hard block.
  • Whirlpool Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 08, 2010
Fix soap dispenser
remove the entire soap dispenser and clean out any dried soap which may be lodged in the pick up tube, blocking the pump
Aug 26, 2014 | Plumbing
Tip
Fix simplehuman soap dispenser
Solution!!!!! to Simplehuman sensor soap dispenser with blinking red light no despensing of soap and new batteries. Rinse out soap with hot water. Fill reservoir with hot tap water. Use bulb end of turkey baster. Place on reservoir to form a tight seal. Force air into reservoir. Which will force the hot water thru the system unclogging the thick soap. Repeat this several times till clear of soap. Then turn on the unit and flush thru the rest of the hot water using the sensor till comes out nicely. Then fill with a thinned out soap. Good luck
on Jan 16, 2014 | Simplehuman Sensor Soap Pump ST1001
Dispenser door will not open
Hey friend, thank you for the post!
I understand that your soap dispenser door will not open on your Frigidaire dishwasher, LGBD2432LW0A. You could possibly be seeing an issue with soap dispenser not getting water into it to release the soap from dispensing. I would check to make sure there are no dishes blocking or obstructing the soap dispenser. You could also remove the soap dispenser to clean it and make sure there is no buildup of any previous detergent remaining that would cause the door to not open. If those steps do not solve the issue it could be a problem with the dispenser and I would recommend having a tech come out to the home to properly diagnose and repair the dishwasher. Hope this is helpful. -Matt
Jul 28, 2014 | Frigidaire Dishwashers
Sometimes the soap dispenser does not open. How do I clean the white hard substance off of it?
Sometimes the soap dispenser is blocked by a large item. It could be a casserole dish, baking pan, etc. Be very aware as you load your lower shelf so that there in nothing that will block the action of the dispenser.
To remove the white build up, run a regular cycle when the dishwasher is empty. Instead of using detergent, use 1/2 cup of white vinegar. This should break down the white scale. After the final rinse, if there is still evidence of the scale, use an old toothbrush to scrub it off.
I hope this helps you. If it does, please come back to Fixya and rate my advice!
Jul 22, 2011 | Kenmore 18 in. 14432 / 14439 Built-in...
Water coming out of soap drawer
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) .Water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning.
Black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases you have to replace the dispenser.
Feb 05, 2010 | Hotpoint First Edition WMA22 Front Load...
Soap dispenser problem?
Check the water supply. Start cycle then open the door after it fills and check water level and spray action. If everything is soaking wet, there is probablyl a pizza pan blocking the soap tray.
Jan 05, 2010 | Frigidaire 24 in. PLD2850 Built-in...
I have the CFW-8000 washing machine. When the
It sounds like the timer showing 1:09 is the time in minutes (109 minutes = 1 hour 49minutes) which is approximately the same as your own timer shows.
The soap dispenser often gets blocked and you will have to remove it and clean away all the residual, built up soap.
It sounds like the drain plug in the base of the unit has become blocked and that is why the soap dispenser is filling with water. All the water SHOULD DRAIN THROUGH the dispenser when it washes the soap down into the washing machine.
Also sounds like your water or fabric softener is blocked too!
Take the plastic parts out and clean away all soap residues.
Nov 18, 2009 | Crosley Washing Machines
Bosch dishwasher soap dispenser
all you have to do is take a flathead screwdriver and look at the dispenser it has a locking metal around thecase where the dispenser goes. it a press in and listen to it click thats when you know that section is in.the plastic around the dispenser is the section where it snaps in. also unplug the dispenser. its only one plug in. very easy but atrick that i use is make sure the rubber gasket is lubricated with something like dish soap.when installing it you have to push hard and listen for the snaps .nyc appliance repair can handle at 1-888-692-1055 based in nyc
Mar 26, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Soap dispenser still has the soap in it after the dishwasher cycle has ended...
do you have a salt unit fitted. I had the same problem and the repair guy had to replace the salt unit as it was blocked up. Failing that it might be the board not opening the solenoid to allow the water to be jetted through the soap dispenser.
Feb 18, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
37 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
