Where is the USB located - Computers & Internet
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
That will depend on the brand and type of computer and motherboard used.
Most USB ports are located on the back side of your computer (some newer model cases have ports in the front), and are about 5/8-inch wide and 1/4-inch tall. As for motherboards most will be on the back side. Some do have them on the board itself for hardware installation. How to find out what a USB is go here: http://www.howstuffworks.com/usb.htm
Posted on Oct 08, 2010
Locating fuses
Usually, if you short a USB port, only that port will be affected. Try booting to safe mode and reinstall the driver.
Oct 21, 2013 | Dell Computers & Internet
Gateway 5632E usb high speed ports locations
You can view the rear I/O panel of the GM5632E (including six USB 2.0 ports) atGateway Support - Ports.
The front view, including two USB 2.0 ports is atGateway Support - Front View.
May 02, 2012 | Gateway Computers & Internet
WHERE DOES MY STICK GO IN AN IBM THINKPAD LAPTOP
The model number is located either on the bottom of the right corner of the screen and on the label on the bottom of the laptop and the location and number of USB ports vary with different models.
The USB port is a connector/port that is 12x5 mm in size, some model thinkpad have onlt one USB port and some have 2 USB ports.
The USB ports are usually located at the back or at the sides of the laptop.
The T30 model has 2 USB ports at the back of the laptop located between the LAN and PS2 connectors.
The T40 model has 2 USB ports located at the left side of the laptop.
The A31p model has 2 USB ports located at the back left hand corner of the laptop.
The R32 model has 2 USB ports, one is located at the back left hand corner and the other is located on the left hand side of the laptop.
Feb 08, 2012 | IBM Computers & Internet
How can i download a music .save to my usb?
1. 1. Connect your USB Flash drive to your computer.You can do this by locating an unused USB port on your computer. 2. Locate the my computer icon on your desktop,provided you are running one of the various Windows operating systems. Doubleclick the my computer icon. You will see a drive labeled as removable drive orflash drive. Double click on the drive. Leavethis window open, proceed to next step. 3. 3. Locate the music files that you havedownloaded/save to your computer. Usually the default location will be "My Music" folder under "MyDocuments". Open the folder that you have downloaded/saved your music in. 4. 4. Highlight the music file and right click. Pickthe copy option. Next go back to the window you opened for you flash drive instep one. Right click in this window and click paste. You should now see yourmusic file in this window.
Jul 17, 2011 | Kingston 2PK 4GB USB 20 DATATRAVELERI GEN...
How do you transfer files from the computer to usb?
Right click the file you want to copy and select "Copy". Open My Computer and double click your USB, then paste the file you copied
Mar 15, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Mt usb is not formating error is windows was enable to format
you can also format your drive in cmd..follow these steps: OK let's start! A. Opening a Command Prompt :1. Click Start 2. Then click All Programs 3. Point to Accessories 4. And click Command Prompt
remote_image20100413-3568-1u9q1a6-0.jpg Command Prompt in its default location
B. Type the location of the USB
remote_image20100413-3568-1isanwk-0.jpg It is commonly D:, E:,G:, or H:, depend on the number of disk inserted
C. Press Enter on your keyboard
remote_image20100413-3568-1u9gy68-0.jpg It will go to the location typed.
D. Type Format location of the USB: then press Enter on your keyboard
remote_image20100413-3568-16457ho-0.jpg It should look like this
E. Then the format process will begin . I didn't press enter thought my USB have has no problem with it ;D
F. The command prompt will say that the format is done. And that's it! You're done! Congratulations!
Feb 12, 2011 | SanDisk 1GB Cruzer Titanium USB Flash...
Where is the usb port located on the Dell Dimension E-310 computer?
4 ports on back, 2 on the front, 1 usb header on the motherboard
http://support.dell.com/support/edocs/systems/dim3100/en/index.htm#printed_documentation
May 13, 2010 | Dell Dimension E310 PC Desktop
I have a PNY 4GB high speed USB Drive. I want to
Well, the easy way would be to do this
But if you want to use the USB drive just insert it into an open USB port
  1. click Start
  2. click My Computer
  3. Select the USB drive from the list of connected drives
  4. Click and drag the files from their location to the USB drive
To get them to the other computer follow steps 1-3, then click and drag them from the USB drive to their new location.
Sep 16, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Can't find usb plug-in
USB Port is located inside next left of the cartridges.
LD
Nov 09, 2008 | Brother MFC-3240C All-In-One InkJet...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
