Question about Bosch 24 in. SHU53 Built-in Dishwasher
The dishwasher stop on1 on the timer and doesn't shut off.
  • Bosch Master
  • 3,247 Answers
The 1 you get on the display is an error code.
It is linked to the water temperature. Either the input water temperature is not correct or the heater is faulty.
Posted on Oct 08, 2010
My dishwasher did not stop running, it went for hours...
follow this steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic control.
Jul 30, 2013 | Asko Dishwashers
John lewis integrated dishwasher
make this test and fix it. God bless you
Float Switch
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/control board
Jul 24, 2013 | John Lewis JLBIDWS1804 Builtin Dishwasher
Zanussi dishwasher ZSF6161 starts program then stops after 15 minutes
check this steps and fix it. God bless youFloat Switch
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control.
Apr 02, 2013 | Zanussi Dishwashers
Dishwasher stuck in wash cycle
see this causes and fix it. God bless you
.Float Switch
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control 10_17_2012_1_06_02_pm.jpg
Oct 16, 2012 | Whirlpool Dishwashers
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
Kenmore dishwasher filling up with water but never spinning and cleaning
I have had this happen before on my dishwasher. The timer inside the door is stuck or the contacts on the timer may have broken off. When you turn the knob on the dishwasher it sends power to a timer, which continually turns until the end of the cycle. This timer is attached to a bunch of arms which close contacts to send power to different parts of the dishwasher during different times in the cycle, now if the timer is worn out and missing parts of its gears or missing some of the armatures the machine will only get so far along in the cycle until it doesn't know what to do next and just stops. Hope that helps
Sep 06, 2012 | Kenmore Dishwashers
MDB7600aws Maytag dishwasher heats up with door shut when off
Your timer is jamming on the heat cycle. When you open the door the door interlock switch cuts the power off and stops the cycle.
Probably if you just close the door again it will heat again unless the machine is started again.
You need to repair or replace the timer.
Mar 16, 2010 | Dishwashers
My FDB2810Ldc1 dishwasher won't stop going thru the cycles. We have to open the door to stop it. When the door is closed again it starts and will continue for hours if the door is not opened again.
The first thing I would try, is to to reset the washer by unplgging it with the door open. You can do this by manually pulling the plug or by tripping the breaker that goes to that plug.
Hope this works for you,
RSMITH972278
P.S. IF YOU NEED FURTHER HELP CONTACT ME !
P.P.S. PLEASE RATE ME !
Oct 21, 2009 | Frigidaire 24 in. PLD2850 Built-in...
It starts then stops. never completes the cycle. it shuts down. it will drain thats it.
If the cycle didnt complete check the following:
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
* On some units, the pause is timed and the unit continues after the allotted time.
* On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place doing one function continuously the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Sep 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher won't start. Control panel lights come on when you press start/cancel, but it doesn;t run. I have checked door latch, any other ideas?
under the plastic door liner is the pcb timer and the white looking with 2 wires hooked to it needs replaced always unplug or shut off power to unit if working on it if you know how to use an ohm meter take a resistance reading if none replace the thermal fuse....
Aug 19, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Bosch 24 in. SHU53 Built-in Dishwasher Logo
91 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
