Paper jam I have a paper jam in a canon pc 1060. I have taken out the cartridge, but I can't get a good enough grip on the tiny bit of paper showing to remove the paper, not having any luck pulling it out from the other side (where the completed copy ejects) any ideas???
  • 1,326 Answers
I would not suggest using a letter opener..... It will cause more damage unless you have a extra $90.00 bucks for the part and the coast of the service call. I believe there is a small lever to release the pressure on the fixing unit near the exit of that unit.
Be very carefull with removing the jam...
Posted on May 30, 2008
The copier says rec paper jam slide left platen? what do i do ?
On the slide there is a handle. This releases the top reader port of the copier, move it to the left. Raise right side cover and remove the drum cartridge unit. You should see the jammed paper there, at the right lower access door, or in the fuser where the paper should come out. Just reverse the procedure to reset the jam. If the copier still indicates the jam then it must be in the fuser. You will have to have a technician remove the fuser assembly from the copier and take apart the unit to remove the jam. Hope this helps.
Jun 12, 2011 | Canon PC-1060 Black and White Copier
I have a Canon Pixma ip4300. I replaced the 5 PGBK (the large non-photo black) cartridge and I went to print. A piece of paper got jammed, so I pulled that out and since then, that brand new cartridge...
Hi I think you may find a very small bit of paper may jammed under the print head, try removing the cartridge and have a close inspection, it only takes a tiny piece to cause the problem cheers Terry
Feb 26, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Unreachaable paper jam
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 22, 2010 | Canon PC-1060 Black and White Copier
Paper jam error showing, but no paper jam in
Hello there
This could do the trick
Nov 18, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper jam Cannon PC 1060
hello,remove all covers arond the exit area lift cart door, control panel screw ,slide left,remove glass.holes in top under glass and under control panel,slide top to left,look down into holes to see screws holding fuser in.three connectors slide out exit side ,carefully dissasemble fuser to remove jam.i replace at least one unit a week.do use sharp objects
Nov 03, 2009 | Canon imageCLASS D761 Copier
Says I have a paper jam when there is none
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 27, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Paper jam indicated but I opened the back and can't see any paper
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects. Most of the sensors are either a microswitch, or more commonly a light sensor (LED and photocell) which can easily become obscured or dirty with even a tiny bit of crud! also reload the printer drivers as the printer is not beem able to read that new cartridge has been installed. and dont just directly install the cartridge .install it through a procedure.as mentioned in the printer properties .---ink cartridge replacement option----- as canon printers do very much drama to detect some cartridges and sometime just works fine.
Nov 21, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PC 1060 has a paper jam that we can't get to
It sounds like the paper jam is in the fixing assembly, and you can not access it unless you take it to a service center for canon products.
Nov 10, 2008 | Canon imageRUNNER 5570 Copier
90 people viewed this question
jasbo
jasbo
