Question about Bosch Classixx WFL 2066 Front Load Washer
Need picture of where front seal clamp goes - Bosch Classixx WFL 2066 Front Load Washer
    Master:
  • 400 Answers
Usually all Manufacturers provide a schematic and exploded views of chassis ONLINE.
Check Bosch and see the SUPPORT or customer service area of their website. You'll need a model# to "search" or a serial number in some cases, but you'll find an area online that will show you your machine. Almost certainly a firm of the size of Bosch has PDF files for all of their appliances which can be downloaded and printed. Consider buying a repair manual from Bosch for your appliance if you are planning to repair it yourself. The price is generally reasonable and very handy for the repairman.
Posted on Oct 08, 2010
3 Suggested Answers
vest6
  • 196 Answers
SOURCE: Clamp and front door seal
Need to know whet you are referring to as a "clamp"
Posted on Jan 26, 2008
  • 353 Answers
SOURCE: Hotpoint WF645 : Do I Need special tool to clamp
not worked on this model.but hotpoint are usually eaSY. no special tools.but i found it easier to take the front of the machine and work at it that way about 1 hour
Posted on Jun 30, 2009
Change door seal
For most front-loaders:
Lubricate the slot which fits over the tub with washing-up fluid. Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange. When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. This is quite difficult and you may need another pair of hands. Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps,etc)
Pl rate me nice for the free help!
May 21, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
How do i change a door seal on a wma35 hotpoint washing machine
it can be changed through the porthole itself tho i find it easier myself to remove the front of machine as everything is easilly accesable that way ... once the bezzel has been removed the front is held by 4 self tappers remove these and lift front upwards to remove it from holding tags .. the seal itself is held by a large metal band you will see this quite clearly now ...
Jul 06, 2009 | Hotpoint WMA35 Front Load Washer
Rubber door seal replacement on my Front Load Washer
OPEN THE DOOR
THERE IS A WIRE AND SPRING CLAMP AROUND THE SEAL, PULL BACK THE SEAL WITH YOUR FINGERS AND YOU WILL SEE IT
TAKE OFF THE CLAMP
FOLD THE SEAL BACK INTO THE DRUM
YOU WILL SEE ( OR FEEL ) A CLAMP AROUND THE SEAL ON THE DRUM
SLACKEN OFF THE SCREW HOLDING IT UNTIL YOU CAN PULL OFF THE SEAL.
FIT A NEW ONE IN REVERSE ORDER.
HINT- WIPING WITH LIQUID DETERGENT WILL MAKE IT EASIER TO FIT THE NEW SEAL.
HINT2 - YOU MAY NEED 4 PAIR OF HANDS TO FIT THE SPRING CLAMP
Jul 06, 2009 | Whirlpool Washing Machines
Door seal needs to be replaced
Plug off the wall mains. Remove the plastic clamp holding the seal to cabinet & peel off the cabinet. Push downwards on the seal close to the tub & the seal will come off - it's just held by a spring on the periphery.
Apr 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Fit new door seal
Jan 20, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Need to replace door boot there is a tension spring and wire clamp where do they go
The spring goes on the inside of the door seal where it fastens onto the drum, u need to double the seal back in on itself to fit it , and the wire clamp fits on the out side of the seal where it is fastened to the front cabinet opening.
Hope this helps u.
Plz rate my solution.
Thanks.
Jan 02, 2009 | Washing Machines
How to replace the door bellows seal ?
this is general for all door seals - all are much the same.
disconnect from mains. take lid off
prise off the clamp holding seal to cabinet - usually a wire circle with a spring - and peel seal off cabinet. fold seal back inside drum
seal is held onto lip of tub with what is really a giant hose clip. undo this and the seal will come away from tub.
on new seal, lubricate the slot in the seal that goes onto the lip of drum with washing up fluid.
starting at top, enter the slot in seal on lip of tub. work your way round in both directions pushing slot onto lip. this is the hard part and it may take more than one attempt.
when seal is on all the way round, replace the clamp.
refix seal to cabinet (easy to do) and refit outer clamp.
test for leaks on rinse as water level is higher
Nov 10, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
WMA46 Door Seal
turn off at mains
remove clamp that holds door seal to cabinet. peel door seal off cabinet.
remove worktop
undo clamp that holds seal to tub. pull seal away from tub.
to refit
lubricate slot in seal that goes on tub rim with washing up fluid
starting at top, fit groove in seal onto rim and work your way round in both directions pushing seal on to tub rim - requires patience and you amy not suceed first time round.
refit inner clamp
fit seal rond cabinet -0 this part is easy
refit outer clamp.
test for leaks on rinse as the water level is higher
Sep 07, 2008 | Hotpoint WMA46 Front Load Washer
Hotpoint Aquarius WF440 Repalce Door Seal
no need to remove front panel
remove clamp that holds boot to cabinet and peel away boot
take top off
undo clamp that holds boot to tub and pull boot off
lubricate slot in new boot that goes on to lip of tub
starting at top, insert slot onto lip of tub and work your way round in both directions pushing slot onto lip
refit clamp
push door boot onto lip of cabinet and refit outer clamp
test on rinse cycle for leaks (water level is higher
water will be a bit foamy till fluid is washed away
Sep 06, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Jan 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
216 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
