Question about Sony VAIO Notebook
Keyboard doesn't work after several restarts. can't even log in....
    Sergeant:
  • 270 Answers
I know you said the keyboard doesn't work, but try this anyway:
power up, and hit the "del" key as soon as the memory check is done. This gets you into the BIOS, then check to see if there are settings that are preventing the keyboard from responding (like a keyboard lock switch (external or software ).
Failing that, you may have a bad keyboard. Try while booting up to press F8 and see if the windows will go to safe mode. If it does, then go to the control panel and see if the keyboard is software locked by windows.
Good luck.
Posted on Oct 08, 2010
    Master:
  • 388 Answers
Try this site or you can try a usb keyboard.
if the keyboard was removed check th connection.
http://www.eserviceinfo.com/downloadsm/17023/Sony_PCGFXA32.html
Emachine that the keyboard doesn't always work
Try a different keyboard. If you're currently using a ps/2 keyboard, then for sure get a usb keyboard...
Jul 25, 2012 | E-Machines W6409 (7234) PC Desktop
Tip
ACCESS LAPTOP ADMIN PASSWORD IF KEYS NOT WORKING
There have been several people out there who faced a difficult problem!
Suddenly when logging in on their laptop they realized that the keyboard or certain keys off their laptop keyboard have given upp!!!!
often some off those keys were ADMIN PASSWORD keys locking them out from their system and all their files, making them inaccessible to their computer!!!!
This solution is cruzial if your laptops keyboard is malfunktioning,
and you need a fast and safe access to your system.
This problem can occur when you least expect it and fast access can be cruzial,like in middle off a busy day at the office when you just cant wait
for service. (have this tip in mind when this kind off problem occur.)
THE SOLUTION: Its simple as long as you can access an external keyboard (borrow from your neighbour or from your work) if you dont have an own near by.
Just plug in the external keyboard and restart the computer and
you are now able to login to your computer again.
a simple solution to a major problem!
Hopefully you liked this solution or even better if this solution saved your day :-)
on May 14, 2010 | Computers & Internet
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
My KEY BOARD IS NOT WORKING
1. Restart your Computer at once. 2. If it doesn't work Turn off your computer and remove the keyboard from your computer and replace again. 3. If it doesn't work too, you need to change the key board. thanks
Aug 30, 2011 | Gateway 2520915 Keyboard
My f10 lite is on and keyboard won't work
Unplug it and replug it, if it still doesn't work restart your computer. If it still doesn't work, it could be the keyboard, or it could be the port it's connected to.
Aug 23, 2011 | Computers & Internet
I cant get the keyboard the respond to the hub, the mouse works fine but not athing from the keyboard. I have even put different batteries in.
I have this problem to sometimes. Hold the keyboard connect button with the hub connect button at the same time. If this doesn't work then restart the computer. If this does not work reinstall the software.
May 08, 2011 | Office Equipment & Supplies
I was using my laptop and now for some reason I can't type on the keyboard or log off. Did I hit a key and lock it? How do I unlock it?
Use the touchpad and right click on the Taskbar then click on the Task Manager to open it. In the Task manager, click on the users tab to view the list of the logged on users then click on the username that you want to log off then click on the Log off button.
After logging off again use the touchpad to restart the Computer by selecting the appropriate option.
As the Computer is restarting press the button that says on the screen to press to enter to SETUP screen. This will make the Computer boot to the BIOS. In the BIOS check if the keyboard is working by pressing the arrow keys to select the Exit menu to select the restore to default option.
If the keyboard is not working in the BIOS then the keyboard is failed and service is required.
Nov 03, 2009 | HP 550 Notebook
Acer eeePC keyboard, usb mouse, trackpad frozen
you can do everything you can do with a mouse with a keyboard, you just have to know the shortcuts. try finding the shortcuts or buying a cheap mouse and trying that.
Aug 17, 2009 | ASUS Eee PC 1000H Laptop
Keybord problem
I suspect someone at some time has spilt water on it and corrosion has set in you will need to have someone remove and clean it or fi a nnew one
Aug 06, 2008 | Computers & Internet
HP NX9030
ok
Try to boot in safemode to do so you have to hit the F8 button several times on restart and select safemode without networking and try there if it works then its and OS issue you can try running MSconfig by typing msconfig in run command and select startup tab thats on the right hand side of the window and selecte disable all and restart the system and try .
Jun 12, 2008 | HP Compaq nx9030 Notebook
Sony VAIO Notebook Logo
152 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
