Question about Dryers
Dryer was working it stoped and smelled like something burning .
    Master:
  • 400 Answers
You should call a repairman. Sounds like a thermostat that failed and the heat built-up inside the heating chamber until the machine stopped. This would be a gas therm and replaced by a qualified repairman. Unplug the machine and don't attempt to operate it as it might lead to a fire.
Posted on Oct 08, 2010
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
My dryer smeels like something is burning. Is
sounds like the dryer drum blet is loose, this makes it slip and u get the burning smell.
Nov 17, 2009 | Computers & Internet
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
It smells like something is burning smells like the gas is not burning very harsh odor that burns your eyes after a period of time
If it smells like an incomplete combustion smell, clean the burner first. I'm assuming it used to work and now doesn't? If it never worked correctly it may have the wrong jet in it. There is a jet for propane and one for natural gas. They do not interchange. If it smells like plastic burning, something probably got past the screen and fell into the burner.
Sep 28, 2009 | Dryers
Dryer will not work
souns like the belt or rear bearing has messed up.
May 11, 2009 | Dryers
Dryer stoped running
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
Feb 24, 2009 | Maytag Dryers
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
When the dryer is on it smells like something is burning
iF YOU USE DRYER SHEETS IN YOUR DRYER, YOU MAY WANT TO WASH, BY HAND, THE SCREEN IN YOUR VENT. tHE SHEETS BUILD UP A COATING ON THE SCREEN AND IT WILL MAKE YOUR DRYER WORK A LOT HARDER AND MAY CAUSE THE SMELL.
Oct 06, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer just stoped working.
Chances are it may just need a new connector in the back where the power cord connects. Check it and see if you can tell where any wires have been damaged. This is usually very easy to do with little or no disassembly.
Aug 04, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
