Question about Amana ADB1000AWW Dishwasher
The detergent latch won't open, therefore, dishes not getting clean. I've run it a couple times now, but still won't open. Any ideas?
jsrock516
  • 5911 Answers
SOURCE: Detergent Fill Dispenser
The dispenser is usually controlled by an actuator of some type. This can consist of a small electric wax motor, switch or mechanical assembly. Some dispensers come equipped with an actuator as one complete assembly, while others have separate components that can be purchased separately. I would need your complete model number (located somewhere along to door opening) to be sure what type you have. I can locate a part number for you and give you some guidance on how to make the repairs yourself, if you wish to pursue this on your own and avoid the cost of a repairman. Post back with comments and let me know. I hope this helps you.
Posted on Jan 28, 2008
  • 641 Answers
SOURCE: Detergent Dispenser does not open
It is located within the door assembly, close to the detergent dispenser cup. You will need to gain access to the inside of the door.
Posted on May 15, 2006
rickzilla
  • 706 Answers
SOURCE: Dishes not getting clean, white film
Hello cljjtm,
You will need to clean the wash arm and unclog the spray holes.. use white vinegar to break down the soap deposit and a sharp metal tool such as an awl to free these holes up from any build up.. white vinegar may be applied while unclogging the openings..
Then, once the spray arm holes are freed of deposits..Start with an empty dishwasher.. and then start a wash on the hottest available setting and then after a few minutes of it cycling.. pause it and add a cup or two of white vinegar to the wash ( the white vinegar should break down any soap residue and allow it to be rinsed away)..once complete.. use about 1/3 less detergent than you have been. See if that gets your DW back in working order.. Hope that helps..
Regards,
Rick
Posted on Feb 16, 2009
rylee_smith
  • 8619 Answers
SOURCE: Dishwasher does not clean well
Hi
Kindly check for the following :
1. Check the water temperature. Should be 125 to 140 F.
2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
4. Check the spray arm and pump cover for splits or leaks.
5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Please revert for any clarifications.
A "Fixya" rating would be appreciated if you have found this to be Helpful.
Thanks
Rylee
SOURCE: My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Posted on Mar 05, 2010
Detergent lid opens, but undissolved detergent streaks down door and dishes aren't clean.
5 results (0.58 seconds) Search Results
    Support - Dishwashers DW80F600UTS/AA ' Samsung ...
    www.samsung.com > Home > Support > Dishwashers
    Samsung ElectronicsVisit Samsung today for DW80F600UTS Top Control Dishwasher with Stainless Steel Tub (Stainless Steel). You'll find product and support information for our ...Missing: black ‎undissolved ‎streaks
    Dishes still dirty - dishwasher ' Ask MetaFilter
    ask.metafilter.com/145865/Dishes-still-dirty
    Feb 13, 2010 - If they use dry dishwasher detergent, some of the undissolved dishwasher ... (part of the pump of the dishwasher) breaking down or some piece ofblack plastic (often a ... Every single dishwasher I've ever worked on had a built inwater heating element. ... That's all we use and never get spots on our dishes.Missing: samsung ‎dw80f600
Jan 19, 2016 | Samsung DW80F600 24" Black Built-In...
The last month my kenmore 665 dishwasher will run its full cycle but the dishes don't look clean and there is dish detergent residue. So I bought glisten to clean the dishwasher and the wax pl
Obviously your heater is not working during the main wash cycle. This could be caused by a bad heating element of course, a bad thermostat, a bad controller, or even the door latch (1 of the 2 switches may be bad or may not be getting engaged when you close the door).
Dec 11, 2014 | Kenmore Dishwashers
Why does my detergent latch open up while the dishwasher is running?
If neither the detergent flap open or the rinse aid is being dispensed the this is usually down to a faulty or 'open circuit' solenoid that operates the dispensor unit.
Sep 20, 2014 | Maytag Dishwashers
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
D/w doesn't dissolve deterg. & therefore not washing dishes
Do this test:
-Upgrade to a name brand detergent like Cascade or Electrosol.
-Do not over fill the dispenser cup
-Do not place large items near the door/near the dispenser cup.
-Make certain that both spray arms can spin freely after you load the dishwasher but before you close the door to begin the wash.
Please report back what you find, OK?
May 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Whirlpool quietpartner I Dishwasher wont clean anymore.
you need to take the blades that spin out and clean them off they have grime on them, is there water still in the bottom of the dishwasher when done> if so there is a plastic grate in the bottom rear of the dishwasher you need a 1/4 inch nut driver take the cover off and clean the debris out, there is a small stainless steele cutting blade in there be careful, it is to cut up foods that might not be washed off before putting dishes in the washer, also it is pressure that makes the detergent door open make sure you are getting full pressure comming into the waher, if non of this works the pump should be replace or it;s new dishwasher time
May 30, 2009 | Dishwashers
Dishwasher does not clean. soap door does not open every time.
Well the 2nd part of your question is probably the the reason it doesn't clean. If the soap door doesn't open then the dishes will probably not be cleaned. So.. I would focus on why the door doesn't open first.. is it sticking from old soap residue? If so, clean the dispenser with white vinegar and cycle it a few times without detergent and use the hottest/sanitary setting.. Then make sure you are using an approved dishwashing detergent for yuour wash cycle. Add some detergent to the dispenser and try cycling it without any dishes .. does the door open? If no, then you need to resolve that first.. If it does open, try running a cycle with about 1/2 the normal dish load and see if the door opened and the dishes came out clean.. Routinely, check and clean the drain filter so you aren't redistributing the food sediment from the previous load all over the next load of dishes.. Hope that helps..
Sep 06, 2008 | Kenmore 24 in. 16009 Built-in Dishwasher
Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Jan 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag mjd 2005dishwasher
Try what my wife does. She uses the individually contained detergent/rinse bubble packs (tab packs). No messy granular detergent and easy to simply place inside the silverware basket. Your dishes should wash spotless, like ours. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Maytag 24 in. MDB9750AW Dishwasher
Amana ADB1000AWW Dishwasher Logo
Top Amana Dishwashers Experts
Cleverer2
Charles T Nevin
Charles T Nevin
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
