Question about Singer Inspiration 4205 Mechanical Sewing Machine
The machine sews normally then once in awhile the material gets stuck in one position, does not move. The bobin thread seems to be a bit tangled in the bobbin case. What is going on?
    Genius:
  • 1,788 Answers
Your bobbin may be wound uneven, try winding a fresh bobbin and make sure that you are using the same weight thread in the top and bottom. And try a fresh needle.
Posted on Oct 08, 2010
Machine hand wheel will not move.
sounds like it jumped time . take it to a repair shop .
Dec 03, 2016 | Singer Sewing Machines
Thread tangles on the underside of the material being sewed the top seems normal, but the bottom of the material I am sewing becomes a tangled mess. any help would be greatly appreciated.
Sounds like a threading problem. Thread the machine all the way to the needle but not in the needle eye and make sure you have the presser foot up. Then pull on the thread and move the presser foot up and down. You should have tension when it is down and no or very little when it is up. If this is not the case you did not get the thread in the tension disk or your machine needs a adjustement. try this and let me no if it fix the problem.
Mar 22, 2011 | Singer Sewing Machines
Thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Jan 17, 2010 | Singer 3116 Simple
Threads tangle, cuts material instead of overlocking.
tension must be set on five and make sure there is no cotton stuck in your tension unit
Jan 11, 2010 | Sewing Machines
Thread bunches from the bottom while sewing.
Hello, sewing is a part of my income and I've encountered this problem before and managed to fix it on my own, by trying out these different things. I re-threaded the machine and checked to make sure that the tension is not too loose. Check the bobin and the sack the bobin fits into, sometimes it comes loose too, click it back into place and re-do the bobin. adjust the tightness of the stiitches, I usually put it on 2 .5 - 3. Hope this helps. Good luck to all. Nefishakh@hotmail.com
Nov 16, 2008 | Singer 5050 Mechanical Sewing Machine
Bobbin gets tangled up
Try taking the covers off again. Now check under and around the bobin case, thats the black plastic bit that holds the bobin. Look for any fuzz or stray bits of thread inside the machine and and around the feed dogs and under the needle too. I use compressed canned air to get in and really blow everything clean. For some reason if the machine is not totally clean, inside the bobin gets tangled up. If you have had even one knot, odds are parts of it are still floating around inside there somewhere and stopping some little lever from moving and jamming your whole machine. Clean under the bobin case too since lint can left it up and keep the bobin from being perfectly level. Also inspect your bobbin case to make sure it isn't scratched along the edge that rotates back and forth. Even a a tiny scratch will cause it jump its tracks and your bobin will lift up and become jamed. In that case you just have to buy a new bobin case. But most of the time your culprit will be some stray bits of thread or lint.
Sep 30, 2008 | Brother SE-270D Computerized Sewing...
Upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Aug 21, 2007 | Euro-Pro 416 Mechanical Sewing Machine
Singer Inspiration 4205 Mechanical Sewing Machine Logo
177 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
