Question about Toshiba 57H82 57" Rear Projection Television
Scramble picture Toshiba 50H81
We interchange a hyper board 23786198 and the picture is good... but from another set and it can't be use...
All 10 uf was changed and still same problem
all capacitor cecked ok
5V ok on many IC's
There is a place for a complete assembly for a good price...
Or other think possible to check up in module
Thank you
A magic finger
Posted on May 31, 2008
Can see screen snow flaks and other designs but no picture?
need to replace the hyper board is not longer abailable but you can found it online --ebay cost about $120-180
Dec 19, 2010 | Toshiba 50H81 50" Rear Projection...
Picture is wavy then fine, happens every two minutes
This model like several others had problems with what is called a Hyper board inside which processes all signal inside the set.
From a Toshiba service bulletin:
No: PJTV200503 2 Pages Ref: WU032505
Product: Projection TV Date: 3/25/05
Models: 42H81,43HX71, 43H71, 50HX81, 50H71, 50H81, 53HX71, 53H71, 57HX81, 57H81, 61H71, 65HX81 AND 65H81
Product Safety Precautions:
Product Safety Precautions are described in the Toshiba service manual(s) for models covered in this bulletin. All safety precautions and checks shall be complied with before returning the equipment to the customer. Servicers who defeat safety features or fail to perform safety checks may-be liable for any resulting damages and may expose themselves and others to possible injury.
Application: The information contained in this bulletin applies only if you encounter the symptom(s) listed below.
Subject: MVPU13 Hyper Module Repair (23786198 / 23148017X)
Symptom: Multiple Symptoms may be experienced depending on which capacitor is faulty. The primary symptoms are jagged, digitized or pie crusting of the picture. The set may also be described with a poor sync condition.
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040 as shown in Figure 1. It's recommended that all of the capacitors identified in Figure 1 be replaced. (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.)
TOSHIBA AMERICA GOISJSUIVIIER PRODUCTS, L.L.C.
There are several surface mounted capacitors that dry out with age and usually the problem starts out when first turned on and then eventually after on a long enough time the set works--the time will get longer as the problem gets worse.
The board is no longer available and only two options here: locate and replace all the selected caps which is not a do it yourself job or remove the board and send it out for rebuild.
Let me know if you need more info as I have seen dozens of these sets with this kind of problem.
SD TECH
May 13, 2010 | Toshiba 57H83 TV
Picture is distorted keeps on moving
Good Day,
You have problem with caps on the Hyper Board. This is how to repair it:
the top shield and replace all of the 10uf, 16v capacitors using Part Number 24619040 It’s recommended that all of the capacitors identified be replaced. (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care).
GOOD luck, big IRISH.
Dec 08, 2009 | Toshiba 42H81 42" Rear Projection...
Picture is scrambled until it warms up. Can play DVD without any issues, but all other video inputs are scrambled for 30 - 40 minutes.
unit has a bad hyper module,NLA thru toshiba.try contacting tristate module or pts to see if they still rebuild them.toshiba part-23786198,MVPU13,PD0264A
you mite have to search to web a bit to find one if they dont rebuild them anymore.
Sep 29, 2009 | Toshiba 42H81 42" Rear Projection...
Shaky picture on my toshiba 50h12
Your ICc may have damaged if display is flickering.
Jan 22, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba 61H71
2SC5570, according to the service manual.
Jul 13, 2008 | Televison & Video
Shakey Screen
That problem is caused by defective capacitors on the Hyper Board location UZ01 stamped MVPU14. You will need to have a technican remove the board and replace all the 10 uF @ 16 Volt SMD caps p/n 24619040N found on that board. The Hyper board is no longer available as a part.
Dec 24, 2007 | Toshiba 50H82 50" Rear Projection...
Tv only watchable through component Toshbia 57H82
this is a known problem with these toshiba tv's, they will do nothing to help you we should form a consumer group and complain to Washington! The part that needs to be replaced is a hyper pcb,pd0637and is available from Tritronics, in Miami Fl.phone #1-800-365-8030.the part cost me $263.00
Dec 06, 2007 | Toshiba 57H82 57" Rear Projection...
Picture appears to be trying to scramble
Bad hyper board == No longer available
Bad electrolytic capacitors on board need changing-
Let me know if you need more info......T.
Nov 01, 2007 | Toshiba 51H84 51" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
109 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
