Question about GPS
Tomtom 710 My tomtom 710 charges on its cradle, but will not turn on. Nothing happens when I press the on/off button. Any suggestions? Thanks
  • 515 Answers
First, reset:
http://www.tomtom.com/support/index.php?Language=1&query=reset&FID=6965
Then, hold down the power on button for several secs,
at least 7...
Posted on May 30, 2008
My tomtom charges the green light comes on I press the on button but nothing happens
I have managed to fix my TomTom one.
The problem was two fold. First the diode D8 was blown and also the power supply chip was blown.
It is a tricky job, using surface mounted components so should not be attempted by a novice but I managed it.
I have a full set of photos etc if anyone cares to try it. I figured - NOTHING to loose!! so what the heck and just went for it. Taking it apart was fun! The surface mounted IC was easy to obtain and the total cost was about £10 plus 4 hours panic labour. If anyone wants the info just let me know and I will send the photos - but no promises - it worked for me.
I figured out this ongoing problem. I purchased my TomTom One second edition 1/20/07 for $395. I was 30 days past my warranty and had the problem of unit not turning on. Green light came on when charged.
I opened my unit up and found the sw2 micro switch broken. If you press too hard on the on/off button, this will eventually happen.
I couldn't find a replacement switch so I wired my own switch and it works now.
Oct 26, 2010 | Tomtom ONE XL GPS
Tomtom Go 710 continually trying to shut down,still plugged in to car adapter or mains power, but comes up with 10 second warning continually, shutting down.
I have had the same problem. unfortunately I have been told that it is the cradle connections to the main unit. they are at fault due to wear and tear and causes the shutdown. Try wiggling the cradle when connected, if there is some slack play then you may also have the same problem.... by the way, Tom Tom are not interested unless within warranty and they dont sell replacement cradles!
Jan 27, 2010 | Tomtom GO 710 Car GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
Jul 14, 2009 | Tomtom RIDER GPS Devices
Tom tom won't turn off
if it does not proceed when the icon is selected, presume data corruption or in fact no data.
TomTom is renouned for this type of problem.
try rteinstalling the map data from the source.
try a reset first ( small pinhole on rear) put open paperclip end in and gently push the button inside) if this still fails then data installation is the go
Jun 23, 2009 | Tomtom GO 720 GPS Receiver
TOMTOM 910 will not turn on after charging
According to Kevin A who says, and thanks by the way (There is a reset button on the back at the top of the unit. It should be on the right side as you turn the unit around. Insert a paperclip or pin into this hole, and the unit should reset) at it works 100% because I tried this morning after being quoted £55 to have my GO910 fixed and now it works after the price of a paper clip. Doug rrp3
Nov 21, 2008 | Tomtom GO 910 GPS Receiver
Tom Tom Go 710
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
Jan 13, 2008 | Tomtom GO 300 GPS Receiver
GPS Won't Turn On
I suggest any unit under warranty to be returned to its supplier or if they will not help, contact tomtom directly!
http://www.tomtom.com/support/index.php?Lid=1
Download the latest updates from tomtom.
Dec 03, 2007 | Tomtom GO 300 GPS Receiver
Tom tom 710
Theres a tiny hole at the back if you look with a torch where the TomTom connects to the cradle
Nov 10, 2007 | Tomtom GO 510 GPS Receiver
GPS Logo
197 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
