Question about Miele S558 Red Velvet Bagged Canister Vacuum
No power. I was getting intermittent power with my miele s558 midsize canister, but it was predicated with me fiddling with the retractable cord to get it to come on and then not move the canister while I was vacuuming. Now I can get no power. I have taken it apart and can see no issues with connectors, cord, casings, etc. It all looks fine. It is about 5 years old and I have had no problems with it.
  • 97 Answers
SOURCE: my Miele s558 Silver moon
This is caused by a circuit board problem in the hose. Unfortunately, the only way to fix this problem is to purchase a new SES 125-3 hose. The good news is that the new production hoses have rectified this problem and you will not experience it again.
-R
Posted on Sep 10, 2008
futureloginn
  • 734 Answers
SOURCE: Miele Solarus Canister Vacuum stopped working
Miele S251i Plus Bagged Canister VacuumMiele white star canister vacuum - won't turn on,...
I have the above canister vac, which after my son tried to vac the stairs, it rolled down the stairs on him, but still worked, after turned off/on. Then after turned off maybe 10-15 mins., stopped working when we tried the switch. My father in law is our fix it guy, but still having a problem with the switch. Is there a wiring guide we could look at?
Thank you!
ALevy
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can try to call the factory for the Miele S251i schematics / wiring diagram @ the phone number and website listed below or I put a few pieces of information listed below that might help.
1. The vacuum cleaner switches off automatically
A temperature limiter switches the vacuum cleaner off automatically if it gets too hot. Some models have a warning light (triangle) which comes on to indicate that it has overheated. Allow the appliance to cool down for approx. 30 mins. and remove any blockages to the air path.
2. The "Change dustbag" indicator stays on even when a new bag has been inserted
To ensure the dustbag change indicator gives a correct reading, lift the floor nozzle or power head off the floor slightly to prevent the vacuum created in the suction tube from influencing the reading.
3. The exhaust filter indicator is red
Change the exhaust filter and then press "Reset" to switch off the indicator light.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430
Posted on Dec 02, 2008
  • 97 Answers
SOURCE: miele s558 Silver Moon
It is not generally necessary to replace the entire cord reel, although occasionally it is.
Here's the quick and easy DIY way to make your cord reel work again: you will need a #2 phillips head screwdriver, any flat head screwdriver, a pair of scissors, and a zip-tie.
First, remove the bag compartment lid by gently prying the hinge parts inward with the flathead screwdriver until you can lift it free. Remove bag and exhaust filter, and then remove the two screws holding the rear control panel on. Lift the front of the control panel upward until you hear a horrible unpleasant crunching noise. You didn't break it.
Lift that free, and remove all screws from the top of the main housing. (I believe there are 6 or so... but I can't remember off the top of my head.) The housing should then lift free.
You should now be able to see your cord reel. see if it wiggles back and forth along the central axle. If it does, you'll want to place the zip tie around the side of the axle which is away from the large round copper contacts which look almost like leaf springs. This will ensure that the contacts make electrical contact again. Cut off the excess zip-tie.
When putting the parts all back together, it is essentially a reverse of the disassembly, but be sure that you thread the cord through the hole in the back of the housing before you attempt to screw the housing down, or you will be very sad; both because you'll have to disassemble it again, and because you'll probably jack up your cord and have to replace the reel, which is what we're trying to avoid.
Test machine. If it works: party. If not, you will have to replace the cord reel.
For further clarification on the process, contact me.
Good luck,
-R
Posted on Mar 07, 2009
  • 430 Answers
SOURCE: motor makes loud growling noise, no suction on
Growling sound on a canister is normally caused by a suction fan wobbling loose due to damage or a bad bearing. Loss of suction would occur if the fan is loose or damaged. If the bearing is bad but the fan intact you will still lose suction as the motor will not run properly out of balance. Take it to a Miele service center for parts
Posted on Sep 07, 2009
  • 8404 Answers
SOURCE: warning light on, vacuum will not turn on
Your machine is clogged ... probably in the hose.
ASSURE the air path is clear and the filters are clean before yhou proceed.
Let me know how you make out on this.
a
Posted on Sep 23, 2009
Shuts down at points on the retractable cord
your cord could be loose or it may need to be replaced this unit comes as one assemble you will have to replace the whole retractable cord assemble
Jun 30, 2010 | Miele s558 Silver Moon Vacuum
Miele just stopped working?
When a Miele canister just stops working all of a sudden, it's usually a pretty clear indication that either you have a bad cord reel, or a bad switch. I would say that in 60% of Miele repairs that I do with this problem, the cord reel has gone bad.
One easy thing that you can try to see if the cord is bad, is put one hand on the on/off switch, and the other hand grab the cord (making sure it's fully retracted inside the canister). Now pull the cord out slowly with your one hand, while continously turning the switch on / off, on / off. Keep pressing the switch on and off while pulling on the cord. Usually if the cord reel has gone bad, then you may hear the vacuum attempt to start, or even turn on while you're pulling on the cord. The cord reels in Miele use a metal spring inside that makes connection with the rest of the vacuum. Over time this spring will start to loose it's strength, and eventually will get so bad that it no longer makes contact with the rest of the vacuum. By pulling the cord out slowly and pressing the on / off switch, a lot of the times the spring will make connection somewhere, and the motor may turn on temporarily.
If this happens, this indicates your cord reel needs to be replaced. I have done a detailed repair here on Fixya on how to replace the cord on a Miele canister vacuum that you may read here;
http://www.fixya.com/support/t2281026-miele_s514_will_not_come
If you can't get the vacuum to turn on at all, this can only mean a few things. First the cord reels spring is gone completely, and wont make any connection with the rest of the vacuum, and you'll still need to replace it.
It also can mean that just the plug that plugs into the wall is bad, is your plug bent, or no longer straight on either prong?
It can also mean that your motor has gone bad. This however is usually the least likely of all the problems. The Miele motors are almost bullet proof, and typically last 20 years. I can count on one hand the number of Miele motor replacements I've ever done in 10 years of fixing vacuums.
I can try and help you diagnosis this further if my suggestions didn't help you. Please use the clarification request that you see here on this page to ask me a question. Please just let me know what happened when you tested the cord out as I suggested above. I really hope this was helpful to you. If you found this to be helpful, please be sure to rate the repair as helpful to you by clicking the thumbs up icon. I really appreciate that.
Chris J.
Mar 21, 2010 | Miele S318 Bagged Canister Vacuum
Le s558 s'arrete sans raison meme apres verification des filtres sac, etc
maybe the fiter it not place properly, there it'a a safety switch that it's not activated
Jan 06, 2010 | Miele S558 Red Velvet Bagged Canister...
Power cord is loose, power cuts off
If its the Auto wind cord then fault could bre internal contacts, not easy to get into suggest best to go to service centre.....
Oct 10, 2009 | Miele s558 Silver Moon Vacuum
Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Oct 07, 2009 | Miele S558 Red Velvet Bagged Canister...
Warning light on, vacuum will not turn on
a
Sep 23, 2009 | Miele S558 Red Velvet Bagged Canister...
No power to my miele s558?
It's a bad model that's why they took it off the market. Mine is doing the same thing have taken it in twice for the same reason. First time they replaced the cord $200.00 which I did not believe it was the problem. A year and a half later still cutting off on me as if it's over heating I took it in and they found nothing. Took it home and it did it again within 5 minutes of using it, new bag inside suction was fine. Can't explain why this has happened since I have owned this vacuume. A LEMON! pilmammy@gmail.com
Jun 26, 2009 | Miele S558 Red Velvet Bagged Canister...
NO Power
There is a fuse, you have to take the top off to get to it.
#225 is the fuse. You could have a problem with the reel cord asm also.
Apr 13, 2008 | Miele S558 Red Velvet Bagged Canister...
Miele S558 Red Velvet Bagged Canister Vacuum Logo
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
