Question about Bosch 11236VS Rotary Hammer
Bit will not lock into chuck. Ball inside chuck is stuck in "in" position, Bit slides all the way in and out w/o engaging the ball.
  • 4 Answers
Open locking sleeve, clean the inside with a good "rust type cleaner" WD40 if you can't find anything else, let it sit overnight, I suggest doing this 2 or 3 times, leave tool with drill end facing down. Clean out with small round wire brush, lubricate with white grease.
Posted on Nov 07, 2010
Dewalt dw005
Remove the cap and the circlip underneath and slide it all forward. Pull back plate holding the small ball and remove it. Put drill bit into a vice and pull on the machine. If it still won't come out you might have to tap on the main spindle with a copper hammer to knock the spindle off. Check the spindle for damage before reassembling.
Jan 18, 2014 | Drills
Quick change clutch is locked
Push the rubber sleve off the drill bit and up the drill bit then the plastic ring. release the clip around the spindle. Slide the clip and chuck sleve forward and remove the ball sitting in the spindle. You should then be able to pull the bit from the machine. If it does not want to come hold the bit in a vice and tap the spindle off the end of the bit using a suitable punch. Rebuild chuck in reverse.
Jan 29, 2013 | Milwaukee Electric Tool Milwaukee 5359 -...
Drill bit does not stay gripped, chuckless drill
On this particular tool, you can't really tighten the bit in the anvil like a bit in a drill chuck. The bit is free floating but held in place by a small steel ball. The steel ball is held in place by the sleeve that slides up and down to release the ball so the bits can be changed. The sleeve is held down by a spring. Bits falling out can be caused by: Using bits without the groove in the bottom of them for the ball to catch in, dirt in the bottom of the anvil so the bit can't seat properly, the ball is missing or stuck, the spring is broke or binding, or the sleeve is bent or too dirty to slide up and down freely. Use compressed air to clean the anvil well and WD40 to clean and lube it further. If bits still fall out you'll have to take it apart and see if the ball, spring or sleeve need to be replaced.
Jan 13, 2013 | Dewalt DW056 18 Volt Cordless Impact...
How do I repair stuck chuck
Sometimes it just needs some lubrication inside where the ball holds onto the bit. If that doesn't work, you need to replace the chuck pieces. Often times they come in a kit. The plastic sleeve may need to be cut or broken off.
Apr 07, 2012 | Drills
Bit tighten stuck open
If you mean the chuck jaws seem stuck open, spray around them with some penetrating oil or spray like WD-40, RP-7 or similar and let sit for a couple hours... Then you can tap around the chuck body with a light hammer or spanner etc... just lightly tap... Then if the chuck has an arbor lock to prevcent it from spinning, be sure that is engaged then try to release the chuck jaws. Sounds like they are stuck open through tight friction or rusting on the inside edges (that you dont see). Be careful not to leave them in the fully open position when stored as this is exactly what can happen!
Mar 31, 2010 | Makita 6304LR 1/2" Chuck Electric Drills
How to replace the chuck on a hilti te10
The complete chuck is not easily replaced. It you stick an SDS+ bit in the chuck and it seems to fit tight without much wiggle then the chuck can be replaced without taking the tool apart. The rubber cap on the end will just pull off. Next the locking collar with the annular spring will come off with the out side sleeve. Underneath is the guide tube with two enlongated rollers. The locking collar should have a ball bearing underneath it that locks the sleeve in place. Usually the roller bearings or ball bearing are missing.
Mar 14, 2010 | Hilti Drills
Sds drill stuck in chuck
tap it lightly with a ball pin hammer, if that dosnt shake it out try opening it and useing something to push it through
May 04, 2009 | Drills
Chuck
Probably just the ball come adrift or worn. Depends on teh age of the drill. If you pry the end cap off the tool holder and remove the chuck sleeve you should be able to see the spring lock mechanism. There should be a ball held in place by a dished washer. The ball can come out and get lost so check that. If this is the case it should be very cheap to buy a new ball, and easy to replace. Just remember to lay the parts out in the order you remove them so it easier to re-assmemble them properly. If the ball has jsut dislodged and not fdallen out you should be able to refit it but may need to repalce the chuck as it in this case it is probably worn.
Nov 01, 2008 | Bosch 11236VS Rotary Hammer
Broken chisel
The rubber end cap should just pry of the toll holder. Behind this ther is normally a snap ring or ciclip. Remove that and the chuck parts should all come off. Remember which order they were in. There is normall end cap, clip/ring, thick washer, dished washer and ball. Once all these parts are removes you can try and punch the bit out from the hole the ball sits in. If it doesn't come out like that then you would probably have to take the gearbox of and remove the striker from the tool holder and punch it out from behind.
Oct 21, 2008 | Dewalt D25830K 12 lb. sds max demolition...
Bosch 11236VS Rotary Hammer Logo
437 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
