Question about Konica Minolta magicolor 2400 Laser Printer
The printing starts about two inches down from the top of the paper, doesn't matter if I use Word, Excel, even the Print test page. So its not a margin setting in Word causing the problem.
  • 567 Answers
This is because the margins are defined on the printing settings.
You may go to Printing preferences and change the same, if you prefer.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Posted on Oct 08, 2010
WAS HAVING TROUBLE WITH HL 2040 PRINTER , LEARNT HOW TO RESET , FIXED THE PROBLEM. TRIED TO PRINT A WORD DOCUMENT , WOULD NOT PRINT - BUT WOULD PRINT EXCEL DOCUMENTS. WHILST TRYING TO GET STARTED AGAIN...
Hi Ron, I dont think you have a printer problem, i think you have a print driver/computer problem.
To find out unplug it (the usb) from you computer, turn it off so no data remains from previous print commands sent from your pc and run a self test by holding your green go button when you turn it on, keep it held untill toner, drum and paper lights light up, then let it go, then press the go button and the printer will print a self test....
If this works ok then we know your printer is ok. and your issue is as i suspect it is, with your print driver, paper size or tray select settings in Driver or in Word or in Excel or your document.
You can isolate if document problem by doing self test in print driver in control panel..
If self test on printer unpluged works and we have no error lights and are seeing the test ok and no flashing lights then you may want to ensure driver is good by completly unistaling the driver on your pc, do this by unistalling all brother stuff from control panel/programs and features (depends on operation system you are using).
Then with it still not connected, go to brothers web and download the full software and drivers package to suit your operating system, run it and only plug in the usb when instructed.
Let me know if your printer shows an error when not connected or if self test fails and Ill go down that road with you... if paper light on it when not connected, it tells us we have a jam, make sure you check back door and under toner drum and paper is sitting neat in tray
But when you tell me excel works and word doesnt, i dont think printer, it is software.Check your page size settings in word and excel and of your documents as the flashing paper light may be the printer trying to tell you the data sent to it from word is a paper size mis match to what the printer has in its tray and it wants you to feed the correct size paper in the manual feed/bypass slot. You should also check paper size and tray selection in your print driver in printers and faxs under control panel is the same as your document. Here is your manual
and here is where you can download your print driver (unistall old software and unpug usb first)
The more i ponder this, it is page size settings in document/excell/word and printer is asking you to feed paper in manual pass slot (above tray)
CHEERS RON
STEVE ;)
hi
Feb 22, 2012 | Brother HL-2040 Laser Printer
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    I am trying to print onto pre-printed forms which have a dark blue band at the top. My printer isn't recognising that the band is there so is starting to print too far down the page. Help please!
    This type of problem can usually be resolved simply by adjusting the margins from within your word processing program. Depending on which word processor you are using you can go into the page setup and make these changes. For Microsoft Word go to the "File" tab at the top then to page setup. The first tab that comes up will allow you to change the margins on the page. If the print is too far down try reducing the top margin from one inch to 0.5. If that is not enough reduce it some more. Print test pages on regular paper, then hold them up to the light against the paper with the pre-printed band to see how the print lines up. That way you don't waste the expensive paper!
    May 20, 2010 | HP Photosmart C5280 Printer
    I cant print on A3 paper through microsoft excel on hp1280
    in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
    Dec 31, 2009 | HP DeskJet 1280 InkJet Printer
    Printing Large Top Margin
    check the header and top margin in your application. (word, Note pad, etc..)
    default top margin for Microsoft word is 1".
    also check the orientation of the printer output.
    Nov 24, 2008 | Samsung CLP-500 Laser Printer
    My hp laserjet 4 plus printer cannot print excel files
    wherer are you printing this, A4 is european, north america would use letter, etc..
    if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
    Click ok, then print a test page from the general tab..
    The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
    If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
    does this happen with all excels files, or one particular?
    Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
    Sep 23, 2008 | HP LaserJet 4 plus Printer
    OKIpage 10i does not accept A4, and wants 'Letter'
    Maybe you won't be able to use A4 paper, which I think is 3/4 inch longer than letter-size 8 1/2 x 11, according to the sizing inside the paper tray of my OKIPAGE 10e. My computer, using Windows 98, doesn't list OKIPAGE 10e among the printers I can use with my computer. Yet, Windows 98 has incorrectly identified my printer as Okidata OL-600e for some reason. I'm surprised my printer works at all with Windows 98. Thanks for detailing your question as "when I print a test page (from the printer controls), because I was unaware I could print a test page using printer controls, so I started pressing anything that looked like an electronic button on the top of my printer. I believe this trial and error eventually helped me to get rid of an unwanted 1 inch wide bar, from top to bottom of 8 1/2 x 11 pages about 2 inches from the right-hand-side of my pages. This was progressively getting worse. I thought I was going to have to buy a new printer. I bought this printer used, and without instruction booklet, so I used your info. about printer controls and started pressing electronic buttons. It's amazing, because after I made about 35 copies, now the annoying 1 inch wide black bar is gone!
    Feb 12, 2007 | OKIPAGE 10i Led Printer
    Konica Minolta magicolor 2400 Laser Printer Logo
    65 people viewed this question
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Ben
    Ben
    David Burkhart
    David Burkhart
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
