Question about GE Refrigerators
Freezer worked well for a few days then ice in icemaker started melting. Refirgerator side was frozen.????? Then it repeated again. Any idea
  • cusosantiago Oct 08, 2010
    Sorry forgot model GE Profile PSW26LSRD
    Water does not run into the fridge side it just starts melting in the top section of the freezer.
    I turned the whole thing off for 4 hrs and it worked fine for a day.??????
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 .
Posted on Oct 08, 2010
No water to icemaker, but through the door water is working. Ice maker itself is ok.
This is most likely cause because some part of the ice maker/distribution mechanism is broken. If at all possible, remove everything from the fridge and freezer and allow the freezer to thaw. If that is not possible, you could try and remove just the ice maker to thaw it or try and thaw it while it is still in the freezer. I hope this helps and have a nice day!
May 04, 2011 | LG LFX21980ST Stainless Steel Bottom...
Seems the freezer door was not completely closed. Ice started ot melt and then form icicles! Well we closed the freezer the next morning. Now the ice maker and water dispensor are not working. In...
when you closed the door, the freezer froze all the condensation/melting ice,hence the icemaker freezing.
the best solution is a TOTAL defrost/clean out,then dry out.DO NOT USE HOT WATER/SCRAPERS,let it defrost naturally or use car de-icer.wipe out with bicarb to keep fresh.and then restart as new.
Sep 11, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
The freezer side every 2 to 3 days the fan makes a noise and the ice begins to melt. It drips from the ice dispenser. The following day every thing is frozen again. The refrigerator stays cold.
This may sound a bit harsh but turn off the water to your icemaker for several days. What your describing sounds like the icemaker water valve is leaking water by the diaphram and is leaking into your freezer. This is a common symptom of failing ice maker water valves. I just went through this on my own personal refrigerator where ice was building up. After changing the icemaker water valve all the ice build up ceased.
So turn off the icemaker water supply for a few days.. break out the ice trays if need be and see if the ice build up stops. If it does then the ice maker water valve will need to be replaced. Fyi they run $38 to 55.00 on average and you can change it yourself. Should the need arise here is a link to a replacement water valve source: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=113933&diagram_id=337176#d337176
Close up view: http://www.appliancepartspros.com/part_details.aspx?part_id=4298908
Thanks for choosing FixYa.
Kelly
Aug 30, 2010 | Frigidaire FRS26R4A Side by Side...
Ice melts in freezer
check your inner box liner for cracks also your door seal's you have a air leak
Jan 13, 2010 | GE Profile Arctica 25.4 Cubic Feet...
LG LRSC26923TT, water dispenser not working
I have a LG GRP207TUJA side by side freezer, which has a water,ice,crushed ice dispenser. There is a button to select which mode of dispenser. The freezer just appears to be cycling through all the selections all by itself and make the bleeping noise as it moves from one selection to another...any ideas
Sep 15, 2009 | Freezers
GE Profile Side by side- lines from custom cool covered with ice
I can't give you a solution but I can tell you that we have exactly the same situation. The freezer seems to work but we come back and water has dripped from the ice holder and formed a classic stalagtite (or is it a stalagmite?) Obviously something has melted. We have also found items in the freezer melted - yet the digital readout said it was 3 degrees! Arghhhhh. Glenn in Delaware
Apr 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Icemaker issue: cubes melting at the bottom causing water leak out the front
J, sounds like your dispensor flapper is not closing properly and you are drawing warm air up into the ice bucket. This model had an issue where the flapper pin holder was part of the housing and would break off. They have a kit now that fixes that problem. The only other thing it could be would be low freezer temps or it's staying in defrost too long. With out being there, I would start with the dispensor flapper. Check it out and post back.. Catriver.
Apr 21, 2007 | KitchenAid KSRS25ILSS Side by Side...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
