Question about Sony Ericsson Walkman® W880i Cellular Phone
RE: Adding contacts to the toolbar
When do I press the + sign? I've tried it from the main screen, main menu, contacts and from the toolbar but it doesn't work.
  • 87 Answers
+ sign is used for calling details in case a call is made to landline no who is out of country then put the +sign mit the code
Posted on Jun 09, 2008
Change screen font and size
This amazingly easy trick will instantly enlarge hard to see text on your screen!
Should you ever want to decrease the text, this trick in reverse will minimize text as well!
Spending lots of time online can cause eyestrain, especially if you encounter very small text. Don't squint or hunch over your screen! Squinting causes wrinkles!
Using these tips you can read screen text comfortably!
With the press of two keys, you can enlarge the screen text without going into your settings.
Simply press and hold down the "control" key, while pressing the "plus sign" key.
Be sure to keep the "control key" depressed while you press the "plus sign" key.
Each repetition will enlarge the text.
This can make reading small text SO much easier!
To return the text back to its original size (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key.
Each repetition will decrease the text size.
also
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
and text sizes largest to smallest
Apr 23, 2013 | Compaq Presario CQ56-115DX Laptop
Fix zoom level
This amazingly easy trick will instantly enlarge hard to see text on your screen! Should you ever want to decrease the text, this trick in reverse will minimize text as well!
Spending lots of time online can cause eyestrain, especially if you encounter very small text. Don't squint or hunch over your screen! Squinting causes wrinkles! Using these tips you can read screen text comfortably! With the press of two keys, you can enlarge the screen text without going into your settings. Simply press and hold down the "control" key, while pressing the "plus sign" key. Be sure to keep the "control key" depressed while you press the "plus sign" key. Each repetition will enlarge the text. This can make reading small text SO much easier! To return the text back to its original (being polite to the next user), simply press, and hold down the "control" key and the "minus sign" key. Each repetition will decrease the text . also Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar this will add to your screen toolbar File Edit View Favorites Tools and Help select the view from the drop down list will be a Zoom with percentages %
and text s largest to smallest
Mar 10, 2013 | Acer Aspire 5500 5570-2609 Laptop
How to make the letters bigger on my facebook account
Step 1:
Feb 07, 2013 | HP Computers & Internet
Get larger font on this computer
Hope this helps.
Jan 17, 2013 | Toshiba Computers & Internet
How to set speed dials
Adding a speed dial - Samsung Convoy (SCH-u640)
  1. From the main screen, press OK to choose MENU.
  2. Select Contacts then press OK.
  3. Select Speed Dials then press OK.
  4. Select the desired speed dial number then press OK to choose SET.
  5. Select the desired contact then press OK.
  6. If prompted, select the desired phone number then press OK.
  7. Select Yes then press OK.
-------a rating of "4" and a testimonial would highly be appreciated"------- you may also click on "YES" if this solution has resolve your problem...
thank you for choosing fixya...
Roger...
Sep 06, 2011 | Samsung Convoy Cell Phone
How do i add a screen name to aol.com
Sign on to AOL. Click My AOL in the top toolbar. Click Screen Names from the pop-up menu. Click Create a Screen Name. Click Create a Screen Name again on the new screen that comes up. Enter the screen name you want to use in the box. Press Enter. Type the password you want to use twice. Press Enter on the screen. Click Continue. Customize the new screen name with the preferences you want. Click Continue. Click Accept Settings.
Apr 09, 2011 | Computers & Internet
Installed AOC 2436vh, top of screen off of physical structure of screen, tried power down, physical reinstall, roll back of driver and reload of cd, how do I uninstall monitor to try again? Or adjust it...
I have the 2436V (no speakers), but I suspect the solution will be similar. My screen was a bit to the left of the monitor's physical display area, and I was able to solve it using the built in menu (If you take too long deciding what menu button to press next, the menu will time out. Just start over if that happens. You will get faster with practice).
1) Press the menu button on the monitor (the menu appears).
2) Press the up button on the monitor 4 times to highlight the icon that looks like a slightly angled screen with yellow cross-hairs in one corner (the toolbar for positioning the screen appears - all 5 icons on the positioning toolbar are blue).
3) Press the menu button on the monitor to "enter" the selected toolbar (one of the toolbar icons turns green to indicate the selected tool on the toolbar).
4) Select the tool you need using the up/down arrow buttons on the monitor (I needed the one that moves the screen horizontally, you need the one that moves the screen vertically).
5) Press the menu button on the monitor to activate the selected tool (the meter above the toolbar icon turns green to indicate the tool is active).
6) Use the up/down buttons on the monitor to position the screen.
7) Press the menu button to exit back out (or, just let the menu time out).
Note: the disk that came with the monitor doesn't seem to have drivers for Windows 7, but allowing Windows to search online while updating the driver found a compatible driver online.
Dec 22, 2010 | AOC Monitor
Toolbar in my internet explorer is almost gone
Are you missing the Internet Explorer toolbar that displays the File, Edit, and View menus? If so, you might have moved the Yahoo! Toolbar, or some other toolbar over the IE menu, or you might have gone into fullscreen mode accidentally.
First, make sure you aren't in fullscreen mode. If you are, you'll only see the navigation bar with the Forward, Back, and other buttons at the top of your screen. If that's the case:
  1. Press the F11 key on your keyboard.
  2. The other toolbars in IE should appear.
You can press F11 as many times as necessary to toggle between normal and fullscreen mode in IE.
If that doesn't solve the problem, you might have accidentally moved one of your other toolbars over the main toolbar. Try the following:
  1. Directly to the left of the Y!, you should see a thin vertical bar.
  2. Click this bar with the left mouse button and drag the toolbar straight down.
  3. Your main IE toolbar should now be visible.
Once your toolbars are how you want them, you can right-click the IE toolbar and select "Lock the Toolbars" to keep them from moving accidentally in the future.
If you're still having problems with your Internet Explorer toolbars, you might need to visit Microsoft's Internet Explorer support website.
Jul 09, 2009 | HP Hewlett Packard Officejet J5780 Laser...
Toolbar/menu/handle disappeared from saved and new documents.
Sounds like you've either gone into Full Screen mode or have turned off your Toolbars and Menu via the Customize command.
Normally pressing ESC will exit the Full Screen Mode. If you can't see the Menu try using the keyboard shortcuts like so. Keep the ALT key held down and press V followed T. Hopefully you should now see the menu and select "Customize..." to turn everything back on again.
Mar 17, 2009 | Microsoft Word 2000 for PC
How do I add contacts to toolbar?
just press the + sign..
remember... the + sign, not the - sign..
mega
May 28, 2008 | Sony Ericsson Walkman® W880i Cellular...
Sony Ericsson Walkman® W880i Cellular Phone Logo
27 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
