Question about Dryers
I have a newer but not brand new kenmore dryer. I have to run it twice to get a load dried. Serial number of dryer is ML4641775. Where is the heating element and how do I replace it?
  • 5,911 Answers
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state, or having improper air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards.
If you have any questions, please post back and let me know. I hope you find this information helpful.
FYI: There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, the heating element is working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat.
Posted on Oct 08, 2010
I have to turn my dryer on 2 or 3 times to dry one load of clothes
Your vent ducting or exhaust hose is clogged.
Oct 20, 2015 | Dryers
My kenmore dryer with serial number: DESR-NAT-1206006-FM22 doesn't have heat at all and my clothes are still wet. What to do before I call the repair guy?
Clean lint screen could be clogged a dryer sheet can sometime block the grille if a loads to large and heavy that will result in wet clothes.some dryers have an option for air dry if that is selec
Jul 24, 2015 | Kenmore Dryers
My Kenmore 6.7 cu ft he2 Super capacity electric dryer is taking twice as long to dry. no error codes
It sounds like a connection problem with one of the heating elements, or perhaps only a clogged input or output hose from the dryer. Either of these could cause the problem...also, a burned out electric element.
Jan 15, 2013 | Kenmore Dryers
I have a Kenmore 90 series dryer.The only number
the door should have a sticker where it closes against with model and serial numbers as for the second part ck terminal connection to elements to make sure they are tight next shoot continuity of the elements limit switches thermal fuse elements will be between 9 and 13 ohms others should read 0
Jan 28, 2010 | Kenmore Dryers
Drying not drying, clothes moist after hours
This is likely the result of an air flow problem if you are sure the heater is working. Ensure you are not running the dryer in a closed room which would starve the dryer of air dramatically reducing the air over the clothes even if the full length of your vent is brand new. Next, remove the vent hose from the rear of the dryer and check for strong air flow at the outlet. If it seems strong enough then run a vent through a window or out into another room and do one load in this fashion. If this resolves your problem the blockage exists in the vent line outside your dryer and disassembling dryer becomes unnecessary.
If not, ensure you have seen and touched every inch of interior dryer piping and hold the lint filter up to the light to be sure you can see through it. Disassemble and clean ANY section of piping you can't get your hand into. The area below the lint filter tends to catch a lot of lint and can only be accessed by removing the housing at the rear on the left side as you face the rear. Ensure the blower wheel turns when the motor turns. (Newer models may have the filter housing at the front)
Having performed all these actions will likely resolve the problem.
Sep 19, 2009 | Kenmore Dryers
Dryer has to run twice to dry completely
clogged wall vent dryer vent,lent shut,clean them all out-mike
May 17, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer not heating
thermal fuse kit.it is blowing due to improper ventilation.their is a clog somewhere from dryer to where dryer vents outside.thermal fuse is located at top of your elemnt cage.you will replace the thermal fuse and your high limit fuse at the bottom of the elemnt cage.but have your venting checked or swept out.
Mar 09, 2009 | Dryers
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Kenmore Dryer Model 110.888029 Serial MH1102412 Type 180.00
MOST LIKELY PROBLEM IS A RESTRICTION IN THE EXHAUST. DISCONNECT THE VENT FROM THE BACK OF THE DRYER AND TRY DRYING ONE LOAD. IF IT DRIES O.K.,
THERE IS A RESTRICTION IN THE EXHAUST. CLEAN THE LINT OUT FROM THE ENTIRE LENGTH OF DUCT WORK.
Apr 08, 2008 | Kenmore 63942 Dryer
Dryer wont heat up!!
where are fuses on kenmore dryer
Oct 25, 2007 | Kenmore 62872 Electric Dryer
Dryers Logo
60 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
