Question about GE Washing Machines
Washer will drain but not spin - GE Washing Machines
  • GE Master
  • 3,051 Answers
Hello there.
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Posted on Oct 08, 2010
  • mph161 Jan 04, 2011
    We used Purex 3 and 1 sheets for a while and the washer stopped draining so I looked at your solution and opened her up and removed 2 of the darn sheets in the hose. One thing I would note though is that you should wear gloves and long sleeves when opening the panel up. I cut my hands and arms on the razor sharp edges when opening up the access panel
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
https://www.youtube.com/watch?v=k41abYwM9WY
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
Washer won't spin. Motor goes thru cycle but not spinning
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
www.youtube.com/watch?v=fRxKs2EEfbU
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Nov 02, 2015 | GE GTWN4250MWS 27" top-load washer with...
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
https://www.youtube.com/watch?v=oFB1jEdXVsQ
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
www.youtube.com/watch?v=diRuMkf9_Vs
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
My washer will not spin or drain, what might I do?
? 5:17
Jul 12, 2013 - Uploaded by ApplianceVideo.com ... your Whirlpool Washer which has this following issues: Notdraining or ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums ...
Sep 09, 2015 | Washing Machines
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Ge washer not draining or spinning
HI yes you can remove the pump and clean. the pump is the problem
Oct 12, 2008 | GE WBSR3140DW Top Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
404 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
