Question about Estro Barista Athena
After about 8 years of good use, my machine started making some hard starting & now does not start @ all ?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 275 Answers
Sometimes pulling the top off will reveal a plugged up filter on the intake. There are tiny valves at the down side of the pump that must remain free of small particles or calcified deposits..
Posted on Oct 08, 2010
  • Ray Panzer Oct 08, 2010
    Thank you so much for your info, I will put it to good use
Key goes into ignition, but start engine
Had same problem. Sounds strange but I tried spare key that had never been used & it starts every time. The old key eas 10 years old & just quit working. Try another key. Hope this helps.
Sep 02, 2014 | Honda CRV Cars & Trucks
MY CRAFTSMAN 6.75 HORSEPOWER 21" MULTI-CUT POWER PROPELLED ROTARY LAWN MOWER MODEL NO. 917.377972 WILL NOT START AND RUN . STARTS THEN QUITS HAVE TRIED EVERYTHING IT HAS BEEN A SHOP LAST TWO YEARS HE CAN...
If the carb is new, then make sure the fuel is fresh- LESS THAN 30 DAYS OLD!!! Is the plug good? Air filter OK? Good oil in the engine? Make sure that the shut off cable hasn't stretched. It may make contact and shut off the engine.
May 20, 2014 | Mtd 22" Yard Machine Push Mower
Hard starting
Spark Plugs--Changed every 3 years?
Ignition Wires or COP Coils original to car (2000) ?
Battery more than 4 years old & tested?
Fuel Pressure Checked-Before & during starting attempt?
Back probed & tested TPS Sensor?
Can't just drive any vehicle,they have to be in the shop
a couple times a year, to do preventative maintenance,look
at data & road test,shops don't do much,you have to educate
yourself & unfortunately it has come to the point that you have to
tell them what to do & only what you want done,no skills or talent
left in the auto trade & the technology has passed them by, for good
You do not need to touch a gas pedal, to start any car,in the last 30
years,they are all electronic & fuel injected
Apr 08, 2014 | 2000 Lincoln Continental
Hard brake pedal
You can only have whatever the engine vacuum is
at any time.
Is there vacuum to the booster check valve
& is the valve working,assuming you have the
old one or a new one with the new booster.
Does fluid flow out all 4 corners?
Are the Rubber Flex Hoses Collaped
Calipers Rusted & frozen?
Did you remove the master & clean out
the moisture from around the piston
That is where you start,then flush & on to
every component in the system, if they are
on the vehicle for many years
You do realize brake fluid gets changed every
2 years on all vehicles or you got big problems with
moisture in years to come
Jul 18, 2013 | Cars & Trucks
Hard disk is not running frm last boot
hi,
- This means that your operating system may have collapsed and needs repair.
- To repair, enslave your hard drive to another machine by:
- Make sure the second computer has a good operating system.
- Remove the hard disk from your computer.
- Remove CD/DVD Rom from the second computer and fix your hard disk on
that drive.
- Start the computer.It will display that you're running on two drives.[Unix]
- Press F1 to save changes and continue.
- The machine notes one drive needs repair and starts the repair process.
- After it has completed and opened your system, turn it off and remove the
hard disk.
- Fix it on the first machine and start it.
- If this fails,you may need to format the hard disk.
GOOD LUCK!
Sep 11, 2011 | Maxtor (6L250S0-20PK) (6L250S020PK) 250 GB...
Put start and does not want to lock door and start
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to www.applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hello! I've got a LG LW40 Express Laptop. Whenever I turn it on, a black screen apologizing for inconvenience is what I see. It says that Windows didn't start successfully because of a software or hardware...
Take the hard driver out & put it back in, push it in nice & *** so that the pins go all the way in.
start it up & go into the BIOS witch should either F2,F8,Esc or Del.if you can't see the bios option
at the start it will appear as F8 or something like that in the list you keep getting.
Or just keep tapping F2 when you first switch it on.
In the BIOS go to exit then select LOAD SYSTEM DEFAULTS hit enter then go to the BOOT list & put them in this order if their not all ready done.......
1. FLOPPY
2. CD/DVD DRIVE
3. HARD DRIVE
4. USB or ANY OTHER DEVICE
it tells you how to change the values @ the bottom of the screen.
Go back to EXIT & make sure you SAVE CHANGES & EXIT.
It will reboot then select start windows normally.......JOBS A GOOD ONE!
if not bell me on my land line it's free land line to land line with BT & we'll try something else........GOOD LUCK.
Sep 04, 2009 | Computers & Internet
My GE WDSR2080G makes a metallic rubbing noise during agitation
Take front off and watch while it agitating useing a good light and see if you can tell where the noise is coming from 52c26ee.jpg
Oct 21, 2007 | GE WDSR2080D Top Load Washer
Estro Barista Athena Logo
181 people viewed this question
Top Estro Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Estro Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
