Question about NEC DT330 - - Phone
I have a DT300 and i need to add a headset? - NEC DT330 - - Phone
I plug in a headset correctly put the speaker button still goes to loudspeaker and not to the headset? Is there a setting I need to change?
You need to program a headset key on one of your buttons. Likely your vendor has to do that, unless you have an in house system manager who is really capable.
Mar 28, 2015 | NEC DTL24D1BK Phone
Program headset in to NEC DT300 phone
how do i connect head set in nec dt 300 series phone ?
and is there any configuration needed for that ?
Mar 27, 2013 | NEC Univerge Dtl-12d-1 680002 Dt300 Refurb...
Lost manual for Intermatic DT 17.
1) Copy following link to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
2) Add comment and describe timer in detail
Dec 16, 2012 | Hardware & Accessories
How to program digital timer
Timer is not identified.
Question posted next to image of DT300 digital timer.
Open following links to identify timer and download possible manual.
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
If you have different timer, then add a comment and describe the timer in detail for possible identification and instruction.
If you need somebody to read the manual and tell you what it says, then take advantage of fixya live service where expert speaks with you via phone while you program timer.
Sep 29, 2011 | RTO Intermatic DT300CL 8.3 Amp Seven Day...
GE digital timer DT300 need a free manual
Question posted under GE 15004 timer.
Open following link to identify Intermatic DT300 timer and download possible manual.
Open following link to identify GE15091 timer and download possible manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#15091
If the free information does not match your timer, then add a comment with clear description of timer for possible identification and manual.
Sep 23, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Need a manual for digital timer DT300GE
If the information does not match your timer, then add a comment with clear description of timer for possible identification and manual.
Sep 23, 2011 | Hardware & Accessories
Intermatic digital lamp timer dt300. I can only get to set it to 24 hour. it does not go to 12 hour when i reset and then hold down the clock button. what am i doing wrong?
There is no repair for defective timer.
The DT300 is sold under at least 3 different brands and product numbers, and each manual shows identical steps for choosing 12H and 24H format.
The manual says to press and hold CLOCK button until display shows 24H. Then press HOUR button to change to 12 hour format.
I am guessing this step cannot be done if timer has programming in memory, so timer has to be reset first by pushing in reset button for a few moments.
Open following links to identify timer and download manual:
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 14, 2011 | Intermatic Hardware & Accessories
Need instruction manual for outlet timer#59732 Model#DT300 125v/60Hz 8.3amp/1000watt resistive. Only other #s isee 227259
Open following links for possible DT300 manual:
I don't see load rating in manual, but 1000Watt would be typical for timer with 2-prong outlet.
If manual is not correct:
Other folks have asked for DT300 manual, but didn't like provided manual.
Timers can have many different numbers, and different timers can go by same number:
1) Add a comment with link to in-focus photo of timer posted on Flickr, for possible identification.
2) Open following link to help identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Aug 07, 2011 | Woods 17321 Outdoor Power Strip Timer with...
DT300, I charged the battery, can set the program, but not the clock.
DT300 shows re-chargeable battery, I didn't know there was a replaceable battery.
Add a comment with photo of your timer and battery to exactly identify product
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Try resetting timer.
Other Intermatic timers with battery have to be reset after battery change if timer does not function, but all these timers come with industry standard 1 year limited warranty and most go bad within a few years, although some last several years.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Apr 03, 2011 | Intermatic Hardware & Accessories
I lost the instructions to program my intermatic digital lamp timer, model:DT300 Can you help me?
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt300.ashx
The DT300 is not available from Intermatic
I guess they discontinued the timer
If internal battery will not charged, then the timer is no longer good
Oct 24, 2010 | Intermatic Hardware & Accessories
NEC DT330 - - Phone Logo
678 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
