Question about Canon IS Binocular
My Canon 10x30 IS binocs got corrosion in the battery compartment and the stabilization no longer works. I have cleaned it pretty well and put a light coat of oil on the contacts. The contacts look ok to me... So I put in a new set of batteries...but no help. What would you suggest as a next step? I was thinking that if I had some instructions maybe I could disassemble enough to thoroughly clean out the battery compartment.
  • Shuddle Oct 08, 2010
    ok, thanks for the suggestions.
  • Canon Master
  • 3,083 Answers
You're going to have to ohm out or jumper the battery contacts inside the binoculars to see where you're getting a bad flow, and try to address that. Sometimes you can take a think piece of silver coated copper wire, or just copper wire, and make a new contact (solder the wire or glue it to the original contact).
It's really hard to find instructions, per se, for binoculars, since Canon's repair facilities are the guys that have them, but you can learn a lot from blogs about them, in general, and usually enough to get the job done. Just google "binocular repair", and you will find many.
I personally, would not coat the contacts with oil- that will just leave a barrier in the metal to metal contact that is essential in current transfer.
Here's Canon's binocular site, in case you decide to replace some parts:
http://usa.canon.com/cusa/consumer/products/binoculars
Good luck, and hope this helps.
Posted on Oct 08, 2010
How to clean corrosion from inside battery compartment of canon 580EXII
I would use a emery board for the big stuff and a pencil eraser for the contacts
Oct 29, 2012 | Canon 580 580ex Ii
Camera is 5 years old, It has been working fine. Batteries had become low and when I put new batteries in the camera switches on. the , the flash open, the viewer window lights up with set time and date...
Make sure the batteries are the correct type and voltage for your camera. Also because of the age you may have corrosion on the battery contacts inside the battery compartment. If this is the case then no matter how many batteries you try they will not make a good connection. Check first to make sure the batteries are correct type. Look inside the battery compartment and see if the contacts are clean and have no white looking powder or black corrosion on them. If there is you will need to clean this off before a solid connection can be established again. I hate cotton swabs but in this case they work great to clean the contact use some lens cleaner or alcohol (not the drinking kind) on the swab and clean as much as you can. Be careful with this because what you are working with is corrosive.
Once you have swabbed the contacts try a set of batteries. If it still doesn't work you may need to scrap at the terminals gently to get through the corrosion ( I use a long flat screwdriver) but the rubber end of a long pencil will work pretty well. You may have on shiny terminal and the other dark it's that dark one that's giving us grief. I'm hoping before you get to this part the problem has been solved and you can clean the compartment again with the swab. IF it still doesn't work afix a small amount of sand paper on the rubber end of a pencil and tape it there. go down inside and sand off that terminal gently, it doesn't have to be shinny just scratch it up so it gets a good connection. Then sorry you'll need to swab out the battery chamber again. It's gotta work after that
Dec 22, 2010 | Cameras
My Canon 10x30IS Image stabilized binoculars show a double image. Both sides focus and stabilize. Can I do something to fix it or should I send them in for repair?
Like I said before, one of the prisms has shifted and the binoculars have lost collimation. This is not something you can fix yourself.
Nov 18, 2010 | Canon IS (10x30)
Even I put fully charged batteries, after 5 seconds, it gives me message "change the batteries" and goes off
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 20, 2009 | Canon PowerShot A630 Digital Camera
Leica ? Disassemble/ Clean / Reassemble
You're best option is a pair of Canon IS binoculars. I am willing to trade you a 10x30 IS near mint in the box for the Leicas plus $100.
James (718)578-5231
Nov 01, 2009 | Leica 40256 Ultravid 8x20 Compact...
Camera will not turn on. makes a noise when you put in battery. but does not turn on
Your problem may be due to or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Oct 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have a canon powershot A640 when you press the on button it wil
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your camera may have a problem that requires professional repair.
Oct 12, 2009 | Canon Cameras
My Camera will no longer turn on. I've swapped out recharged batteries but nothing seems to work. This a refurbished camera that canon swapped out for a s2is that was having problems with no display on lcd...
There may be something more serious wrong with the camera, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, wipe both ends of the batteries with the cloth, and reinsert them into the camera. This clears the problem about 90% of the time - I hope it works for you.
Sep 09, 2009 | Canon PowerShot S3 IS Digital Camera
Canon IS Binocular Logo
319 people viewed this question
Top Canon Optics Experts
old marine
old marine
TC CAMERA REPAIR.Com...
Are you a Canon Optic Expert? Answer questions, earn points and help others
