Question about Home
Water does not shut off in shower, what can I do
    Problem Solver:
  • 16 Answers
There are a number of reasons your faucet may not be shutting off. If you have an old type of faucet, the problem may be due to a worn out washer, or the faucet may have a damaged seat. In which case, there is a tool that can be purchased in your neighborhood hardware store. You will have to disassemble the faucet and examine the seat to verify the damage. In older faucets, it is sometimes better to replace the faucet than make the repairs, as the repairs and the search for parts to repair the faucet may be almost impossible to find.
Or you may have a washerless faucet which actually has a different type of spring loaded washer, and will wear over a period of time as well.
The shut off valve may even be somewhat loose and require tightening. In most cases, this can be verified if the handle turns 360 degrees and never tightens completely.
I hope this helps you solve your problem
Posted on Oct 08, 2010
The water wont shut off. the shower is always running with water
You need a plumber. They will turn the water off and replace the cartridge that turns the water on and off.
Apr 14, 2016 | Moen & One Handle Tub & Shower Faucet
Bathroom showers drips
Good news MOEN has a lifetime warranty shut water off to shower then remove the valve behind the knob home Depot or lowes give you new one free with old part
Mar 15, 2015 | Moen Home
Why do I only have hot water in the shower
sounds like either the cold water that feeds the other half got shut off, or the mixer in the valve for controlling the water temperature is broken....most likely the water got shut off. better go to the water source and trace the cold water feed pipe ,looking for a shut off valve....it could also be behind the shower panel, then turn or rotate the valve the other way and go test the water to see if you can adjust the temperature now.....if not, then replace your hardware.......in the mean time, you could turn the temperature down on the water heater so that you won't scald yourself in the shower til you have time to fix it properly.
Apr 26, 2012 | Moen Home
I replaced an Moen spout for my shower unit. Water flows thru the Spout and when level is pulled water flows thru the shower head. But there is water leak somewhere (reverse flow?). The ceiling below it...
if you have copper piping,you probably twisted the pipe when,you tightened the spout ,and broke pipe. If you are'nt able to get into the wall on the shower side, cut a hole on the other side of shower wall to repair it.
Aug 04, 2011 | Garden
Cold water suddenly shuts off during shower.
sounds like you may have "air" in the pipes and that bang has slamed the water reg valve shut hard
Mar 27, 2010 | Bosch AquaStar 2400ES-NG
Hand held shower head leaking where connected to bracket
If it leaks continuously during use, verify that a rubber washer was used in that connection and that the connection is tight.
If it only leaks after the water is shut-off, there is a vacuum breaker installed there, which prevents water from siphoning back into your water system. It is normal for water to drain at this connection when the water is shut off.
Jan 25, 2010 | Ace Hardware OAKBROOK COLLECTION DESIGNERS...
Need to clean single knob shower cartridge from what i read - where do i shut off water first? hot water running to bathroom - sink gets it - in shower, cold water good, hot water trickles - read lots of...
To clean it, shut off the discharge valve at the water
heater. Then, you shut the valve off of the main water supply. After which, you can start cleaning the single
knob shower cartridge. After the cleaning job, you can
open the discharge valve of the water heater, then, the
valve of the main water supply.
Nov 11, 2009 | Moen & One Handle Tub & Shower Faucet
I have a new moen single handle shower faucet that is only giving one temp of water (cold). Only if I have it on very slow will I feel hot water. Any idea how to fix
Did the hot water shut off get turned back on fully after the change? Is the hot water line kinked under the sink? Is the hot water shut off valve working?
Aug 05, 2009 | Moen & One Handle Tub & Shower Faucet
Water heater has hot water in it but cold water is still flowing
Nothing wrong with waterheater. Did you perhaps reverse hot/supply lines on new shut off valves?? try reversing lines. Maybe
Please rate. Thanks jj505
Mar 28, 2009 | Whirlpool Water Heaters
Tub water will not stop
sound like the shower control needs washer replacement.
unscrew the control and take it to any hardware store or howm center. get the correct washer.
that will work
Mar 17, 2009 | Kohler Home
Home Logo
188 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
