Question about Refrigerators
Whirlpool american fridge
you was good enough to advise us 2 weeks ago to defrost the chiller unit inside our freezer and all seemed well, but the fridge is now not cool and we have removed panels from freezer and it is all frozen over again.
Any ideas
Nicky
  • 828 Answers
You have a problem in you automatic defrost system. It could be one of the following that is causing it. The defrost timer could be bad, Locate it and rotate the dial Clockwise SLOWLY until you hear one click. The refrigerator will be in the defrost cycle. Wait about 20-30 minutes and if it defrosts and does not restart rotate the dial a little more and it will start. This tells you that the defrost timer is bad. If it does not defrost and restarts after 18-22 minutes the heater or defrost thermostat is bad.
Posted on May 30, 2008
Whirlpool American fridge freezer FRSB36AF20/2 Triangle Warning light on and freezer not freezing. Fridge ok
Most common these symptoms point to a unit low on freon. The fridge gets its cold air from the freezer. So there is just enough freon for a good fridge temp but not to freeze water in the freezer.
Second would be the coils froze over due to the defrost circuit not working. Also check the conderser fan in the freezer. The cooling fan in the back bottom, if there is one, may have quit also.
Sep 27, 2014 | Refrigerators
Samsung fridge not working freezer is?
sounds like you removed the defrost tstat.you need to replace it.if your evap coil ices up it will block the cold air flow to the frige section.replace your bad part so your defrost system willwork
Nov 27, 2012 | Samsung Refrigerators
Hi, my side my side fridge freezer has just packed up, the temp reads cold enough but the fridge and the freezer parts are both warm :( plz help
While it could be the main control board, I would check for a defrost circuit failure first. If you take off the read shield of the freezer you will be able to see the evaporator coils. If that is a block of ice, then your defrost circuit is not doing its job and the ice is causing the thermostats to read the incorrect temperature.
The good news is that once you defrost the unit, you will have 2-3 weeks before the ice builds up enough to be a problem again. Which give you time to troubleshoot and order the replacement parts.
Jan 28, 2012 | Samsung Refrigerators
Fridge side not cold enough but freezer ok.
It is possible that your adaptive defrost assembly found inside the fresh food section and behind the control panel is defective. If not we need to check the defrost heater and the defrost thermostat. Sea Breeze
61005988 Adaptive Defrost Assembly
Jul 25, 2009 | Refrigerators
Top sections of Freezer and Fridge not Cold at all
hi!!! You seem to have a problem with your evaporator fan motor or the defrost mechanism on the frig.That the defrost timer..Listen manually turn of your refrigerature and turn it on again when all the ice melts away if the fan work or runs then its your defrost timer on the frig.Easy fix man..Good luck..
Jan 03, 2009 | KitchenAid KSRG25FKSS Side by Side...
Freezer is freezing up, then freezer and fridge warm up.
hi thanks for your question. you have a no defrost problem. the cheapest part to replace is the defrost termination switch. located in the freezer., its clamped to one of the coils by the fan motor replace this part. see what happens thanks the appliance doc
Oct 30, 2008 | Kenmore 50522 / 50524 Side by Side...
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 | Freezers
S20b rsb21 whirlpool
Your freezer section has a defrost system problem. A device (Timer) schedules defrosts, energizes electric heaters which melt the frost, when the temperature of the coil gets above the point where all ice is melted a thermostat opens cutting the electrical circuit for the heater(s). The defrost cycle continues until the time expires (18-22 minutes). Therefore your problem could be any one of the three elements. Timer, heater, or thermostat.
May 29, 2008 | Refrigerators
Whirlpool refrigerator w/ top freeezer
It has a plugged defrost drain. You may need to defrost for 24 hours with unit unplugged and doors open. UNPLUG FIRST!! f still leaks, you need to remove floor of freezer, then the back wall of freezer. Remove ice. At center rear under coils is the drain hole that is plugged up. Use hair dryer to melt ice. Pour hot water in this area to uncover drain. With hot water in area, you can put a 1/4 diam. hose or copper pipe in drain and blow into it while pressing down. It will slowly go through ice, clearing drain.
Nov 17, 2007 | Whirlpool ER6AHKXPQ Top Freezer...
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
