I have a William 14000 BTU wall heater and the pilot don't stay on
    Scholar:
  • 80 Answers
Make sure the pilot sensing device is clean and free of any dirt or soote! If not then that will probably be the part you need to replace!
Posted on Oct 08, 2010
Wall above Direct Vent Heater gets very hot.
Sense heat rises the only real way to help this is to put some sort of thermal barrier above the heater.
Mar 21, 2017 | Heating & Cooling
I have a Dyna-Glo natural gas unvented roon heater that is wall mounted. The model is #GH-55(30,000 BTU). The pilot lights,but the main burner shuts off after 10-15 seconds with a fairly loud clunk. Do...
the pilot says on yes ? if not pilot could be blocked and need cleaning out or thermocouple needs changing if pilot is staying on then there could be a limit switch shutting off too soon , or burner needs cleaning
Jan 20, 2011 | Heating & Cooling
I HAVE A wILLIAM wALL hEATER. tHE PILOT LIGHT IS
The blower is heat activated, it takes more than the pilot. If the burners are on, verify power to the unit.
Jan 01, 2010 | Williams Heating & Cooling
Empire wall heater with wall vent pilot light
It sounds like the gas valve is dropping out. Make sure the system is venting the exhaust(no restrictions). Then make sure all your wiring connections in the unit are tight. In a millivolt system if all wiring connections aren't tight and clean your circuit will drop in millivolts and the gas valve will drop out. The gas valve requires a certain millivolt to stay open. I hope I was of some assistance!! Good luck!!
Nov 29, 2009 | Empire Direct Vent Wall Furnace Millivolt...
Wall mount propane heater ignites, but won't stay lit
I have a Reddyheat IWH16NLTD with this problem. When the heater fan turns on it blows the pilot light slightly up and away from the thermocouple causing the safety valve to close after the ceramic cools down. The manual says that low gas line pressure can cause the flame to rise too far from the thermocouple causing this problem, so either it is a problem with gas pressure, or it is an assembly plant problem.
Jan 10, 2009 | Reddy Heater-10-12-15,000 Btu L.P.
Natural Gas wall heater
It sounds like the thermocoupler is either not adjusted into the flame properly, or you may have gotten a bad one. The thermocouple is the main thing that makes the pilot work.
Dec 22, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
