Konica minolta c500 error code SC46-13. Printer will not print test page from fiery, just says error code--call service technician
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
herminio_hal
  • 210 Answers
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
  • 97 Answers
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
The fuser temperature is too high. There is probably some residue from the transparency left on the thermister or the thermister went faulty that causes a wrong reading. The only solution would be to have the printer serviced.
Posted on Aug 05, 2009
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
May 01, 2014 | Konica Minolta Bizhub C451...
Scanner settings Bizhub Pro C500
The communication can only be complete when the IP Address is fully established. This is in the manual and information on doing a set up is detailed by Minolta. Only you or a technical person with privileges who you invite into your computer can resolve that issue.
Feb 20, 2014 | Konica Minolta Bizhub Pro C500
Poor quality prints on fiery c451
well what do the colors look like print out the gradation pattern for each color in service mode see what they look like
May 27, 2017 | Konica Minolta bizhub Office Equipment &...
Code error konica minolta c500 sc8101
Assuming your error reads E81-01, this means you have a Printer Control Program Error.
The quote from the service manual says:
"A printer control ROM software
is not installed that is corresponding
to the material
changeover setting".
Either there has been a recent change in your hardware that is conflicting or you may need to have the print controllers firmware reloaded. You will need a Minolta service rep to come out a repair and or reload firmware.
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Office Equipment & Supplies
I have konica minolta bizhub pro c500 machine, that is password protected, I don't know the password. how can i reset password?
You dont specify what you want the password to. So here are some options to try.
If you want admin access to the Fiery print controller the default password is "Fiery.1"
The default operator password for a Creo server is "colorserver"
I'm not positive about the default admin password for the C500 but I'd try these.
eight zeros: "00000000"
or: "12345678"
If these don't work chances are someone has changed them from the default. On the Fiery or Creo this usually means a software reload. On the machine a service rep can probably reset the admin password.
Aug 29, 2010 | Computers & Internet
ERROR CODE SC45-20 MINOLTA 500
Color registration problem Restart copier and leave the front door open,will bypass the error code page.Press HELP,then press KEY OPERATOR MODE, scroll down to 21 EXECUTE ADJUST OPERATION, select COLOR REGIST AUTO ADJUSTMENT, then press OK, PREVIOUS SCREEN. After adjusting, it will back to normal. If the code number back on again, then it was the transfet belt off alignment. If you know how to pull the transfer back to center position, problem solve, if not, call technician.
Feb 11, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Logo Won't Clear from Screen
It sounds like you will need to have a service Tech stop by, it may be a firmware issue, or if you have a Fiery the controller. A Technician can do a diagnostic to find where the error is occuring
Sep 22, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
299 people viewed this question
k24674
jasbo
jasbo
