Question about Electrolux Envirosteamer 370A Canister Vacuum
My enviro steamer was going OK then suddenly just put out water. Then the handle got hot and boiling water started leaking out of the body.
    President:
  • 2,777 Answers
That's a major hardware failure in the unit, there is no simple fix for that. How old is this unit?
Tim
Posted on Oct 08, 2010
I ned at instruction book for electrolux enviro multi steamer
You didn't specify which model you had, but I assume it's the newer Eureka Enviro Steamer Model 313A.
Here's a link to the owners manual for your Steamer. If you have an older Enviro steamer, please feel free to reply using the comment field below. Also, if you found this solution helpful, please be sure to leave feedback for me. Leaving feedback is greatly appreciated by the FixYa community, and ensures that repair experts continue to leave great FREE advice, as opposed to just answering the premium, or paid questions.
Hope this helped you, thanks again.
Eureka by Electrolux Enviro Steamer Owners Manual for 313A
Jan 07, 2011 | Vacuums
My Eureka Deluxe Enviro Steamer doesn't steam, I had no directions with it so I'm not sure how much water to put in it. It comes out the bottom before it heats up sometimes.It never seems to get hot...
You will need to pour two measures of water using the measuring cup or 12 oz of water. The reason why water comes out of the bottom is because the floor cloth is too wet or you had too much water in the tank
Click on the link below to view the owners manual:
http://www.eureka.com/service/manuals/70359.pdf
Jun 22, 2010 | Eureka Deluxe Enviro Steamer Vacuum
I have an electrolux enviro multi steamer and have no instructions. I filled it up and turned it on and it is steaming out everywhere. The handle became too hot to use. What am I doing wrong ?
Check the handle. There is a Button which you press and hold and one which slides up and down. The slide button is so you don't have to depress the other button (when you are wanting constant steam, ie., for cleaning floors etc...).
I would suggest that the slide button is engaged (meaning in the on position), slide it back the opposite way and see if this solves the problem. Regards, Tina
Nov 15, 2009 | Electrolux Vacuums
Scuncii Steamer
It is probably clogged with rust or limescale - can happen with steam cleaners. Sadly there's no way around this but to try a limescale remover in distilled water such as Calgon limescale remover. Fill the kettle as normal and give it time to boil up. Then release the steam as you would normally. You may find that the kettle will spurt out deposits of gunk. Sounds like its definately clogged though.
Feb 19, 2009 | Scunci 52067 Handheld Steam Vacuum
Can't get it open
had same problem. Tried pouring boiling water over cap and it seemed to loosen some so I boiled more water and put the steamer top down in a bowl in the kitchen sink and pour the boiling water in and let it sit about 5 minutes. It came loose with some effort. The grooves are the opening are metal and they had started to corrode.Once open coat with wd40.
Jan 31, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
I have an electrolux Enviro multi steamer which I was using this morning. I turned the steamer off for approximately 1 1/2 to do some shopping, and when I turned it on again, the steamer light turned on...
Problem fixed itself. Turned off for couple of hours so unit can cool down completely and when I turned it back on it started working again.
Dec 14, 2008 | Vacuums
Knob
The safety cap (knob) turns counter clockwise to open so you can put water in. Turn clockwise to close after filling.
Aug 03, 2008 | Eureka Enviro Steamer 310 Stick Vacuum
Electrolux Envirosteamer 370A Canister Vacuum Logo
160 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
